Home » Archived » M2M (model-to-model transformation) » ATL - How to assign a new value to an attribute of type map
ATL - How to assign a new value to an attribute of type map [message #44176] Mon, 04 June 2007 11:01 Go to next message
Originally posted by: erik_becker.gmx.de
Hi all,
In my ATL transformation I want to create a Map(Integer, String) that
will be updated and used while the transformation.
Unfortunately the update doesn't work. I always get the same (empty) map.
Here's my code:
helper def : getNewID(amlID: String) : Integer =
if thisModule.IdMap.getKeys()->size() > 0 then
let
newId : Integer = thisModule.getMaximum(
thisModule.IdMap->getKeys()) + 1
in
let
temp : Map(Integer, String) =
thisModule.IdMap->including(newId, amlID)
in
thisModule.IdMap->getKeys().getMaximum()
else
let
newId : Integer = 1
in
thisModule.IdMap->including(newId,amlID)
.getKeys()->asSequence()->first()
endif;
helper def : IdMap : Map(Integer, String) = Map{};
The transformation doesn't fail, but it doesn't what I want.
If I make an assignment like
thisModule.IdMap <- thisModule.IdMap->including(...)
I get an problem in the ATL editor
How can I assign a new value to my 'IdMap' to update the attribute and
how to get the update attribute?
Can anyone help?
Erik
Re: [ATL] - How to assign a new value to an attribute of type map [message #44207 is a reply to message #44176] Mon, 04 June 2007 11:56 Go to previous message
Hi Erik,
The including operation on a Map has a return type. This is why the
transformation works but does not behave as expected.
A Map can be filled in an imperative block (e.g "do" clause of a rule)
following the syntax you proposed:
do {
Helpers can be used for accessing the values (or keys) of a Map.
See the ATL User Manual for more details.
Erik Becker wrote:
> Hi all,
> Here's my code:
> let
> in
> let
> in
> else
> let
> newId : Integer = 1
> in
> endif;
> Can anyone help?
> Regards
> Erik
Éric Vépa
SODIUS
6, rue de la Cornouaille - BP 91941
44319 Nantes, France
Email: evepa@sodius.com
www.mdworkbench.com
Draw more value from your models
Previous Topic:[ATL] Proper nesting
Next Topic:[TCS] Where is km3.tcs file ?
Current Time: Thu Jul 17 07:00:50 EDT 2025
Powered by FUDForum. Page generated in 0.03412 seconds
