Home » Newcomers » Newcomers » Does Eclipse come with a SDK?
Does Eclipse come with a SDK? [message #43946] Thu, 31 March 2005 02:51 Go to next message
Originally posted by: tkangas.uslink.net
Do you have to install the j2sdk1.4.2_07 on your computer in order to use
Eclipse or does Eclipse come with it's own SDK?
Re: Does Eclipse come with a SDK? [message #43978 is a reply to message #43946] Thu, 31 March 2005 03:29 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
You have to install a Java SDK (see
http://www.eclipse.org/eclipse/faq/eclipse-faq.html#users_3)
HTH,
Csaba
Re: Does Eclipse come with a SDK? [message #44103 is a reply to message #43946] Thu, 31 March 2005 08:56 Go to previous message
Originally posted by: myersj.gmail.com
Strictly speaking, Eclipse only requires a JRE to run (with it's rt.jar
library to compile against, Eclipse provides its own compiler). But
it's better to install an SDK to have the java source code available
within Eclipse.
- Jeff
> use Eclipse or does Eclipse come with it's own SDK?
Previous Topic:where can i find the source code for eclipse 3.0 instead of api?
Next Topic:Creating .exe from Java code
Current Time: Sun Jul 13 14:36:19 EDT 2025
Powered by FUDForum. Page generated in 0.08546 seconds
