Problem with Classloader switch and narrow Object [message #44155] |
Tue, 29 June 2004 08:14 |
We are using different plugins in our application. The main one depends on a library plugin containing the weblogic jar. To get the InitialContext from the weblogic jar we need to switch the Classloader (without we get an javax.naming.NoInitialContextException). If we wan't to get the RemoteHomeObject of another plugin we get an ClassCastException, Cannot narrow....
Can anyone help me on this subject? Is the Classloader switch still needing? If yes how does it work if I have to switch between different plugins?
code
public ServiceLocator() throws ServiceLocatorException
try
ClassloaderSwitch.switch2CL();
Hashtable env = new Hashtable();
env.put(Context.INITIAL_CONTEXT_FACTORY,
"weblogic.jndi.WLInitialContextFactory");
env.put(Context.PROVIDER_URL, "t3://myhost:8880");
ic = new InitialContext(env);
catch (NamingException ne)
throw new ServiceLocatorException(ne);
catch (Exception e)
throw new ServiceLocatorException(e);
finally
ClassloaderSwitch.switch2Normal();
public EJBHome getRemoteHome(String jndiHomeName, Class className)
EJBHome home = null;
try
Object objref = ic.lookup(jndiHomeName);
Object obj = PortableRemoteObject.narrow(objref, className);
home = (EJBHome) obj;
catch (Exception e)
return home;
Beat
FUDForum. Page generated in 0.02977 seconds
