Home » Eclipse Projects » Plugin Development Environment (PDE) » pde.exportPlugins failed
pde.exportPlugins failed [message #44118] Tue, 03 February 2009 05:17 Go to next message
I want to make jar file of my plugin using ANT.
<target name="pe" depends="init">
<pde.exportPlugins destination="${tempPlugin}" exportSource="false"
exportType="directory" plugins="Project_Wizard" useJARFormat="true"/>
</target>
After run command i got message:
D:\ANT>ant pe
I got messase:
BUILD FAILED
D:\ANT\build.xml:54: taskdef doesn't support the "class" attribute
Can any one help me for this.
Re: pde.exportPlugins failed [message #44149 is a reply to message #44118] Tue, 03 February 2009 07:25 Go to previous messageGo to next message
> D:ANTbuild.xml:54: taskdef doesn't support the "class" attribute
You have to write a taskdef with a 'classname' attribute.
http://ant.apache.org/manual/CoreTasks/taskdef.html
> </target>
> D:ANT>ant pe
> I got messase:
> BUILD FAILED
The error messages tells it
Re: pde.exportPlugins failed [message #44180 is a reply to message #44149] Tue, 03 February 2009 08:38 Go to previous messageGo to next message
thanks!
I set taskdef by using
<taskdef name="pde.exportPlugins"
classname="org.eclipse.ant.core.antRunner"/>
BUILD FAILED
D:\NFCProject\ANT\build.xml:54: taskdef class
org.eclipse.ant.core.antRunner can
not be found
My goal is to make Eclipse plug-in by using ANT not from eclipse export
wizard.
is there any other solution for this.
Re: pde.exportPlugins failed [message #44242 is a reply to message #44180] Tue, 03 February 2009 11:00 Go to previous messageGo to next message
look for the project http://www.pluginbuilder.org/
and some tutorials on pde-build (for example
http://rcpquickstart.com/2007/06/06/getting-started-with-pde -build/)
Re: pde.exportPlugins failed [message #44392 is a reply to message #44180] Tue, 03 February 2009 14:53 Go to previous messageGo to next message
The pde.exportPlugins task needs eclipse to be running in order to work,
it is essentially doing an export from the workspace (which is slightly
different from a headless build).
To use it you will need to start ant using the eclipse antrunner:
eclipse -application org.eclipse.ant.core.antRunner <ant command line>
-Andrew
Dhirendra Rawal wrote:
> thanks!
> BUILD FAILED
> not be found
> wizard.
Re: pde.exportPlugins failed [message #45280 is a reply to message #44392] Thu, 05 February 2009 03:24 Go to previous message
thanks to all of you.
now I am able to make jar by eclipse antRunner.
But i want to do it using ANT only no eclipse ,i tried to it by putting
antRunnner jar in seprate folder but still facing error and problem.
Is anyone has idea about it.
Please help.
Re: pde.exportPlugins failed [message #591144 is a reply to message #44118] Tue, 03 February 2009 07:25 Go to previous message
> </target>
> D:ANT>ant pe
> I got messase:
> BUILD FAILED
Re: pde.exportPlugins failed [message #591150 is a reply to message #44149] Tue, 03 February 2009 08:38 Go to previous message
thanks!
BUILD FAILED
not be found
wizard.
Re: pde.exportPlugins failed [message #591180 is a reply to message #44180] Tue, 03 February 2009 11:00 Go to previous message
Re: pde.exportPlugins failed [message #591222 is a reply to message #44180] Tue, 03 February 2009 14:53 Go to previous message
-Andrew
> thanks!
> BUILD FAILED
> not be found
> wizard.
Re: pde.exportPlugins failed [message #591483 is a reply to message #44392] Thu, 05 February 2009 03:24 Go to previous message
Please help.
Previous Topic:Can I use ant build rcp product?Anybody has correct example?
Next Topic:Where can I find the exported jars ?
Current Time: Sat Jul 12 22:46:24 EDT 2025
Powered by FUDForum. Page generated in 0.47240 seconds
