Home » Language IDEs » C / C++ IDE (CDT) » Source C editor behavior
Source C editor behavior [message #43854] Sun, 06 October 2002 00:52 Go to next message
Originally posted by: mgareil.hotmail.com
I just downloaded and installed the latest version of CDT (build 20021002)
on the eclipse 2.01 (build 20020920) on a Windows XP Pro.
I could create a new C/C++ project and started to write new source C when at
the second line of code, the C editor started to write right to left instead
of left to write.
when I typed printf I got ftnirp. I cleared all the text from the editor and
started again. For the very first line of C, the editor behaves normally nut
not for the following lines I tried to write.
Is it a special command to insert a new line in this C source file editor ?
Any idea on how to get a normal behavior for the whole source file ?
____________________________________________________________ ______
Michel GAREIL ICQ#: 12644559 Current ICQ status: + More ways to contact me i
See more about me:
Re: Source C editor behavior [message #44013 is a reply to message #43854] Mon, 07 October 2002 11:11 Go to previous messageGo to next message
Hi Michel,
I am very sorry to hear of your editor troubles. These types of things are
*very* frustrating. Unfortunately, I have not heard of any problems like
this.
There are no specfic commands to insert text in the editor.
I expect that you have already tried the usual (shutdown and restarted
Eclipse, checked the logfile)
Could you delete or rename your log file and restart Eclipse. Attempt to
edit again and see if there are any entries. If there are please post them
here.
-Judy
"Michel GAREIL" <mgareil@hotmail.com> wrote in message
news:anoe8h$nc$1@rogue.oti.com...
| Hi,
instead
| of left to write.
and
nut
i
| See more about me:
Re: Source C editor behavior [message #44044 is a reply to message #44013] Mon, 07 October 2002 22:13 Go to previous messageGo to next message
Originally posted by: perlwhiz.yahoo.com
On Mon, 7 Oct 2002 11:11:47 -0400, "Judy N. Green" <jgreen@qnx.com>
>this.
Just FYI, I installed Eclipse on my W2K machine last night, and CDT
about 15 minutes ago, and I'm getting the same behavior as Michel.
I'll try to delete the log file as you suggest.
Dave
Re: Source C editor behavior [message #44075 is a reply to message #44044] Tue, 08 October 2002 07:43 Go to previous messageGo to next message
Hi, July
Of course I tried to shutdown and restart eclipse ... but also I reinstalled
from scratch eclipse to make sure there is no remanent file from an
incorrect installation.
For the log file, I can't find any log, could you tell me more on where I
can find such file ?
Thank's for your help
"Dave Terry" <perlwhiz@yahoo.com> wrote in message
news:bmf4qukrv59hj8b114h926ke25fmjonfuj@4ax.com...
are
> >this.
> Dave
Re: Source C editor behavior [message #44104 is a reply to message #44075] Tue, 08 October 2002 10:10 Go to previous messageGo to next message
news:anuf0i$vso$1@rogue.oti.com...
| Hi, Judy
reinstalled
The log file is found in your workspace/.metadata/.log
Thanks for bringing this to our attention.
-Judy
| are
like
| > >this.
| > Dave
Re: Source C editor behavior [message #44134 is a reply to message #44075] Tue, 08 October 2002 10:39 Go to previous messageGo to next message
For me, it appears to only be happening with the 09/20 build of Eclipse.
At work (also on W2K), I had downloaded the 08/29 build and installed CDT,
and it works fine.
If I have time today, I'll try to download a newer build and see how that
goes.
Dave
Re: Source C editor behavior [message #44195 is a reply to message #44134] Tue, 08 October 2002 12:45 Go to previous messageGo to next message
I have noticed some instability with the editors in 09/20 build of Eclipse.
Since the CDT editors directly extend the JDT editor, we often suffer from
the same issues.
Have you noticed editor problems being reported in the eclipse.tools
newsgroup?
news:anuqmg$920$1@rogue.oti.com...
| and it works fine.
| goes.
Thanks for taking the time to check this out.
-Judy
| Dave
Re: Source C editor behavior [message #44256 is a reply to message #44195] Tue, 08 October 2002 12:47 Go to previous messageGo to next message
Hi, Judy
I catched the .log file I have many ArrayIndewOutOfBoundExceptions like the
one below :
!SESSION oct. 06, 2002
06:32:16.124 --------------------------------------------
java.version=1.4.1
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86 -data
c:\mgeclipse -install file:C:/eclipse/
!ENTRY org.eclipse.ui 4 4 oct. 06, 2002 06:32:16.134
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 oct. 06, 2002 06:32:16.164
!MESSAGE 1000
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 1000
org.eclipse.cdt.internal.ui.text.BufferedDocumentScanner.rea d(BufferedDocume
ntScanner.java:105)
org.eclipse.cdt.internal.ui.text.FastCPartitionScanner.nextT oken(FastCPartit
ionScanner.java:91)
org.eclipse.jface.text.rules.DefaultPartitioner.documentChan ged2(DefaultPart
itioner.java:303)
org.eclipse.jface.text.AbstractDocument.updateDocumentStruct ures(AbstractDoc
ument.java:509)
org.eclipse.jface.text.AbstractDocument.fireDocumentChanged( AbstractDocument
..java:531)
org.eclipse.jface.text.AbstractDocument.replace(AbstractDocu ment.java:841)
org.eclipse.jface.text.DocumentAdapter.replaceTextRange(Docu mentAdapter.java
:162)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.j ava:5446)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.ja va:6287)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java: 2470)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java: 4760)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.j ava:4787)
at org.eclipse.swt.custom.StyledText$8.handleEvent(StyledText.j ava:4551)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1622)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1368)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1256)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1239)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
"Judy N. Green" <jgreen@qnx.com> wrote in message
news:anv0c3$d92$1@rogue.oti.com...
Eclipse.
> the same issues.
> newsgroup?
CDT,
> | and it works fine.
that
> | goes.
