Home » Archived » OHF » Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down?
Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #44056] Wed, 16 July 2008 07:37 Go to next message
Originally posted by: michael.sprinzl.siemens.com
Hi everyone!
I am new to the Eclipse OHF project and therefore I wanted to try the
Public Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/
mentioned in the OHF Wiki. After entering username & password I always get:
Unknown error in getProxyohfsoapclient Object ( [bridgeClient] =>
soap_fault Object ( [error_message_prefix] => [mode] => 1 [level] => 1024
[code] => WSDLCACHE [message] => Unable to retrieve WSDL
http://healthcare.almaden.ibm.com:8080/bridge/services/ohf-b ridge?wsdl,
[userinfo] =>
[backtrace] => Array ( [0] => Array ( [file] =>
/usr/share/pear/SOAP/Fault.php [line] => 52 [function] => pear_error
[class] => pear_error [type] => :: [args] => Array ( [0] => Unable to
retrieve WSDL
[1] => WSDLCACHE [2] => [3] => [4] =>
http://healthcare.almaden.ibm.com:8080/bridge/services/ohf-b ridge?wsdl ) )
[1] => Array ( [file] => /usr/share/pear/SOAP/Base.php [line] => 205
[function] => soap_fault [class] => soap_fault [type] => -> [args] =>
Array ( [0] => Unable to retrieve WSDL
http://healthcare.almaden.ibm.com:8080/bridge/services/ohf-b ridge?wsdl [4]
=> [5] => ) ) [2] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php
[line] => 993 [function] => _raisesoapfault [class] => soap_wsdl_cache
[type] => -> [args] => Array ( [0] => Unable to retrieve WSDL
[1] =>
[3] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 1067
[function] => get [class] => soap_wsdl_cache [type] => -> [args] => Array
( [0] =>
http://healthcare.almaden.ibm.com:8080/bridge/services/ohf-b ridge?wsdl [1]
=> Array ( ) ) ) [4] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php
[line] => 1061 [function] => parse [class] => soap_wsdl_parser [type] =>
[5] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 156
[function] => soap_wsdl_parser [class] => soap_wsdl_parser [type] => ->
=> soap_wsdl Object ( [_XMLSchema] => Array ( [0] =>
http://www.w3.org/2001/XMLSchema [1] => http://www.w3.org/1999/XMLSchema )
[_XMLSchemaVersion] => http://www.w3.org/2001/XMLSchema [_typemap] =>
Array ( [http://www.w3.org/2001/XMLSchema] => Array ( [string] => string
[boolean] => boolean [float] => float [double] => float [decimal] => float
[duration] => integer [dateTime] => string [time] => string [date] =>
string [gYearMonth] => integer [gYear] => integer [gMonthDay] => integer
[gDay] => integer [gMonth] => integer [hexBinary] => string [base64Binary]
=> string [normalizedString] => string [token] => string [language] =>
string [NMTOKEN] => string [NMTOKENS] => string [Name] => string [NCName]
=> string [ID] => string [IDREF] => string [IDREFS] => string [ENTITY] =>
string [ENTITIES] => string [integer] => integer [nonPositiveInteger] =>
integer [negativeInteger] => integer [long] => integer [int] => integer
[short] => integer [byte] => string [nonNegativeInteger] => integer
[unsignedLong] => integer [unsignedInt] => integer [unsignedShort] =>
integer [unsignedByte] => integer [positiveInteger] => integer [anyType]
=> string [anyURI] => string [QName] => string )
[http://www.w3.org/1999/XMLSchema] => Array ( [i4] => integer [int] =>
integer [boolean] => boolean [string] => string [double] => float [float]
=> float [dateTime] => string [timeInstant] => string [base64Binary] =>
