Home » Eclipse Projects » DTP » Formatting SQL
Formatting SQL [message #44129] Mon, 21 April 2008 23:34 Go to next message
Originally posted by: eclipsenews.20.epm.spamgourmet.com
Even though there is a 'Format SQL' function available under the Edit
menu when editing a SQL scrapbook... it doesn't appear to do anything.
Have I got something misconfigured?
Also, the content assist is pretty good at suggesting standard SQL
keywords, however it seems it would be much more useful if it could
content assist table and field names. Is that possible, or a feature
that is planned?
Cheers
Tom
Re: Formatting SQL [message #44191 is a reply to message #44129] Tue, 29 April 2008 09:24 Go to previous messageGo to next message
Hello Tom,
Can you tell us which version of DTP/Eclipse and which database you are
using?
Rico
PS:
If I remember right, the "Format SQL" function should change all
registered keywords of your database dialect to upper case. To make this
work you have to set at least the database type for the scrapbook.
Re: Formatting SQL [message #44219 is a reply to message #44191] Wed, 30 April 2008 20:30 Go to previous message
Hi Enrico,
Thanks for your reply. I am using Eclipse 3.3.2 with DTP 1.5.2 and
PostgreSQL 8.2.4.
Format SQL does not appear to do anything, not even uppercase the SQL
keywords, even though I have set the database type for the scrap book.
It does autocomplete the keywords though.
I often have to deal with dumps of queries that are long with many
subqueries, and which are largely unreadable. I was kind of hoping the
format sql feature might split queries into multiple lines with
indenting. When I code complicated queries I often format them something
like this:
SELECT
something,
somethingelse,
SELECT
athirdthing
FROM
thirdtable
) as thirdthing
FROM
sometable
INNER JOIN someothertable
WHERE
this = that;
Etc. Is anything like that planned for the future? Could I submit a
feature request?
Cheers
Tom
Enrico Schenk wrote:
> Hello Tom,
> using?
> Rico
> PS:
Re: Formatting SQL [message #591035 is a reply to message #44129] Tue, 29 April 2008 09:24 Go to previous message
Hello Tom,
using?
Rico
PS:
Re: Formatting SQL [message #591052 is a reply to message #44191] Wed, 30 April 2008 20:30 Go to previous message
Hi Enrico,
PostgreSQL 8.2.4.
like this:
SELECT
something,
somethingelse,
SELECT
athirdthing
FROM
thirdtable
) as thirdthing
FROM
sometable
WHERE
this = that;
feature request?
Cheers
Tom
> Hello Tom,
> using?
> Rico
> PS:
Previous Topic:DTP Incubator Promotion Policy
Next Topic:JDBC Connection Error
Current Time: Thu Jul 17 18:34:29 EDT 2025
Powered by FUDForum. Page generated in 0.04675 seconds