> -Judy
> | Dave
Re: Source C editor behavior [message #44286 is a reply to message #44195] Wed, 09 October 2002 00:38 Go to previous messageGo to next message
On Tue, 8 Oct 2002 12:45:44 -0400, "Judy N. Green" <jgreen@qnx.com>
>the same issues.
Now that I'm back home with my 9/20 build, I notice that it doesn't
happen in a Java Perspective. That is, I can write, build and run a
"Hello World" type program with no problem in Java, but not C++.
Could I have installed it incorrectly? I just unzipped the CDT zipfile
into my Eclipse directory. When Eclipse started, it asked if I wanted
to execute the changes, to which I said "yes" and it restarted the
program. (I didn't see any errors.) Is that the standard procedure?
>newsgroup?
I haven't looked there yet, but I'll be checking it out tomorrow.
Hopefully Michel posting his log file will help as well.
Dave
Re: Source C editor behavior [message #44348 is a reply to message #44256] Wed, 09 October 2002 10:56 Go to previous messageGo to next message
Hi Michel,
thanks for the log file. I think we have some idea of what is going on, but
would you be able to provide a testcase that you use to reproduce it (e.g. a
file that you open and/or a particular sequence of keys)?
Sebastien
news:anv0rg$dhe$1@rogue.oti.com...
> Hi, Judy
the
> one below :
> java.version=1.4.1
> !MESSAGE 1000
> !STACK 0
> at
> ntScanner.java:105)
> at
> ionScanner.java:91)
> at
> itioner.java:303)
> at
> ument.java:509)
> at
> .java:531)
> at
> at
> :162)
> at
> a:775)
> at
> at
> .java:25)
> Regards
> Eclipse.
from
> > the same issues.
> > newsgroup?
Eclipse.
> CDT,
> > | and it works fine.
> that
> > | goes.
> > -Judy
> > | Dave
Re: Source C editor behavior [message #44379 is a reply to message #44348] Wed, 09 October 2002 10:10 Go to previous messageGo to next message
Hi Sebastien,
Although your message is addresses to Michel, I can tell you that the only
thing I have to do to cause the problem is to move from the first line of
the editor to the second.
That is, if I open a new text file and start typing, everything on the
first line is okay. Then, I hit Enter to move the cursor to the second
line, and everything I type from the first character onward is displayed
right-to-left, no matter what I do.
Dave
Re: Source C editor behavior [message #44469 is a reply to message #44286] Wed, 09 October 2002 16:00 Go to previous messageGo to next message
news:5ac7qucv2dlp7vr6g1knnqn89ebrcfbmor@4ax.com...
Eclipse.
from
| >the same issues.
It sounds like you have it installed correctly.
I'll look into this today.
-Judy
| >newsgroup?
| Thanks,
| Dave
Re: Source C editor behavior [message #44493 is a reply to message #44379] Wed, 09 October 2002 16:52 Go to previous messageGo to next message
Hi folks,
I just downloaded and installed (build 20021002) of CDT)
on a clean eclipse 2.01 (build 20020920) on a Windows 2K
I do not get this problem at all with a hello world type example.
Can you forward a copy of what you were trying to type.
The exception is in code that will throw an array index out of bounds but I
need to know what the data was that caused it.
-Judy
news:ao1dcr$qt3$1@rogue.oti.com...
(e.g. a
| Hi Sebastien,
| Dave
Re: Source C editor behavior [message #44617 is a reply to message #44493] Thu, 10 October 2002 12:56 Go to previous messageGo to next message
Alright then ...
We have finally reproduced this problem!
It only happens with the eclipse 2.01 (build 20020920) or newer.
If you roll back to an older version of Eclipse ... until we post a patch ..
you will still be able to work with the CDT.
Logged as Bug # 24648 against the CDT UI
-Judy
news:ao235j$aau$1@rogue.oti.com...
| Hi folks,
I
| Thanks
| -Judy
| (e.g. a
| | Hi Sebastien,
only
of
| | Dave
Re: Source C editor behavior [message #44647 is a reply to message #44617] Thu, 10 October 2002 12:33 Go to previous messageGo to next message
> Alright then ...
Great!
I'm wondering why it didn't happen for you yesterday, though (when you
posted about installing the 20020920 build on W2K, and couldn't get that
behavior). Did you have to do anything special to make it happen?
Re: Source C editor behavior [message #44678 is a reply to message #44647] Thu, 10 October 2002 13:36 Go to previous messageGo to next message
After I double checked, I realized that I had used a different Eclipse
build. I had double clicked on the wrong SDK :(
I just checked used Eclipse 20020920 build on W2K with the latest CDT build
200210101131 and I do see the same behaviour.
Something has changed as of Eclipse build 20020920 that is breaking our CDT
builds.
Hummmm ... very interesting.
If you create a project and attempt to edit a new file you get the described
behaviour. If you reopen Eclipse you can edit the previously created file
with no obvious problems. You still get the aberant behaviour on any *newly*
created files.
Thanks ... looking into it ....
-Judy
news:ao4a4o$8bh$1@rogue.oti.com...
| > Alright then ...
| Great!
Re: Source C editor behavior [message #44708 is a reply to message #44678] Thu, 10 October 2002 13:53 Go to previous messageGo to next message
> created files.
Not so in my case. :-)
When I exit Eclipse and restart, I still get the same behavior when
editing the file that I created in my previous Eclipse session.
Re: Source C editor behavior [message #44728 is a reply to message #44708] Thu, 10 October 2002 15:21 Go to previous messageGo to next message
A fix has been submitted and will be included in the next build.
-Judy
news:ao4eqq$bhl$1@rogue.oti.com...
*newly*
| > created files.
Re: Source C editor behavior [message #44791 is a reply to message #44728] Thu, 10 October 2002 17:11 Go to previous messageGo to next message
Sorry to confuse this issue further, but...
Is the "2.01 (build 20020920)" that we're referring to the same as the 2.1.0 M1
stable build on eclipse.org's download page? I can't seem to find a 9/20 build
of 2.0.1 (which I'm assuming is the same as "2.01"), and the last CVS tag I can
find for 2.0.1 was "v20020911".
