Home » Archived » XML Schema Definition (XSD) » XMI 2.0 spec. questions
XMI 2.0 spec. questions [message #43917] |
Fri, 07 May 2004 09:29  |
Originally posted by: arno.leist.io-software.com
Hi all,
can someone explain the meaning of the <xsd:element ref='xmi:extension'
/> tag to me, which is included in every class content (see rule 4c in
the XMI 2.0 spec.), regardless whether the enclosing complex type is
derived or not?
Another point is, that I think the XMI 2.0 spec is not clear about how
attributes and compositions are inherited. On page 34 point 1.8.7 is
stated, that for attributes and compositions copy-down inheritance is
required. Contrarily is rule 4c on page 57, which states that only local
attributes, references, and compositions are included if the
org.omg.xmi.useSchemaExtensions is set to true.
What do you think about this?
Arno
Re: XMI 2.0 spec. questions [message #43948 is a reply to message #43917] |
Fri, 07 May 2004 10:01   |
Arno,
I'm not all that familiar with the details of the spec, but I'll explain
what I understand. The spec allows instances to contain <xmi:extension>
tags pretty much anywhere to act as extensions, so every schema for every
instance has to explicitly declare that these are allowed. Note that a
couple of weeks ago we added support to EMF's XMI resource implementation to
support these.
By using XML Schema's complex type <extension> support, it's possible to
model inheritance more accurately, but it sounds like that's an optional
thing. When it isn't used, you would need to duplicate all the content
model of the base type(s). When multiple inheritance is present,
<extension> can't adequately describe the model because XML Schema doesn't
support multiple inheritance.
In general, I think that XMI schemas do a poor job of describing the syntax.
They are too stylized and there are too many holes where they simply turn
validation off. You can't reconstruct a decent model from the XMI schema
alone...
Arno Leist wrote:
> Hi all,
> derived or not?
> Arno
Re: XMI 2.0 spec. questions [message #43979 is a reply to message #43948] |
Fri, 07 May 2004 11:20   |
See below...
Arno
Ed Merks wrote:
> Arno,
> support these.
I know that you have the possibility to decide between using the XSD
extension mechanism and copy-down inheritance, using the
org.omg.xmi.useSchemaExtensions tag. But if I don't misunderstand the
following part from page 34 of the spec, attributes and compositions
have to be inherited by copy-down inheritance, regardless of which way
you choose.
"XML schemas have a mechanism for extending types, but it does not
support extending
from more than one type, and using that mechanism imposes an order on
the content
models of the types that are derived from other types. Since XMI
attempts to minimize
order dependencies, XMI by default does not use schema extension to
represent
inheritance. In its place, XMI specifies that inheritance will be
copy-down inheritance.
For attributes and compositions, copy-down inheritance is required. For
associations
(AssociationEnds with references), the actual class referenced is used,
and subclasses
may be used on the other end of the reference."
And here is the contrary part of page 57:
"If
org.omg.xmi.useSchemaExtensions is false or not present, inherited
Attributes, References, and Compositions
are included; otherwise, only local Attributes, References, and
Compositions are included."
> alone...
Regarding my current understanding of this issue, I agree with you that
there is no decent way back from such a XSD.
> Arno Leist wrote:
>>Hi all,
>>derived or not?
>>Thanks,
>>Arno
Re: XMI 2.0 spec. questions [message #44010 is a reply to message #43979] |
Fri, 07 May 2004 11:40  |
Arno,
As I said, I'm not really an expert on the XMI schema spec, so it's best to ask
the folks responsible for that spec.
Arno Leist wrote:
> See below...
> Arno
> Ed Merks wrote:
> > Arno,
> > support these.
> you choose.
> support extending
> the content
> represent
> associations
> and subclasses
> "If
> > alone...
> > Arno Leist wrote:
> >>Hi all,
> >>derived or not?
> >>Thanks,
> >>Arno
Re: XMI 2.0 spec. questions [message #586853 is a reply to message #43917] |
Arno,
support these.
alone...
Arno Leist wrote:
> Hi all,
> derived or not?
> Arno
Re: XMI 2.0 spec. questions [message #586866 is a reply to message #43948] |
See below...
Arno
Ed Merks wrote:
> Arno,
> support these.
you choose.
support extending
the content
represent
associations
and subclasses
"If
> alone...
> Arno Leist wrote:
>>Hi all,
>>derived or not?
>>Thanks,
>>Arno
Re: XMI 2.0 spec. questions [message #586879 is a reply to message #43979] |
Arno,
Arno Leist wrote:
> See below...
> Arno
> Ed Merks wrote:
> > Arno,
> > support these.
> you choose.
> support extending
> the content
> represent
> associations
> and subclasses
> "If
> > alone...
> > Arno Leist wrote:
> >>Hi all,
> >>derived or not?
> >>Thanks,
> >>Arno
Current Time: Tue Jul 15 06:39:13 EDT 2025
Powered by FUDForum. Page generated in 0.05579 seconds