string [base64] => string [ur-type] => string )
[http://schemas.xmlsoap.org/soap/encoding/] => Array ( [base64] => string
[array] => array [Array] => array [Struct] => array ) )
[_defaultObjectClassname] => stdClass [_namespaces] => Array (
[http://schemas.xmlsoap.org/soap/envelope/] => SOAP-ENV
[http://www.w3.org/2001/XMLSchema] => xsd
[http://www.w3.org/2001/XMLSchema-instance] => xsi
[http://schemas.xmlsoap.org/soap/encoding/] => SOAP-ENC ) [_namespace] =>
[_xmlEntities] => Array ( [&] => & [<] => < [>] => > ['] => &apos; ["] =>
" ) [_doconversion] => [__attachments] => Array ( ) [_wsdl] => [_section5]
=> 1 [_auto_translation] => [_type_translation] => Array ( ) [_debug_flag]
=> [_debug_data] => [_encodings] => Array ( [0] => ISO-8859-1 [1] =>
US-ASCII [2] => UTF-8 ) [_myfaultcode] => WSDL [fault] => soap_fault
Object ( [error_message_prefix] => [mode] => 1 [level] => 1024 [code] =>
[userinfo] =>
[backtrace] => Array *RECURSION* [callback] => ) [_debug] =>
[_default_error_mode] => [_default_error_options] =>
[_default_error_handler] => [_error_class] => SOAP_Fault
[_expected_errors] => Array ( ) [tns] => [definition] => Array ( )
[namespaces] => Array ( ) [ns] => Array ( ) [xsd] =>
http://www.w3.org/2001/XMLSchema [complexTypes] => Array ( ) [elements] =>
Array ( ) [messages] => Array ( ) [portTypes] => Array ( ) [bindings] =>
Array ( ) [imports] => Array ( ) [services] => Array ( ) [service] =>
[uri] =>
[docs] => [proxy] => Array ( ) [trace] => 0 [cacheUse] => 0 [cacheMaxAge]
=> 43200 [wsdlParserClass] => SOAP_WSDL_Parser ) [2] => ) ) [6] => Array (
[file] => /usr/share/pear/SOAP/WSDL.php [line] => 125 [function] =>
parseurl [class] => soap_wsdl [type] => -> [args] => Array ( [0] =>
[7] => Array ( [file] => /healthcare/demo/lib/OHFSoapClient.php [line] =>
38 [function] => soap_wsdl [class] => soap_wsdl [type] => -> [args] =>
Array ( [0] =>
[8] => Array ( [file] => /healthcare/demo/lib/OHFSoapClient.php [line] =>
25 [function] => initbridgeservice [class] => ohfsoapclient [type] => ->
[args] => Array ( ) ) [9] => Array ( [file] =>
/healthcare/demo/lib/OHFRhioConfigurations.php [line] => 50 [function] =>
ohfsoapclient [class] => ohfsoapclient [type] => -> [args] => Array ( [0]
=> Array ( [user] => asas [password] => asas [facility] => ) [1] => utils
Object ( ) ) ) [10] => Array ( [file] =>
/healthcare/demo/lib/OHFRhioConfigurations.php [line] => 42 [function] =>
showrhiopanel [class] => ohfrhioconfigurations [type] => -> [args] =>
Array ( [0] => Array ( [user] => asas [password] => asas [facility] => )
[1] => utils Object ( ) ) ) [11] => Array ( [file] =>
/healthcare/demo/index.php [line] => 55 [function] => isconfigured [class]
=> ohfrhioconfigurations [type] => -> [args] => Array ( [0] => Array (
[logout] => no [badlog] => no [getMyLog] => no [reset_rhio] => no
[search_patient] => no [add_patient_form] => no [search_doc_by_id] => no
[search_doc_by_details] => no [search_doc_do_search] => no
[searchPatientId] => [AANamespaceId] => [AAUniversalId] =>
[AAUniversalIdType] => [AAUniversalIdTypeCode] => [patientIdx] =>
[patient_details] => no [patientId] => [idNumber] => [patientId2send2] =>
[sendDocument] => no [useFQS] => off [user] => asas [password] => asas
[facility] => ) [1] => Array ( [user] => asas [password] => asas
[facility] => ) [2] => utils Object ( ) ) ) ) [callback] => ) [utils] =>
utils Object ( ) [_SESSION] => Array ( [user] => asas [password] => asas
[facility] => ) ) The OHF Bridge is probably down.