So, I installed the 2.0.1 release build (8/29) today under Win2k, and checked
out the latest CVS version of the CDT (most likely after the fix for bug #24648
had been committed). It appears to exhibit similar character-reversal behavior
to that described in this thread.
I then installed the M1 stable build (9/20, which I believe is version 2.1.0).
I again checked out the latest CVS version of the CDT, and it appears to have
solved the character-reversal problem.
Is the current CDT for 2.0.1 or 2.1.0? Is there a 20020920 build for 2.0.1? Am
I just off in left field?
I'm easily confused, so be gentle. :-)
Brian
> -Judy
> *newly*
> | > created files.
Re: Source C editor behavior [message #45198 is a reply to message #44791] Tue, 15 October 2002 12:53 Go to previous messageGo to next message
HI Brian,
You are right on the money and not so confused after all.
Here is a copy of the emial I sent to the mailing list this morning.
The CDT team *officially* support the *Stable* Eclipse version Eclipse
2.0.1 - Aug 29, 2002
FYI
There have been changes in Eclipse UI between the Aug 29 build and the M1
build on 20 September, that have caused problems with our C editor.
The fix that was posted will only work with Eclipse newer than 20 September,
which we do not currently support. This fix will be rolled back today and
the PR re-opened until we move forward to Eclipse 2.0.1 when it is declared
stable.
In other words ...
Eclipse 2.0.1 build # < 13 September + original CDT editor code (no fix) ==
WORKS
Eclipse 2.0.1 build # > 20 September + patched CDT editor code == WORKS (but
will be rolled back)
NOTE!!!
Eclipse 2.0.1 build # < 13 September + patched CDT editor code == DOES NOT
WORK
Eclipse 2.0.1 build # > 20 September (M1) + original CDT editor code (no
fix) == DOES NOT WORK
DOES NOT WORK == backwards typing in C View editor as reported in the PR
against the M1 build with the older (unpatched) CDT code.
Sorry for the confuson that has ensued.
-Judy
Re: Source C editor behavior [message #45320 is a reply to message #45198] Tue, 15 October 2002 16:52 Go to previous messageGo to next message
(aka, "how to bead a dead horse...")
Did you mean "2.1.0" for the (M1) version numbers sited below (e.g., the "> 20
September" builds?), or is M1 really a milestone release for 2.0.1 development?
Brian
> WORKS
> NOTE!!!
> WORK
Re: Source C editor behavior [message #45584 is a reply to message #45320] Thu, 17 October 2002 10:48 Go to previous messageGo to next message
Hi Brian,
"Brian Moyle" <bmoyle@mvista.com> wrote in message
news:3DAC8025.1070000@mvista.com...
"> 20
development?
The Eclipse M1 is dated 20 September and is listed as Stable Build on the
2.1 stream
Sorry for any confusion.
-Judy
| Brian
| > WORKS
(but
| > NOTE!!!
NOT
| > WORK
Re: Source C editor behavior [message #45705 is a reply to message #45584] Thu, 17 October 2002 13:32 Go to previous messageGo to next message
Thank you!
As mentioned in a previous message, I'm easily confused... so I just wanted to
make sure I'm on the right page.
Brian
> Hi Brian,
> "> 20
> development?
> 2.1 stream
> -Judy
Re: Source C editor behavior [message #45734 is a reply to message #44013] Thu, 17 October 2002 18:37 Go to previous messageGo to next message
Originally posted by: hongming.cs.utexas.edu
I also got this annoying behavior in my Eclipse after doing a find/replace
past the end of file. I tried to delete eclipse\workspace\.metadata\.log
and then restart Eclipse but that didn't solve the problem.
Yeh Hong-ming
Department of Computer Sciences
University of Texas at Austin
news:ans6h2$n8q$1@rogue.oti.com...
> Hi Michel,
> this.
> here.
> Thanks
> -Judy
> | Hi,
20021002)
when
> at
> instead
> | of left to write.
> and
> nut
editor
me
> i
> | See more about me:
Re: Source C editor behavior [message #45854 is a reply to message #45734] Fri, 18 October 2002 11:34 Go to previous messageGo to next message
Hi Yeh,
Which version of Eclipse were you using (build number) and which version of
the CDT?
-Judy
"Yeh Hong-ming" <hongming@cs.utexas.edu> wrote in message
news:aoncgi$lts$1@rogue.oti.com...
| Yeh Hong-ming
| > Hi Michel,
are
| > this.
them
| > here.
| > Thanks
| > -Judy
| > | Hi,
| 20021002)
| when
| > at
| > instead
| > | of left to write.
editor
| > and
normally
| > nut
| editor
contact
| me
| > i
| > | See more about me:
Re: Source C editor behavior [message #47662 is a reply to message #43854] Mon, 28 October 2002 13:10 Go to previous messageGo to next message
I just tried Eclipse I20021023 with CDT F3-Candidate (2002/10/22),
Linux-Motif. It typed backwards.
Yeh Hong-ming
The University of Texas at Austin
Re: Source C editor behavior [message #47691 is a reply to message #47662] Mon, 28 October 2002 14:57 Go to previous messageGo to next message
Per Judy's comments dated 10/15/2002 in this same news thread:
"The CDT team *officially* support the *Stable* Eclipse version Eclipse
2.0.1 - Aug 29, 2002"
Try that release instead.
Brian
> Yeh Hong-ming
Re: Source C editor behavior [message #47750 is a reply to message #47691] Mon, 28 October 2002 17:16 Go to previous messageGo to next message
Originally posted by: ijmuiden.pointbreak.biz
Yes, either that, or use the F2 release (which I believe contains the now
removed patch). That should work with newer releases of the Eclipse
workbench.
Gerjon
"Brian Moyle" <bmoyle@mvista.com> schreef in bericht
news:3DBD96A3.2030901@mvista.com...
> Brian
> > Yeh Hong-ming
Re: Source C editor behavior [message #50100 is a reply to message #43854] Thu, 14 November 2002 07:11 Go to previous messageGo to next message
I still have the same behavior of C/C++ editor with eclipse 2.01 and the CDT
build of the 11/11/2002
Is it planed to be corrected with the next stable eclipse package ?
