Home » Eclipse Projects » Eclipse 4 » Will UI auto adjust itself?
Will UI auto adjust itself? [message #362] Mon, 13 October 2008 03:47 Go to next message
Originally posted by: krzysztof.daniel.gmail.com
Hi everybody,
I mean that common used commands/items should present to the user in
more aggressive way and do not hide among other not so very often used
options.
Typically only 20% features makes 80% of work ;-).
Similar functionality exists in Windows (top used programs), in mail
clients (most contacted people) etc.
Why not to move that functionality to Eclipse UI?
I have opened a bug against Mylyn, but that is not in their scope...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247942
What do you think, e4 Team?
Christopher Daniel
<krzysztof_daniel somewhere at pl.ibm.com>
Rational Eclipse TSE
Re: Will UI auto adjust itself? [message #382 is a reply to message #362] Sun, 23 November 2008 11:49 Go to previous message
I guess you used the "dog food" that already does this in E3 to some
extent ?;-)
It's called Mylyn. Of course it has not been used to such extent by most
projects, but generally speaking what you see when you work in a
TaskContext with Mylyn is exactly that. Items you don't consider
important enough for your current task hide until you enable them again
or switch to another task.
Re: Will UI auto adjust itself? [message #560954 is a reply to message #362] Sun, 23 November 2008 11:49 Go to previous message
extent ?;-)
Previous Topic:Will app isolation be supported in one Workbench (like tabs in Chrome)?
Next Topic:What is e4?
Current Time: Tue Nov 18 09:24:00 EST 2025
Powered by FUDForum. Page generated in 0.03506 seconds