I tried to send a mail to Eishay Smith as mentioned within the error
message but it returned, mainly due to the fact that Eishay does not work
anymore for IBM Almaden Research Center (according to Google ;-)).
Any ideas who I should contact regarding this issue or is the Public Demo
OHF Bridge not maintained anymore?
Kind regards
Michael Sprinzl
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #44127 is a reply to message #44056] Wed, 16 July 2008 18:56 Go to previous messageGo to next message
Hi Micheal -
You've reached the right forum here. We'll look into this - we had a
site shut down recently -- probably nothing more than re-starting Tomcat
or something.
- Sarah
Michael Sprinzl wrote:
> Hi everyone!
> 1024 [code] => WSDLCACHE [message] => Unable to retrieve WSDL
> [userinfo] =>
> retrieve WSDL
> ) [1] => Array ( [file] => /usr/share/pear/SOAP/Base.php [line] => 205
> [4] => [5] => ) ) [2] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php
> [1] =>
> ) [3] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 1067
> Array ( [0] =>
> [1] => Array ( ) ) ) [4] => Array ( [file] =>
> /usr/share/pear/SOAP/WSDL.php [line] => 1061 [function] => parse [class]
> => soap_wsdl_parser [type] => -> [args] => Array ( [0] =>
> ) [5] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 156
> [1] => soap_wsdl Object ( [_XMLSchema] => Array ( [0] =>
> ) [_XMLSchemaVersion] => http://www.w3.org/2001/XMLSchema [_typemap] =>
> float [duration] => integer [dateTime] => string [time] => string [date]
> => string [gYearMonth] => integer [gYear] => integer [gMonthDay] =>
> integer [gDay] => integer [gMonth] => integer [hexBinary] => string
> [base64Binary] => string [normalizedString] => string [token] => string
> [language] => string [NMTOKEN] => string [NMTOKENS] => string [Name] =>
> string [NCName] => string [ID] => string [IDREF] => string [IDREFS] =>
> string [ENTITY] => string [ENTITIES] => string [integer] => integer
> [nonPositiveInteger] => integer [negativeInteger] => integer [long] =>
> integer [int] => integer [short] => integer [byte] => string
> [nonNegativeInteger] => integer [unsignedLong] => integer [unsignedInt]
> => integer [unsignedShort] => integer [unsignedByte] => integer
> [positiveInteger] => integer [anyType] => string [anyURI] => string
> [QName] => string ) [http://www.w3.org/1999/XMLSchema] => Array ( [i4]
> => integer [int] => integer [boolean] => boolean [string] => string
> [double] => float [float] => float [dateTime] => string [timeInstant] =>
> string [base64Binary] => string [base64] => string [ur-type] => string )
> string [array] => array [Array] => array [Struct] => array ) )
> => [_xmlEntities] => Array ( [&] => & [<] => < [>] => > ['] => &apos;
> ["] => " ) [_doconversion] => [__attachments] => Array ( ) [_wsdl] =>
> [_section5] => 1 [_auto_translation] => [_type_translation] => Array ( )
> [_debug_flag] => [_debug_data] => [_encodings] => Array ( [0] =>
> ISO-8859-1 [1] => US-ASCII [2] => UTF-8 ) [_myfaultcode] => WSDL [fault]
> => soap_fault Object ( [error_message_prefix] => [mode] => 1 [level] =>
> [userinfo] =>
> => Array ( ) [messages] => Array ( ) [portTypes] => Array ( ) [bindings]
> => Array ( ) [imports] => Array ( ) [services] => Array ( ) [service] =>
> [uri] =>
> [cacheMaxAge] => 43200 [wsdlParserClass] => SOAP_WSDL_Parser ) [2] => )
> ) [6] => Array ( [file] => /usr/share/pear/SOAP/WSDL.php [line] => 125
> [function] => parseurl [class] => soap_wsdl [type] => -> [args] => Array
> ( [0] =>
> ) [7] => Array ( [file] => /healthcare/demo/lib/OHFSoapClient.php [line]
> => 38 [function] => soap_wsdl [class] => soap_wsdl [type] => -> [args]
