Home » Eclipse Projects » GEF » some question about connections....
some question about connections.... [message #43873] |
Wed, 20 November 2002 11:04  |
hi all,
i'm just a bit confused(again!) about connection creation(and deletion of
course)...
i have a part which has connections, but when this part gets deleted
connections just becomes mess and don't get deleted. i looked at 'logic' but
couldn't find how this is performed.
and further question, i couldn't find out how to include this deletion(if
there is a command than it's easy, but i couldn't find that command) in
undo-redo stuff...
i know these questions sounds silly, any help is appreciated,
ozgur
Re: some question about connections.... [message #43966 is a reply to message #43873] |
Wed, 20 November 2002 13:22   |
Originally posted by: hudsonr.us.eye-bee-em.com
The best thing to do is to handle the deletion of connection in the same
command that deletes the node.
So, this becomes a model problem, and not a problem that EditPolicies can
help you with.
The reason you should do it this was is because the Outline Tree does not
display connection edit parts, and therefore they cannot contribute. The
logic example is being re-worked.
-randy
"Ozgur Kurt" <ozgurkurt@hotmail.com> wrote in message
news:arg9mg$ndt$1@rogue.oti.com...
> hi all,
> course)...
but
> undo-redo stuff...
> ozgur
Re: some question about connections.... [message #44179 is a reply to message #43966] |
Thu, 21 November 2002 04:42   |
Hi Randy,
Sorry I didn't understand this. i'm looking at logic sample, i open a new
file with 4bits adder sample, i select the led at the bottom, and
connections are deleted correctly, i click 'undo' and then they are restored
correctly. in which part of logic sample this functionality is achieved?
thanx,
ozgur
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:arghps$th6$1@rogue.oti.com...
> help you with.
> -randy
> > hi all,
of
> > course)...
> but
deletion(if
> > undo-redo stuff...
> > ozgur
Re: some question about connections.... [message #44235 is a reply to message #44208] |
Thu, 21 November 2002 05:36   |
silvia,
thank you for your intention. i know about commands. the thing i couldn't
find is, (the mechanism working behind the scenes). just could you please
tell me exactly where is deleting of connections performed(like
Class.method()) and which commands are invoked, i mean the name of class.
there is only one deletecommand in logic, and this not invoked except for
the deleted part itself. but sure some commands are invoked to delete
connections, because when i undo, they come back, which means they are in
commandstack, which also means they are commands.
thanx,
ozz
"Silvia de Beer" <debeer@ri.silicomp.fr> wrote in message
news:3DDCB5D9.4030105@ri.silicomp.fr...
> Look at the .model package and the Command classes. You will find the
> execute member functions, and the corresponding undo and redo functions.
> They work on the model, and correctly delete editParts with their Wires.
> Hope this helps,
> Silvia
> Ozgur Kurt wrote:
> > Hi Randy,
new
restored
> > thanx,
> > ozgur
can
> >>help you with.
not
> >>-randy
> >>>hi all,
> > of
> >>>course)...
'logic'
> >>but
> > deletion(if
> >>>undo-redo stuff...
> >>>ozgur
Re: some question about connections.... [message #44360 is a reply to message #44179] |
Thu, 21 November 2002 09:56   |
I'm saying that the way the logic example does it is not correct right now.
The code that is in LogicTreeNodeEditPolicy will move into the Logic's
DeleteCommand. The DeleteCommand that deletes a node is responsible for
finding all affected connections, and also deleting them.
In general, it is not safe to assume that you can walk EditParts and reach
everything in the model. The viewer may not display some items, like
connections. Or, the User may be able to invoke filters.
news:ari7ld$pjg$1@rogue.oti.com...
> Hi Randy,
restored
> thanx,
> ozgur
can
> > help you with.
not
> > -randy
> > > hi all,
> of
> > > course)...
'logic'
> > but
> deletion(if
in
> > > undo-redo stuff...
> > > ozgur
Re: some question about connections.... [message #44391 is a reply to message #44360] |
Thu, 21 November 2002 10:38  |
now i got what you mean, in this case best place would be
ComponentEditPolicy descendant.... i'll do this there...
thanx
ozgur
news:ariq1q$628$1@rogue.oti.com...
now.
> > Hi Randy,
new
> restored
> > thanx,
> > ozgur
same
> can
> > > help you with.
> not
The
> > > -randy
> > > > hi all,
deletion
> > of
> > > > course)...
> 'logic'
> > > but
> > deletion(if
> in
> > > > undo-redo stuff...
> > > > ozgur
Current Time: Wed Jul 16 19:22:16 EDT 2025
Powered by FUDForum. Page generated in 0.04177 seconds
