Home » Modeling » TMF (Xtext) » [Xtext] Can any compare Xtext with TCS?
[Xtext] Can any compare Xtext with TCS? [message #43896] Sun, 17 May 2009 12:48 Go to next message
It seems that XText is quite similar to TCS in terms of functionality. If somebody can compare them two, I think it is better for newbies to have an overview of them.
Thanks.
Michael.
Re: [Xtext] Can any compare Xtext with TCS? [message #43992 is a reply to message #43896] Mon, 18 May 2009 05:36 Go to previous messageGo to next message
Michael,
I've used both TCS and Xtext, although I'm more familiar with Xtext.
First
the technical differences.
I find TCS more complete for defining a closed DSL; that is one that
does
not have in-built primitives or use import clauses. It also within the
grammar
of the language definition allows the definition of the language objects
that
create scope and the language objects that are added to the current scope.
This means that it is possible to create many DSLs with the need to write
any code. However, if the generated implementation of a DSL does not
perform as you need, it is not easy to modify.
Xtext is probably better for non-closed DSLs; i.e. ones that have
primitive
types and use import clauses. It is also has mechanisms designed to permit
the customisation the generated implementation; in my view, the use of
dependency injection and adapters means that it is not always obvious as
to how the customisation code has to interact with the generated code. As I
see it, the main drawback of Xtext is that it assumes that a resource is a
flat
namespace. Hence, if a DSL has any scope concepts, it is necessary to
write customisation code.
Now for the non-technical comparison. The activity in this news group
appears to show that TCS is no longer under active development or support.
The source, for example, has not been accessible in an Eclipse repository
for almost a year. Hence, for any new project, I would recommend that you
only consider Xtext.
Andy.
"Michael" <my25@macs.hw.ac.uk> wrote in message
news:gupf5g$ul0$1@build.eclipse.org...
> Thanks.
> Michael.
Re: [Xtext] Can any compare Xtext with TCS? [message #44023 is a reply to message #43992] Mon, 18 May 2009 08:06 Go to previous messageGo to next message
Andy Carpenter wrote:
> Michael,
> First
> does
> grammar
> that
> primitive
> flat
> Andy.
>> Thanks.
>> Michael.
Hi Andy:
Thanks, it is very useful for me. I tried to make TCS work in my Eclipse IDE for about one week but still failed.
I think it is wise for me to turn to Xtext. According to the documentation of XText, it has a kind of metamodel inference mechanism
which generates ecore metamodel based on grammar definition. However, I have already composed the ecore metamodel of my DSL,
hence I do not want to adopt the metamodel inference mechanism. Could Xtext handle this situation well?
Thanks again.
Michael.
Re: [Xtext] Can any compare Xtext with TCS? [message #44054 is a reply to message #44023] Mon, 18 May 2009 09:24 Go to previous messageGo to next message
Hi Michael,
Xtext is perfectly ok with existing Metamodels. Please have a look at
the reference documentation at
http://wiki.eclipse.org/Xtext/Documentation#EPackage_import
However, please make sure, that your EPackage is valid according to the
EMF validation.
If you have any further questions about Xtext, feel free to ask them in
the newsgroup. We'll be glad to help you with any problem that occurs.
Btw: If may want to download the distro from
http://oaw.itemis.com/openarchitectureware/language=en/2837/ downloads as
a jump start.
Sebastian
Am 18.05.2009 14:06 Uhr, schrieb Michael:
>> Michael,
>> First
>> I find TCS more complete for defining a closed DSL; that is one that does
>> grammar
>> objects that
>> scope.
>> primitive
>> permit
>> As I
>> is a flat
>> support.
>> Andy.
>>> Hi,
>>> Thanks.
>>> Michael.
> Hi Andy:
> Thanks again.
> Michael.
Re: [Xtext] Can any compare Xtext with TCS? [message #44215 is a reply to message #44054] Mon, 18 May 2009 13:57 Go to previous messageGo to next message
Hi, Sebastian:
I am still in the stage of teh preliminary study of Xtert. I would like to incorporate a model injector and extractor into a standalone ATL tranformation application.
So my question is whether Xtext can generate them based on the grammar specification of the concerned DSL. If so, are they handy to be incorporated in the standalone
ATL transformation application?
You help is highly appreciated.
Regards.
Michael.
> Hi Michael,
> EMF validation.
> a jump start.
> Sebastian
>>> Michael,
>>> First
>>> does
>>> grammar
>>> objects that
>>> scope.
>>> write
>>> primitive
>>> permit
>>> As I
>>> is a flat
>>> support.
>>> repository
>>> you
>>> Andy.
>>>> Hi,
>>>> Thanks.
>>>> Michael.
>> Hi Andy:
>> Thanks again.
>> Michael.
Re: [Xtext] Can any compare Xtext with TCS? [message #44245 is a reply to message #44215] Mon, 18 May 2009 14:28 Go to previous messageGo to next message
Hi Michael,
I (and I guess the same is true for Sebastian) don't know the
ATL-specific concepts, but as far as I could find out in ATL (TCS)
an injector is a parser and
an extractor is a generator/pretty printer/serializer.
If that is coorect, I guess the answer is 'yes'. As long as you have a
valid complete Xtext grammar of your language.
I also don't know whether it is convenient to use them in the context of
ATL (but would be interested top learn), but if ATL works with EMF
Resources (I guess so) it should be straight forward.
Xtext provides you with an implementation of an EMF Resource, where the
load uses the parser and the save uses the serializer.
For the serializer (unlike TCS) the pretty-printing information is
declared outside the grammar (documentation for that aspect will be
available soon).
Hope that helps,
Sven
Michael schrieb:
> Hi, Sebastian:
> Regards.
> Michael.
>> Hi Michael,
>> the EMF validation.
>> in the newsgroup. We'll be glad to help you with any problem that occurs.
>> as a jump start.
>> Regards,
>> Sebastian
>>>> Michael,
>>>> First
>>>> does
>>>> grammar
>>>> objects that
>>>> scope.
>>>> write
>>>> primitive
>>>> permit
>>>> obvious as
>>>> As I
>>>> is a flat
>>>> support.
>>>> repository
>>>> that you
>>>> Andy.
>>>>> Hi,
>>>>> Thanks.
>>>>> Michael.
>>> Hi Andy:
>>> Thanks again.
>>> Michael.
Re: [Xtext] Can any compare Xtext with TCS? [message #44719 is a reply to message #44245] Wed, 20 May 2009 10:33 Go to previous messageGo to next message
Snip
> available soon).
Is any draft documentation on controlling the formatting
available, or hints on where it is configured? At the moment
I'm getting all of my text on a single line.
Andy.
Re: [Xtext] Can any compare Xtext with TCS? [message #44853 is a reply to message #44719] Fri, 22 May 2009 13:44 Go to previous message
Formatting is one of the few things where we'll have late changes /
fixes. Expect working formatting and correpsonding documentation by RC3
(two weeks).
Sven
Andy Carpenter schrieb:
> Snip
>> available soon).
> Andy.
Previous Topic:[XText] Possibility to read the order of a node
Next Topic:importing subpackages of external ecore models
Current Time: Thu Jul 17 20:41:46 EDT 2025
Powered by FUDForum. Page generated in 0.07327 seconds