> => Array ( [0] =>
> ) [8] => Array ( [file] => /healthcare/demo/lib/OHFSoapClient.php [line]
> => 25 [function] => initbridgeservice [class] => ohfsoapclient [type] =>
> -> [args] => Array ( ) ) [9] => Array ( [file] =>
> => ohfsoapclient [class] => ohfsoapclient [type] => -> [args] => Array (
> [0] => Array ( [user] => asas [password] => asas [facility] => ) [1] =>
> utils Object ( ) ) ) [10] => Array ( [file] =>
> => showrhiopanel [class] => ohfrhioconfigurations [type] => -> [args] =>
> [class] => ohfrhioconfigurations [type] => -> [args] => Array ( [0] =>
> Array ( [logout] => no [badlog] => no [getMyLog] => no [reset_rhio] =>
> no [search_patient] => no [add_patient_form] => no [search_doc_by_id] =>
> no [search_doc_by_details] => no [search_doc_do_search] => no
> => [sendDocument] => no [useFQS] => off [user] => asas [password] =>
> asas [facility] => ) [1] => Array ( [user] => asas [password] => asas
> work anymore for IBM Almaden Research Center (according to Google ;-)).
> Demo OHF Bridge not maintained anymore?
> Kind regards
> Michael Sprinzl
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #44223 is a reply to message #44127] Mon, 21 July 2008 03:48 Go to previous messageGo to next message
Hi Sarah,
any updates regarding the status of the OHF Bridge? I just tried again it
noticed that it still seems to be down...
Kind regards
Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #44370 is a reply to message #44223] Mon, 21 July 2008 11:30 Go to previous messageGo to next message
Hi Michael,
Sorry for the delay - I'm away on business. I'll have my colleague dig
into this when he returns from vacation on WEds. Sorry for the delay.
- Sarah
> Hi Sarah,
> it noticed that it still seems to be down...
> Kind regards
> Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #44710 is a reply to message #44370] Thu, 24 July 2008 14:06 Go to previous message
Michael,
Sorry for the delay in my response. We've pretty much stopped updating
this OHF Bridge installation due to the fact the server is quite
unreliable and combined with the fact that users of the OHF Bridge must
use it in their local environment at Connectathon. Sorry for the
references to the site in our documentation, we haven't been very
diligent in our updates of docs :)
As for running it in your local environment, it's very straightforward
to download and run locally. See:
http://www.eclipse.org/ohf/components/bridge/install.php
-Matt
Sarah Knoop wrote:
> Hi Michael,
> - Sarah
>> Hi Sarah,
>> Kind regards
>> Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #585989 is a reply to message #44056] Wed, 16 July 2008 18:56 Go to previous message
Hi Micheal -
or something.
- Sarah
> Hi everyone!
> [userinfo] =>
> retrieve WSDL
> [1] =>
> Array ( [0] =>
> [userinfo] =>
> [uri] =>
> ( [0] =>
> => Array ( [0] =>
> Kind regards
> Michael Sprinzl
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #586034 is a reply to message #44127] Mon, 21 July 2008 03:48 Go to previous message
Hi Sarah,
Kind regards
Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #586112 is a reply to message #44223] Mon, 21 July 2008 11:30 Go to previous message
Hi Michael,
- Sarah
> Hi Sarah,
> Kind regards
> Michael
Re: Demo OHF Bridge at http://healthcare.almaden.ibm.com/demo/ down? [message #586266 is a reply to message #44370] Thu, 24 July 2008 14:06 Go to previous message
Michael,
-Matt
Sarah Knoop wrote:
> Hi Michael,
> - Sarah
>> Hi Sarah,
>> Kind regards
>> Michael
Previous Topic:Error parsing response from ebxmlrr
Next Topic:required runtiime jars?
Current Time: Sun Jul 13 23:12:23 EDT 2025
Powered by FUDForum. Page generated in 0.33216 seconds
