Re: 2.5 D update example [message #3850 is a reply to message #3843] |
Mon, 01 June 2009 14:22  |
Hi Miles,
On 2009-06-01 19:29:15 +0200, Miles Parker <milesparker@gmail.com> said:
>> http://metascapeabm.com/presentations/Eclipse3D.mov
Cool ;-) Frankly, I do not really understand what these boxes are doing
there, but it looks quite well.
> In this example, as you can see there are ony two faces being drawn for
> each cube, not the whole cube. I'm just using SolidCube here, and
> setting a color. Do I need to be specifiying a texture as well?
No, this is a GEF3D bug, actually I knew about that bug but then I did
forget it. I added a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278651
and fixed it (at least I hope so, otherwise change the bug report ;-)
). You would like to update org.eclipse.draw3d.shapes.SolidCube (rev.
146).
Jens
Re: 2.5 D update example [message #561732 is a reply to message #3843] |
Hi Miles,
146).
Jens
FUDForum. Page generated in 0.03367 seconds