Thanks for your help
instead
> of left to write.
and
nut
i
> See more about me:
Re: Source C editor behavior [message #50451 is a reply to message #50100] Sun, 17 November 2002 01:38 Go to previous messageGo to next message
I tried the eclipse M3 version (15/Nov/2002) with the latest cdt build
(14/Nov/2002) and the editor is still typing backward after the first line
of a c/cpp source file.
I'm running eclipse on a Windows XP Pro.
Below please find the very first lines of the log file of eclipse, may be it
will help.
======================= beginning of the eclipse log file ===========
!SESSION nov. 17, 2002
07:28:41.942 --------------------------------------------
java.version=1.4.1
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/eclipse/
!ENTRY org.eclipse.ui 4 4 nov. 17, 2002 07:28:41.942
!ENTRY org.eclipse.ui 4 0 nov. 17, 2002 07:28:41.952
!MESSAGE 1000
!STACK 0
ntScanner.java:105)
ionScanner.java:91)
itioner.java:256)
ument.java:507)
..java:529)
org.eclipse.jface.text.AbstractDocument.replace(AbstractDocu ment.java:839)
:162)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.j ava:5621)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.ja va:6545)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java: 2652)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java: 5007)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.j ava:5030)
at org.eclipse.swt.custom.StyledText$8.handleEvent(StyledText.j ava:4800)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:825)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1435)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1418)
a:831)
..java:25)
!ENTRY org.eclipse.ui 4 4 nov. 17, 2002 07:28:42.02
!ENTRY org.eclipse.ui 4 0 nov. 17, 2002 07:28:42.12
!MESSAGE 1000
!STACK 0
ntScanner.java:105)
ionScanner.java:91)
itioner.java:256)
ument.java:507)
..java:529)
:162)
a:831)
..java:25)
!ENTRY org.eclipse.ui 4 4 nov. 17, 2002 07:28:42.112
!ENTRY org.eclipse.ui 4 0 nov. 17, 2002 07:28:42.132
!MESSAGE 1000
!STACK 0
ntScanner.java:105)
ionScanner.java:91)
itioner.java:256)
ument.java:507)
..java:529)
:162)
a:831)
..java:25)
!ENTRY org.eclipse.ui 4 4 nov. 17, 2002 07:28:42.272
!ENTRY org.eclipse.ui 4 0 nov. 17, 2002 07:28:42.292
!MESSAGE 1000
!STACK 0
ntScanner.java:105)
ionScanner.java:91)
itioner.java:256)
ument.java:507)
..java:529)
:162)
a:831)
..java:25)
news:ar01ri$n2u$1@rogue.oti.com...
CDT
> > Hi,
20021002)
when
> at
> instead
> > of left to write.
> and
> nut
editor
me
> i
> > See more about me:
Re: Source C editor behavior [message #50645 is a reply to message #50451] Mon, 18 November 2002 16:02 Go to previous messageGo to next message
news:ar7be0$s6c$1@rogue.oti.com...
| Hello,
Eclipse M3 is a 2.1 based version.
The cdt is only supporting the 2.0.1 and soon 2.0.2 versions of Eclipse.
The fix for typing backwards in the Eclipse 2.1 stream (M1 etc) will not be
released until we make the move to support the 2.1 version of Eclipse.
-Judy
| java.version=1.4.1
| file:C:/eclipse/
| !MESSAGE 1000
| !STACK 0
| at
| ntScanner.java:105)
| at
| ionScanner.java:91)
| at
| itioner.java:256)
| at
| ument.java:507)
| at
| .java:529)
| at
| at
| :162)
| at
| a:831)
| at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
| at
| at
| .java:25)
| !MESSAGE 1000
| !STACK 0
| at
| ntScanner.java:105)
| at
| ionScanner.java:91)
| at
| itioner.java:256)
| at
| ument.java:507)
| at
| .java:529)
| at
| at
| :162)
| at
| a:831)
| at
| at
| .java:25)
| !MESSAGE 1000
| !STACK 0
| at
| ntScanner.java:105)
| at
| ionScanner.java:91)
| at
| itioner.java:256)
| at
| ument.java:507)
| at
| .java:529)
| at
| at
| :162)
| at
| a:831)
| at
| at
| .java:25)
| !MESSAGE 1000
| !STACK 0
| at
| ntScanner.java:105)
| at
| ionScanner.java:91)
| at
| itioner.java:256)
| at
| ument.java:507)
| at
| .java:529)
| at
| at
| :162)
| at
| a:831)
| at
| at
| .java:25)
| > Hi,
| CDT
| > > Hi,
| 20021002)
| when
| > at
| > instead
| > > of left to write.
editor
| > and
normally
| > nut
| editor
contact
| me
| > i
| > > See more about me:
Re: Source C editor behavior [message #51855 is a reply to message #50645] Mon, 25 November 2002 08:32 Go to previous messageGo to next message
Originally posted by: robert.varga.fathomtechnology.com
When can we expect that move to support 2.1 to happen?
Maybe some of us would be willing to use the fix as a patch provided as is
without support, if it would not break too much things and would not be too
hard to incorporate.
It could also be considered as a means of testing that :-)
Robert Varga
news:arbhr9$u3e$1@rogue.oti.com...
