Home » Eclipse Projects » Nebula » GridViewer and SWT.VIRTUAL
GridViewer and SWT.VIRTUAL [message #44146] Wed, 28 November 2007 14:36 Go to next message
Does the GridViewer support the virtual style bit of the Grid? I see a few
references (// TODO Fix when grid supports virtual) in GridTableViewer which
makes me think that it's not yet supported. If that's true, is there an
estimated time for this feature?
Chuck
Re: GridViewer and SWT.VIRTUAL [message #44327 is a reply to message #44146] Thu, 29 November 2007 18:07 Go to previous message
Yes the GridViewer hasn't been updated to work with the virtual style
but thats partly because the virtual mode hasn't been completed in Grid.
Its mostly there but I haven't implemented the the clear methods and I
haven't optimized the performance. The clear methods could be added and
the API would essentially be complete. Then GridViewer could be
updated. The clear methods should be very easy to implement. If you're
still looking to contribute it could be a real easy way to get started.
-Chris
> Chuck
Re: GridViewer and SWT.VIRTUAL [message #586802 is a reply to message #44146] Thu, 29 November 2007 18:07 Go to previous message
-Chris
> Chuck
Previous Topic:GridTableViewer - CellModifier problem with collapsed GridColumnGroup?
Next Topic:GridTableViewer - CellModifier problem with collapsed GridColumnGroup?
Current Time: Fri Jul 18 23:25:28 EDT 2025
Powered by FUDForum. Page generated in 0.02769 seconds
