Home » Eclipse Projects » Nebula » SWT Ribbon - Alpha 2 Out
SWT Ribbon - Alpha 2 Out [message #44177] |
Wed, 28 November 2007 16:05  |
Hello all!
Just doing a quick post to let you all know the SWT Ribbon is up/out as an
Alpha 2. I'm between things at the moment (moving to a new country among
other things - no I'm not running from anything ;-) ) so I figured I'd make
an update to it while I can and have internet. It should be quite a bit more
stable than the first Alpha and includes lots of fixes and new features (the
RibbonShell and the two-style toolbars among others), but there's still
stuff missing and so on.
For downloads, screenshots, what's left to do, etc, go to
http://www.hexapixel.com/ribbon/
You'll need Java 5, I don't really plan on making it 1.4 or earlier
compatible, 5.0 is just too convenient for maintaining large amounts of
code.
Please post questions/problems in this very thread and I'll check it when I
can. For example code, check the RibbonTester.java file in the source jar.
Kind of important note: It's not required you use the RibbonShell at all,
you can use it as a widget as well just like the older screenshots. The
sample code however uses the shell but there's commented out code that uses
it as a widget in the RibbonTester.java file as well.
Enjoy (I hope)!
Emil
Emil Crumhorn
Nebula Committer
Re: SWT Ribbon - Alpha 2 Out [message #44358 is a reply to message #44177] |
Thu, 29 November 2007 18:07   |
Very very cool stuff. I downloaded the source to try stuff out but its
not complete. There appears to be some utility classes/package thats
not included :(
-Chris
Emil Crumhorn wrote:
> Hello all!
> code.
> Enjoy (I hope)!
> Emil
Re: SWT Ribbon - Alpha 2 Out [message #44420 is a reply to message #44358] |
Fri, 30 November 2007 04:24   |
Ack, you're right, I'm an idiot. In my haste I forgot the generic part of
the package. I've made the changes and uploaded new files of each, let me
know if there's still trouble.
Thanks! :)
Emil
"Chris Gross" <chris.gross@us.ibm.com> wrote in message
news:fingl5$4o5$2@build.eclipse.org...
> not complete. There appears to be some utility classes/package thats not
> included :(
> -Chris
>> Hello all!
>> an Alpha 2. I'm between things at the moment (moving to a new country
>> among other things - no I'm not running from anything ;-) ) so I figured
>> I'd make an update to it while I can and have internet. It should be
>> quite a bit more stable than the first Alpha and includes lots of fixes
>> and new features (the RibbonShell and the two-style toolbars among
>> others), but there's still stuff missing and so on.
>> code.
>> I can. For example code, check the RibbonTester.java file in the source
>> jar.
>> uses it as a widget in the RibbonTester.java file as well.
>> Enjoy (I hope)!
>> Emil
Re: SWT Ribbon - Alpha 2 Out [message #60942 is a reply to message #44177] |
Fri, 28 November 2008 21:07   |
> Hello all!
> code.
> Enjoy (I hope)!
> Emil
Any news on a new release? This would be cool for a project we are
planning.
Re: SWT Ribbon - Alpha 2 Out [message #61064 is a reply to message #60942] |
Mon, 08 December 2008 15:35  |
Hi Darren,
Not at the moment. The project has been stalled as I've been cleaning up the
3 other widgets that are in Nebula, as well as other real life tasks + work.
I would like to finish it, but there is no new version coming at the moment.
It's hard to find time to keep all these widgets going solo :)
But that said, I hope to be able to go back into it soon.
Emil
"Darren Bell" <djb.bell@gmail.com> wrote in message
news:ggq85u$je$2@build.eclipse.org...
>> Hello all!
>> code.
>> jar.
>> Enjoy (I hope)!
>> Emil
> planning.
Re: SWT Ribbon - Alpha 2 Out [message #586821 is a reply to message #44177] |
not included :(
-Chris
> Hello all!
> code.
> Enjoy (I hope)!
> Emil
Re: SWT Ribbon - Alpha 2 Out [message #586847 is a reply to message #44358] |
Thanks! :)
Emil
> included :(
> -Chris
>> Hello all!
>> code.
>> jar.
>> Enjoy (I hope)!
>> Emil
Re: SWT Ribbon - Alpha 2 Out [message #586864 is a reply to message #44177] |
Fri, 30 November 2007 14:51  |
> Hello all!
Can I make a suggestion: there's no high-level explanation - I can't
tell at a glance what the thing is supposed to do. You should provide an
"introduction" that gives the gist in a couple of sentences.
Eric
Re: SWT Ribbon - Alpha 2 Out [message #586874 is a reply to message #44451] |
Sun, 02 December 2007 08:12  |
I guess I figured pretty much everyone knew what the Office 2007 ribbon was
at this point, you're the first I've heard ask what it's for.
In short:
The ribbon is a menubar and toolbar replacement widget that gives an easy
overview of menu items and toolbar items by showing large clear buttons and
descriptive tooltips. Each tab could be viewed as a menu section (for
example "Edit") and then each item in that tab area could be viewed as a
menu item, such as "Find" or "Copy" etc.
Microsoft does a much better job describing it of course:
http://office.microsoft.com/en-us/products/HA101679411033.as px
(and there's many more sites for more info)
I assume that's what you were asking for.
Emil
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:fippj4$c2f$2@build.eclipse.org...
>> Hello all!
> Can I make a suggestion: there's no high-level explanation - I can't tell
> Eric
Re: SWT Ribbon - Alpha 2 Out [message #586884 is a reply to message #44481] |
Mon, 03 December 2007 11:45  |
> In short:
It helps me understand a little better, but my suggestion was really
that the web page for your SWT implementation should explain it. I
definitely think it is invalid to assume "everyone" will be familiar
with Office 2007 - many companies and people have not yet upgraded.
Eric
>>> Hello all!
>> Eric
Re: SWT Ribbon - Alpha 2 Out [message #592837 is a reply to message #44177] |
> Hello all!
> code.
> Enjoy (I hope)!
> Emil
planning.
Re: SWT Ribbon - Alpha 2 Out [message #592892 is a reply to message #60942] |
Hi Darren,
Emil
>> Hello all!
>> code.
>> jar.
>> Enjoy (I hope)!
>> Emil
> planning.
Current Time: Thu Jul 17 20:44:16 EDT 2025
Powered by FUDForum. Page generated in 0.55359 seconds
