Code Assist Javadoc Hover [message #44079] |
Thu, 29 May 2003 23:30  |
No matter what I try, I cannot get Javadoc to show in a hover next to
code assist. I could swear this worked on other Eclipse installations
I've used. Javadoc is definitely available for the methods I'm selecting
in the code assist popup - if I type the methods into the editor and
hover over them, I see the Javadoc in a hover. I've scoured the
preferences, and I don't see a preference that controls whether Javadoc
is shown in code assist.
Actually, it appears that code assist refuses to use hovers in any
circumstance. If I create a new class, then type "to"<ctrl-space> to
override toString(), I don't see the hover which shows the code about to
be generated.
Anyone have an idea?
Jeff
Re: Code Assist Javadoc Hover [message #45189 is a reply to message #44385] |
Fri, 30 May 2003 15:05  |
>> Javadoc is shown in code assist.
>> to be generated.
> Works for me using I20030528 on Win2k. Please file a bug report with
> steps to reproduce.
Filed: https://bugs.eclipse.org/bugs/show_bug.cgi?id=38279
Summary: There seems to be a bug which causes Code Assist hovers to
never appear if you set the Code Assist auto activation delay to zero.
Jeff
FUDForum. Page generated in 0.05377 seconds