> | Hello,
line
be
> -Judy
> | java.version=1.4.1
> | file:C:/eclipse/
> | !MESSAGE 1000
> | !STACK 0
> | at
> | ntScanner.java:105)
> | at
> | ionScanner.java:91)
> | at
> | itioner.java:256)
> | at
> | ument.java:507)
> | at
> | .java:529)
> | at
> | at
> | :162)
> | at
> | at
> | at
> | at
> | a:831)
> | at
> | at
> | .java:25)
> | !MESSAGE 1000
> | !STACK 0
> | at
> | ntScanner.java:105)
> | at
> | ionScanner.java:91)
> | at
> | itioner.java:256)
> | at
> | ument.java:507)
> | at
> | .java:529)
> | at
> | at
> | :162)
> | at
> | at
> | at
> | at
> | a:831)
> | at
> | at
> | .java:25)
> | !MESSAGE 1000
> | !STACK 0
> | at
> | ntScanner.java:105)
> | at
> | ionScanner.java:91)
> | at
> | itioner.java:256)
> | at
> | ument.java:507)
> | at
> | .java:529)
> | at
> | at
> | :162)
> | at
> | at
> | at
> | at
> | a:831)
> | at
> | at
> | .java:25)
> | !MESSAGE 1000
> | !STACK 0
> | at
> | ntScanner.java:105)
> | at
> | ionScanner.java:91)
> | at
> | itioner.java:256)
> | at
> | ument.java:507)
> | at
> | .java:529)
> | at
> | at
> | :162)
> | at
> | at
> | at
> | at
> | a:831)
> | at
> | at
> | .java:25)
> | > Hi,
the
> | CDT
> | > > Hi,
> | 20021002)
> | when
> | > at
> | > instead
> | > > of left to write.
> editor
> | > and
> normally
> | > nut
> | editor
> contact
> | me
> | > i
> | > > See more about me:
Re: Source C editor behavior [message #51985 is a reply to message #51855] Mon, 25 November 2002 16:27 Go to previous messageGo to next message
"Robert Varga" <robert.varga@fathomtechnology.com> wrote in message
news:art8ob$nv8$1@rogue.oti.com...
| Hello,
too
Hi Robert,
Thanks for the offer. The problem is that there may be many more things that
come up when we run with Eclipse 2.1.
I do not want to open a can of worms that we are not ready to manage.
If you really really want to fix this problem and use Eclipse 2.1. You are
welcome to check out the CDT code, rollback to the fix (mentioned in another
thread) and build the CDT from within Eclipse (instructions on the CDT
website). You can then install the resulting plugins and features at your
own risk.
Yes it would eb a great way of testing when we are ready to do so.
Thanks for your offer.
-Judy
| Regards,
| Robert Varga
| > | Hello,
| line
| be
| > -Judy
| > | java.version=1.4.1
| > | file:C:/eclipse/
| > | !MESSAGE 1000
| > | !STACK 0
| > | at
| > | ntScanner.java:105)
| > | at
| > | ionScanner.java:91)
| > | at
| > | itioner.java:256)
| > | at
| > | ument.java:507)
| > | at
| > | .java:529)
| > | at
| > | at
| > | :162)
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | a:831)
| > | at
| > | at
| > | .java:25)
| > | !MESSAGE 1000
| > | !STACK 0
| > | at
| > | ntScanner.java:105)
| > | at
| > | ionScanner.java:91)
| > | at
| > | itioner.java:256)
| > | at
| > | ument.java:507)
| > | at
| > | .java:529)
| > | at
| > | at
| > | :162)
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | a:831)
| > | at
| > | at
| > | .java:25)
| > | !MESSAGE 1000
| > | !STACK 0
| > | at
| > | ntScanner.java:105)
| > | at
| > | ionScanner.java:91)
| > | at
| > | itioner.java:256)
| > | at
| > | ument.java:507)
| > | at
| > | .java:529)
| > | at
| > | at
| > | :162)
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | a:831)
| > | at
| > | at
| > | .java:25)
| > | !MESSAGE 1000
| > | !STACK 0
| > | at
| > | ntScanner.java:105)
| > | at
| > | ionScanner.java:91)
| > | at
| > | itioner.java:256)
| > | at
| > | ument.java:507)
| > | at
| > | .java:529)
| > | at
| > | at
| > | :162)
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | at
| > | a:831)
| > | at
| > | at
| > | .java:25)
| > | > Hi,
| the
| > | CDT
| > | > > Hi,
| > | 20021002)
C
| > | when
| > | > at
left
| > | > instead
| > | > > of left to write.
| > editor
| > | > and
| > normally
| > | > nut
| > | editor
| > contact
| > | me
| > | > i
| > | > > See more about me:
Re: Source C editor behavior [message #52795 is a reply to message #51985] Sat, 30 November 2002 04:20 Go to previous messageGo to next message
Originally posted by: james.keeley.tfn.com
Hello Judy,
It appears that if one substitutes an instance of the
BufferedRuleBasedScanner for the BufferedDocumentScanner in
org.eclipse.cdt.internal.ui.text.FastCPartitionScanner, all is well.
Haven't had too much time to investigate beyond at this point, but suspect
the differences in their respective read() methods is the culprit.
James
news:aru44b$akk$1@rogue.oti.com...
> | Hello,
is
> too
> Hi Robert,
that
another
> own risk.
> -Judy
> | Regards,
> | Robert Varga
> | > | Hello,
build
first
> | line
Eclipse.
not
> | be
> | > -Judy
> | > | java.version=1.4.1
> | > | file:C:/eclipse/
> | > | !MESSAGE 1000
> | > | !STACK 0
> | > | at
> | > | ntScanner.java:105)
> | > | at
> | > | ionScanner.java:91)
> | > | at
> | > | itioner.java:256)
> | > | at
> | > | ument.java:507)
> | > | at
> | > | .java:529)
> | > | at
> | > | at
> | > | :162)
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | a:831)
> | > | at
> | > | at
> | > | .java:25)
> | > | !MESSAGE 1000
> | > | !STACK 0
> | > | at
> | > | ntScanner.java:105)
> | > | at
> | > | ionScanner.java:91)
> | > | at
> | > | itioner.java:256)
> | > | at
> | > | ument.java:507)
> | > | at
> | > | .java:529)
> | > | at
> | > | at
> | > | :162)
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | a:831)
> | > | at
> | > | at
> | > | .java:25)
> | > | !MESSAGE 1000
> | > | !STACK 0
> | > | at
> | > | ntScanner.java:105)
> | > | at
> | > | ionScanner.java:91)
> | > | at
> | > | itioner.java:256)
> | > | at
> | > | ument.java:507)
> | > | at
> | > | .java:529)
> | > | at
> | > | at
> | > | :162)
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | a:831)
> | > | at
> | > | at
> | > | .java:25)
> | > | !MESSAGE 1000
> | > | !STACK 0
> | > | at
> | > | ntScanner.java:105)
> | > | at
> | > | ionScanner.java:91)
> | > | at
> | > | itioner.java:256)
> | > | at
> | > | ument.java:507)
> | > | at
> | > | .java:529)
> | > | at
> | > | at
> | > | :162)
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | at
> | > | a:831)
> | > | at
> | > | at
> | > | .java:25)
> | > | > Hi,
and
> | the
> | > | CDT
> | > | > > Hi,
> | > | 20021002)
source
> C
> | > | when
> | > | > at
> left
> | > | > instead
> | > | > > of left to write.
