Home » Newcomers » Newcomers » Could not find framework msg when trying to launch Eclipse
Could not find framework msg when trying to launch Eclipse [message #44163] Thu, 31 March 2005 09:19 Go to next message
Originally posted by: lcole.ball.com
!SESSION Thu Mar 31 09:17:06 EST 2005
!ENTRY org.eclipse.core.launcher 4 0 Mar 31, 2005 09:17:06.997
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:395)
at org.eclipse.core.launcher.Main.basicRun(Main.java:174)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Could not find framework msg when trying to launch Eclipse [message #44194 is a reply to message #44163] Thu, 31 March 2005 09:22 Go to previous messageGo to next message
Sorry, meant to ask if anyone has any thoughts on why I'm getting this
error and how to resolve it.
Lisa
Re: Could not find framework msg when trying to launch Eclipse [message #44924 is a reply to message #44194] Fri, 01 April 2005 02:41 Go to previous message
> Lisa
Lisa,
This sounds like some of the (standard) plugins might be missing. Did
you have any problems/issues when extracting the eclipse zip file? Most
probabely the easiest (first try) would be to to extract the archive
once again. If the problem persistes, could you post a list of files and
subdirectories in your eclipse directory?
Hope this helps,
Kai
Previous Topic:Eclipse cannot run on Intel EM64T with Fedora Core 3
Next Topic:Eclipse and Doja
Current Time: Thu Jul 17 21:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.52998 seconds
