Home » Eclipse Projects » Nebula » GridTableViewer - CellModifier problem with collapsed GridColumnGroup?
GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44209] Thu, 29 November 2007 05:46 Go to next message
Hi all,
working with Nebula latest release, I have a problem with editable cells
on a GridTableViewer, with collapsed GridColumnGroup.
Let's assume I have 3 GridColumn (col1,col2,col3).
The one in the middle has : col2.setSummary(false);
The table shows the right values, GridColumngroup Expanded and Collapsed ;
meaning that the LabelProvider works well GridColumnGroup.
When GridColumnGroup expanded, a click on any cell of any column allows to
edit the right value.
When Collapsed, a click on col3 give the opportunity to edit hidden col2.
The methods of the CellModifier are given wrong "property" argument by the
GridTableViewer.
In fact, this problem happens when clicking at a position a hidden column
was located when the GridColumnGroup was expanded.
To sum up :
| group << |
|col1|col2| col3 |
| group >> |
|col1| col3 |
| |XXXXXYYY|
When clicking on XXXXX, you edit col2
When clicking on YYY, you edit col3
The problem comes with the CellModifier. Has anyone else the same problem ?
Any idea to solve this ?
Philippe
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44240 is a reply to message #44209] Thu, 29 November 2007 06:12 Go to previous messageGo to next message
It seems that the algorithm to find the correct column to edit is not
working. I suppose the problem is found in
GridViewerRow#getColumnIndex(Point) where we try to correct index.
I think we never tested this at least I haven't so it is fairly likely
that it's not working as expected. Another problem in this area could be
tabbing support.
Ravaine would you mind to creating a snippet (we can run without
modifications) to reproduce the problem and file a bugzilla. I'll take
at it look then.
Tom
Ravaine Philippe schrieb:
> Hi all,
> ; meaning that the LabelProvider works well GridColumnGroup.
> to edit the right value.
> the GridTableViewer.
> column was located when the GridColumnGroup was expanded.
> To sum up :
> | group << |
> |col1|col2| col3 |
> | group >> |
> |col1| col3 |
> | |XXXXXYYY|
> Cheers,
> Philippe
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44269 is a reply to message #44240] Thu, 29 November 2007 11:47 Go to previous messageGo to next message
Hi Tom,
As you were assuming, another problem in the area is tabbing support.
I just created a snippet and attach it to the new bug I reported : Bug
211466
Hope you'll get time to have a look at it.
Philippe Ravaine
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44299 is a reply to message #44269] Thu, 29 November 2007 12:36 Go to previous messageGo to next message
Thank you for the great snippet Philippe. This makes fixing bugs fun :-)
Tom
> Hi Tom,
> 211466
> Cheers,
> Philippe Ravaine
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #44389 is a reply to message #44299] Thu, 29 November 2007 18:08 Go to previous message
Bug fixed :)
And I agree with Tom - great bug report! Thanks.
-Chris
> Tom
>> Hi Tom,
>> 211466
>> Cheers,
>> Philippe Ravaine
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586760 is a reply to message #44209] Thu, 29 November 2007 06:12 Go to previous message
tabbing support.
at it look then.
Tom
> Hi all,
> To sum up :
> | group << |
> |col1|col2| col3 |
> | group >> |
> |col1| col3 |
> | |XXXXXYYY|
> Cheers,
> Philippe
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586772 is a reply to message #44240] Thu, 29 November 2007 11:47 Go to previous message
Hi Tom,
211466
Philippe Ravaine
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586781 is a reply to message #44269] Thu, 29 November 2007 12:36 Go to previous message
Tom
> Hi Tom,
> 211466
> Cheers,
> Philippe Ravaine
Re: GridTableViewer - CellModifier problem with collapsed GridColumnGroup? [message #586838 is a reply to message #44299] Thu, 29 November 2007 18:08 Go to previous message
Bug fixed :)
-Chris
> Tom
>> Hi Tom,
>> 211466
>> Cheers,
>> Philippe Ravaine
Previous Topic:GridViewer and SWT.VIRTUAL
Next Topic:Re: Using Nebula CalendarCombo and DataBinding
Current Time: Sun Aug 31 04:50:48 EDT 2025
Powered by FUDForum. Page generated in 0.11632 seconds