the
> | > editor
> | > | > and
> | > normally
> | > | > nut
file
> | > | editor
file
> | > contact
> | > | me
> | > | > i
> | > | > > See more about me:
Re: Source C editor behavior [message #52906 is a reply to message #52795] Sat, 30 November 2002 20:50 Go to previous messageGo to next message
"james keeley" <james.keeley@tfn.com> wrote in message
news:as9vq0$3fg$1@rogue.oti.com...
> Hello Judy,
Thanks for looking into this. I'll look at it this week.
Thanks again
-Judy
> James
> > | Hello,
as
> is
be
> > too
> > Hi Robert,
> that
are
> another
your
> > own risk.
> > -Judy
> > | Regards,
> > | Robert Varga
> > | > | Hello,
> build
> first
> > | line
> Eclipse.
> not
> > | be
Eclipse.
> > | > -Judy
> > | > | java.version=1.4.1
> > | > | file:C:/eclipse/
> > | > | !MESSAGE 1000
> > | > | !STACK 0
> > | > | at
> > | > | ntScanner.java:105)
> > | > | at
> > | > | ionScanner.java:91)
> > | > | at
> > | > | itioner.java:256)
> > | > | at
> > | > | ument.java:507)
> > | > | at
> > | > | .java:529)
> > | > | at
> > | > | at
> > | > | :162)
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | a:831)
> > | > | at
> > | > | at
> > | > | .java:25)
> > | > | !MESSAGE 1000
> > | > | !STACK 0
> > | > | at
> > | > | ntScanner.java:105)
> > | > | at
> > | > | ionScanner.java:91)
> > | > | at
> > | > | itioner.java:256)
> > | > | at
> > | > | ument.java:507)
> > | > | at
> > | > | .java:529)
> > | > | at
> > | > | at
> > | > | :162)
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | a:831)
> > | > | at
> > | > | at
> > | > | .java:25)
> > | > | !MESSAGE 1000
> > | > | !STACK 0
> > | > | at
> > | > | ntScanner.java:105)
> > | > | at
> > | > | ionScanner.java:91)
> > | > | at
> > | > | itioner.java:256)
> > | > | at
> > | > | ument.java:507)
> > | > | at
> > | > | .java:529)
> > | > | at
> > | > | at
> > | > | :162)
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | a:831)
> > | > | at
> > | > | at
> > | > | .java:25)
> > | > | !MESSAGE 1000
> > | > | !STACK 0
> > | > | at
> > | > | ntScanner.java:105)
> > | > | at
> > | > | ionScanner.java:91)
> > | > | at
> > | > | itioner.java:256)
> > | > | at
> > | > | ument.java:507)
> > | > | at
> > | > | .java:529)
> > | > | at
> > | > | at
> > | > | :162)
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | at
> > | > | a:831)
> > | > | at
> > | > | at
> > | > | .java:25)
> > | > | > Hi,
> and
> > | the
> > | > | CDT
package
> > | > | > > Hi,
(build
> > | > | 20021002)
> source
> > C
> > | > | when
> > | > | > at
to
> > left
> > | > | > instead
> > | > | > > of left to write.
> the
> > | > editor
> > | > | > and
behaves
> > | > normally
> > | > | > nut
> file
> > | > | editor
> file
to
> > | > contact
> > | > | me
> > | > | > i
> > | > | > > See more about me:
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.423 / Virus Database: 238 - Release Date: 11/25/02
Re: Source C editor behavior [message #53356 is a reply to message #52906] Sun, 08 December 2002 14:54 Go to previous messageGo to next message
Hi Judy,
Been away for a bit, so just getting caught up. Any news on this one?
Regs,
James
> > Hello Judy,
> Thanks again
> -Judy
> > Regards,
> > James
> > > | Hello,
> as
> > is
> be
> > > too
> > > Hi Robert,
> > that
> are
> > another
> your
> > > own risk.
> > > -Judy
> > > | Regards,
> > > | Robert Varga
> > > | > | Hello,
> > build
> > first
> > > | line
> > Eclipse.
> > not
> > > | be
> Eclipse.
> > > | > -Judy
> > > | > | java.version=1.4.1
> > > | > | file:C:/eclipse/
> > > | > | !MESSAGE 1000
> > > | > | !STACK 0
> > > | > | at
> > > | > | ntScanner.java:105)
> > > | > | at
> > > | > | ionScanner.java:91)
> > > | > | at
> > > | > | itioner.java:256)
> > > | > | at
> > > | > | ument.java:507)
> > > | > | at
> > > | > | .java:529)
> > > | > | at
> > > | > | at
> > > | > | :162)
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | a:831)
> > > | > | at
> > > | > | at
> > > | > | .java:25)
> > > | > | !MESSAGE 1000
> > > | > | !STACK 0
> > > | > | at
> > > | > | ntScanner.java:105)
> > > | > | at
> > > | > | ionScanner.java:91)
> > > | > | at
> > > | > | itioner.java:256)
> > > | > | at
> > > | > | ument.java:507)
> > > | > | at
> > > | > | .java:529)
> > > | > | at
> > > | > | at
> > > | > | :162)
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | a:831)
> > > | > | at
> > > | > | at
> > > | > | .java:25)
> > > | > | !MESSAGE 1000
> > > | > | !STACK 0
> > > | > | at
> > > | > | ntScanner.java:105)
> > > | > | at
> > > | > | ionScanner.java:91)
> > > | > | at
> > > | > | itioner.java:256)
> > > | > | at
> > > | > | ument.java:507)
> > > | > | at
> > > | > | .java:529)
> > > | > | at
> > > | > | at
> > > | > | :162)
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | a:831)
> > > | > | at
> > > | > | at
> > > | > | .java:25)
> > > | > | !MESSAGE 1000
> > > | > | !STACK 0
> > > | > | at
> > > | > | ntScanner.java:105)
> > > | > | at
> > > | > | ionScanner.java:91)
> > > | > | at
> > > | > | itioner.java:256)
> > > | > | at
> > > | > | ument.java:507)
> > > | > | at
> > > | > | .java:529)
> > > | > | at
> > > | > | at
> > > | > | :162)
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | at
> > > | > | a:831)
> > > | > | at
> > > | > | at
> > > | > | .java:25)
> > > | > | > Hi,
> > and
> > > | the
> > > | > | CDT
> package
> > > | > | > > Hi,
> (build
> > > | > | 20021002)
> > source
> > > C
> > > | > | when
> > > | > | > at
> to
> > > left
> > > | > | > instead
> > > | > | > > of left to write.
