Home » Eclipse Projects » GEF » moving figures within figures
moving figures within figures [message #44026] Wed, 20 November 2002 21:22 Go to next message
Originally posted by: jayuen.alumni.uwaterloo.ca
Hi:
I am having a problem with figures that have children (i.e. figures to which
I have added figures).
I have an ellipse and I have added two polylines inside of it so the result
looks like a circle with an X inside it. When I drag and move the ellipse,
the ellipse moves but the lines that I have drawn inside don't move with it.
In fact, when I move my ellipse back to the it's original location, I can
see the children lines that I originally drew again! Currently I handle the
move doing something like this:
Point location = getGlyph().getLocation();
Dimension size = this.getFigure().getSize();
Rectangle rect = new Rectangle(location, size);
((GraphicalEditPart)getParent()).setLayoutConstraint(this, getFigure(),
rect);
However, when I step through the setLayoutConstraints method, I notice two
things.
1. The constraints of any child figures don't seem to be updated and,
2. A deprecated method called setConstraint is called.
I have tried setting a layout manager on my figure but it doesn't seem to do
anything. I was considering calling setConstraint of each of the figure's
children individually but I saw that the method was deprecated (I'm using
GEF 2.0.0). Any ideas?
Jason
Re: moving figures within figures [message #44057 is a reply to message #44026] Wed, 20 November 2002 21:43 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Polylines cannot be used with regular layoutManagers. The intended usage is
that you simply set the points, and the bounds update accordingly.
There are older posts on this type of stuff.
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:arhdqd$d15$1@rogue.oti.com...
> Hi:
which
result
ellipse,
it.
the
> rect);
> things.
do
> Jason
Re: moving figures within figures [message #44265 is a reply to message #44026] Thu, 21 November 2002 08:15 Go to previous messageGo to next message
changing layout constraints of editparts are performed by
LayoutEditPolicies. putting them to the location specified by constraints
are performed by layoutmanagers. policies can only be installed to
editparts, which means, what you set constraint(move) is editpart in
reality. of course the figure bound to this edit part is (protected void
refreshVisuals()) also set this constraint, which then laid out(moved) by
layoutmanager.
so, make a figure(a single figure, which is ellipse) with two children
figures(which are lines), then make this figure, figure of editpart, then it
will move correctly.
ozz
> Hi:
which
result
ellipse,
it.
the
> rect);
> things.
do
> Jason
Re: moving figures within figures [message #44548 is a reply to message #44265] Thu, 21 November 2002 11:35 Go to previous messageGo to next message
Thanks Oz, Randy:
After reading Randy' comments, I put some code to redraw the lines (i.e.
removing the lines and then adding two new ones) each time I move the parent
glyph. With this method, I am a little concerned that the continual
redrawing may introduce some lags if the glyph is moved around alot. When
I did some quick testing, the UI response was pretty snappy but I suspect
that this might not be the most elegant solution.
Creating new edit parts (as Oz has suggested), seems to be a more elegant
solution. However, would creating these extra "line" edit parts incur
significant overhead and bloat the program size if many of these glyphs were
to be drawn?
Thanks for your help,
Jason
"Ozgur Kurt" <ozgurkurt@hotmail.com> wrote in message
news:arik4m$187$1@rogue.oti.com...
> layoutmanager.
it
> ozz
> > Hi:
> which
> result
> ellipse,
> it.
can
> the
> > rect);
two
> > things.
to
> do
figure's
using
> > Thanks,
> > Jason
Re: moving figures within figures [message #44809 is a reply to message #44548] Fri, 22 November 2002 08:28 Go to previous message
you will draw three figures(not three editparts), one of them, which is
parent will be figure of edit part, there will be one editpart. if i were
you, i would go ahead and subclass figure to supply my paint method, and
paint ellipse and lines by myself... like the following code... i didn't
write painting method of course. it's easy...
public class EllipseLinesFigure
extends Figure
protected void paintFigure(Graphics g)
Rectangle rClient = getBounds();
Color color = BPMResources.clInputPort;
g.setBackgroundColor(color);
g.fillRectangle(rClient);
// g.setForegroundColor(FigureUtilities.lighter(color));
// g.drawLine(rClient.x, rClient.y, rClient.right(), rClient.y);
// g.drawLine(rClient.x, rClient.y, rClient.x, rClient.bottom());
// g.setForegroundColor(FigureUtilities.darker(color));
// g.drawLine(rClient.right(), rClient.y, rClient.right(),
rClient.bottom());
// g.drawLine(rClient.x, rClient.bottom(), rClient.right(),
rClient.bottom());
// rClient.crop( new Insets(1) );
rClient.bottom());
rClient.bottom());
// g.setForegroundColor(BPMResources.clBlack);
g.drawRectangle(rClient);
g.setFont(BPMResources.fnPortFont);
g.translate(bounds.x, bounds.y);
g.drawString(strLabel, 3, 1);
public Dimension getPreferredSize(int wHint, int hHint)
if(dText == null)
dText = FigureUtilities.getTextExtents(strLabel,
dText.height += 3;
dText.width += 5;
return dText;
i would recommend not care much about performance issues. if you do the
things in a correct way, you will not lose much performance, and further you
will have readible and elegant code.
news:arivp9$b1g$1@rogue.oti.com...
> Thanks Oz, Randy:
parent
When
were
> to be drawn?
> Jason
constraints
by
> > layoutmanager.
then
> it
> > ozz
> > > Hi:
> > which
> > result
> > ellipse,
with
> > it.
> can
handle
> > the
getFigure(),
> > > rect);
> two
> > > things.
> to
> > do
> figure's
> using
> > > Thanks,
> > > Jason
Previous Topic:[contribution] Hello Gef 1 released for GEF 1.0
Next Topic:Difference between LogicDiagramFactory and LogicTemplateFactory in logic editor example
Current Time: Fri Jul 18 00:36:11 EDT 2025
Powered by FUDForum. Page generated in 0.03874 seconds
