"Phantom" Selection [message #43932] |
Wed, 20 November 2002 10:56 |
i have a problem with the co-work of my connection creation tool and the
other creation tools that are activated from the palette. if i connect two
nodes, then i create another node(in the regular way, from the
palette...), and then i select a third node, the node that always gets
selected is the target node of the created link. the selection works right
after i finish the connection and works right if i create an object not
after connection creation, it works weird onl in this scenario, does
anyone have an idea what went wrong here?
thanks
yoav
FUDForum. Page generated in 0.47520 seconds