> > the
> > > | > editor
> > > | > | > and
> behaves
> > > | > normally
> > > | > | > nut
> > file
> > > | > | editor
> > file
> to
> > > | > contact
> > > | > | me
> > > | > | > i
> > > | > | > > See more about me:
Re: Source C editor behavior [message #53407 is a reply to message #53356] Mon, 09 December 2002 12:55 Go to previous messageGo to next message
news:1103_1039377259@www.eclipse.org...
| Hi Judy,
Hi James,
Nothing yet ... it is on my list ;)
-Judy
| Regs,
| James
| > > Hello Judy,
suspect
| > Thanks again
| > -Judy
| > > Regards,
| > > James
| > > > | Hello,
provided
| > as
| > > is
not
| > be
| > > > too
| > > > Hi Robert,
things
| > > that
manage.
You
| > are
| > > another
CDT
| > your
| > > > own risk.
| > > > -Judy
| > > > | Regards,
| > > > | Robert Varga
| > > > | > | Hello,
cdt
| > > build
the
| > > first
| > > > | line
| > > Eclipse.
will
| > > not
| > > > | be
| > Eclipse.
| > > > | > -Judy
| > > > | > | java.version=1.4.1
| > > > | > | file:C:/eclipse/
| > > > | > | !MESSAGE 1000
| > > > | > | !STACK 0
| > > > | > | at
| > > > | > | ntScanner.java:105)
| > > > | > | at
| > > > | > | ionScanner.java:91)
| > > > | > | at
| > > > | > | itioner.java:256)
| > > > | > | at
| > > > | > | ument.java:507)
| > > > | > | at
| > > > | > | .java:529)
| > > > | > | at
| > > > | > | at
| > > > | > | :162)
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | a:831)
Method)
| > > > | > | at
| > > > | > | at
| > > > | > | .java:25)
| > > > | > | !MESSAGE 1000
| > > > | > | !STACK 0
| > > > | > | at
| > > > | > | ntScanner.java:105)
| > > > | > | at
| > > > | > | ionScanner.java:91)
| > > > | > | at
| > > > | > | itioner.java:256)
| > > > | > | at
| > > > | > | ument.java:507)
| > > > | > | at
| > > > | > | .java:529)
| > > > | > | at
| > > > | > | at
| > > > | > | :162)
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | a:831)
Method)
| > > > | > | at
| > > > | > | at
| > > > | > | .java:25)
| > > > | > | !MESSAGE 1000
| > > > | > | !STACK 0
| > > > | > | at
| > > > | > | ntScanner.java:105)
| > > > | > | at
| > > > | > | ionScanner.java:91)
| > > > | > | at
| > > > | > | itioner.java:256)
| > > > | > | at
| > > > | > | ument.java:507)
| > > > | > | at
| > > > | > | .java:529)
| > > > | > | at
| > > > | > | at
| > > > | > | :162)
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | a:831)
Method)
| > > > | > | at
| > > > | > | at
| > > > | > | .java:25)
| > > > | > | !MESSAGE 1000
| > > > | > | !STACK 0
| > > > | > | at
| > > > | > | ntScanner.java:105)
| > > > | > | at
| > > > | > | ionScanner.java:91)
| > > > | > | at
| > > > | > | itioner.java:256)
| > > > | > | at
| > > > | > | ument.java:507)
| > > > | > | at
| > > > | > | .java:529)
| > > > | > | at
| > > > | > | at
| > > > | > | :162)
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | at
| > > > | > | a:831)
Method)
| > > > | > | at
| > > > | > | at
| > > > | > | .java:25)
| > > > | > | > Hi,
2.01
| > > and
| > > > | the
| > > > | > | CDT
| > package
| > > > | > | > > Hi,
| > (build
| > > > | > | 20021002)
new
| > > source
| > > > C
| > > > | > | when
| > > > | > | > at
right
| > to
| > > > left
| > > > | > | > instead
| > > > | > | > > of left to write.
from
| > > the
| > > > | > editor
| > > > | > | > and
| > behaves
| > > > | > normally
| > > > | > | > nut
source
| > > file
| > > > | > | editor
source
| > > file
ways
| > to
| > > > | > contact
| > > > | > | me
| > > > | > | > i
| > > > | > | > > See more about me:
Re: Source C editor behavior [message #53461 is a reply to message #53407] Mon, 09 December 2002 18:37 Go to previous messageGo to next message
Cheers. No worries.
news:at2kj1$6sr$1@rogue.oti.com...
> | Hi Judy,
> Hi James,
> -Judy
<in the interest of brevity...snip>
Re: Source C editor behavior [message #53726 is a reply to message #53407] Wed, 11 December 2002 06:53 Go to previous messageGo to next message
Actually Judy, adding the following conditional before the final return
statement in org.eclipse.cdt.internal.ui.text.BufferedDocumentReader.read ()
will do the trick as well:
if (fOffset >= fRangeLength) {
fOffset++;
return EOF;
> | Hi Judy,
> Hi James,
> -Judy
> | Regs,
> | James
> | > > Hello Judy,
> suspect
> | > Thanks again
> | > -Judy
> | > > Regards,
> | > > James
message
> | > > > | Hello,
> provided
> | > as
> | > > is
> not
> | > be
> | > > > too
> | > > > Hi Robert,
> things
> | > > that
> manage.
> You
> | > are
in
> | > > another
> CDT
> | > your
> | > > > own risk.
> | > > > -Judy
> | > > > | Regards,
> | > > > | Robert Varga
> | > > > | > | Hello,
> cdt
> | > > build
> the
> | > > first
> | > > > | line
of
> | > > Eclipse.
etc)
> will
> | > > not
> | > > > | be
> | > Eclipse.
> | > > > | > -Judy
> | > > > | > | java.version=1.4.1
x86 -install
> | > > > | > | file:C:/eclipse/
> | > > > | > | !MESSAGE 1000
> | > > > | > | !STACK 0
> | > > > | > | at
> | > > > | > | ntScanner.java:105)
> | > > > | > | at
> | > > > | > | ionScanner.java:91)
> | > > > | > | at
> | > > > | > | itioner.java:256)
> | > > > | > | at
> | > > > | > | ument.java:507)
> | > > > | > | at
> | > > > | > | .java:529)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | :162)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | a:831)
> | > > > | > | at
> Method)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | .java:25)
> | > > > | > | !MESSAGE 1000
> | > > > | > | !STACK 0
> | > > > | > | at
> | > > > | > | ntScanner.java:105)
> | > > > | > | at
> | > > > | > | ionScanner.java:91)
> | > > > | > | at
> | > > > | > | itioner.java:256)
> | > > > | > | at
> | > > > | > | ument.java:507)
> | > > > | > | at
> | > > > | > | .java:529)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | :162)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | a:831)
> | > > > | > | at
> Method)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | .java:25)
> | > > > | > | !MESSAGE 1000
> | > > > | > | !STACK 0
> | > > > | > | at
> | > > > | > | ntScanner.java:105)
> | > > > | > | at
> | > > > | > | ionScanner.java:91)
> | > > > | > | at
> | > > > | > | itioner.java:256)
> | > > > | > | at
> | > > > | > | ument.java:507)
> | > > > | > | at
> | > > > | > | .java:529)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | :162)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | a:831)
> | > > > | > | at
> Method)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | .java:25)
> | > > > | > | !MESSAGE 1000
> | > > > | > | !STACK 0
> | > > > | > | at
> | > > > | > | ntScanner.java:105)
> | > > > | > | at
> | > > > | > | ionScanner.java:91)
> | > > > | > | at
> | > > > | > | itioner.java:256)
> | > > > | > | at
> | > > > | > | ument.java:507)
> | > > > | > | at
> | > > > | > | .java:529)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | :162)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | at
> | > > > | > | a:831)
> | > > > | > | at
> Method)
> | > > > | > | at
> | > > > | > | at
> | > > > | > | .java:25)
> | > > > | > | > Hi,
eclipse
> 2.01
> | > > and
> | > > > | the
> | > > > | > | CDT
> | > package
> | > > > | > | > > Hi,
CDT
> | > (build
> | > > > | > | 20021002)
Pro.
> new
> | > > source
> | > > > C
> | > > > | > | when
> | > > > | > | > at
> right
> | > to
> | > > > left
> | > > > | > | > instead
> | > > > | > | > > of left to write.
> from
> | > > the
> | > > > | > editor
> | > > > | > | > and
> | > behaves
> | > > > | > normally
> | > > > | > | > nut
> source
> | > > file
> | > > > | > | editor
> source
> | > > file
> ways
> | > to
> | > > > | > contact
> | > > > | > | me
> | > > > | > | > i
> | > > > | > | > > See more about me:
Re: Source C editor behavior [message #54025 is a reply to message #53726] Thu, 12 December 2002 17:12 Go to previous message
Hi all,
This issue has been resolved and the fix is in the *nightly* build just
posted to the downloads page.
Thanks for all you patience and suggestions.
-Judy
news:at78m0$s5m$1@rogue.oti.com...
| statement in
| fOffset++;
| return EOF;
| > | Hi Judy,
| > Hi James,
| > -Judy
| > | Regs,
| > | James
| > | > > Hello Judy,
well.
| > suspect
| > | > Thanks again
| > | > -Judy
| > | > > Regards,
| > | > > James
| message
| > | > > > | Hello,
| > provided
| > | > as
| > | > > is
would
| > not
| > | > be
| > | > > > too
| > | > > > Hi Robert,
| > things
| > | > > that
| > manage.
2.1.
| > You
| > | > are
(mentioned
| in
| > | > > another
the
| > CDT
features
| at
| > | > your
| > | > > > own risk.
so.
| > | > > > -Judy
| > | > > > | Regards,
| > | > > > | Robert Varga
| > | > > > | > | Hello,
latest
| > cdt
| > | > > build
after
| > the
| > | > > first
| > | > > > | line
| of
| > | > > Eclipse.
| etc)
| > will
| > | > > not
| > | > > > | be
of
| > | > Eclipse.
| > | > > > | > -Judy
| > | > > > | > | java.version=1.4.1
NL=fr_FR
| x86 -install
| > | > > > | > | file:C:/eclipse/
| > | > > > | > | !MESSAGE 1000
| > | > > > | > | !STACK 0
| > | > > > | > | at
| > | > > > | > | ntScanner.java:105)
| > | > > > | > | at
| > | > > > | > | ionScanner.java:91)
| > | > > > | > | at
| > | > > > | > | itioner.java:256)
| > | > > > | > | at
| > | > > > | > | ument.java:507)
| > | > > > | > | at
| > | > > > | > | .java:529)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | :162)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | a:831)
| > | > > > | > | at
| > Method)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | .java:25)
| > | > > > | > | !MESSAGE 1000
| > | > > > | > | !STACK 0
| > | > > > | > | at
| > | > > > | > | ntScanner.java:105)
| > | > > > | > | at
| > | > > > | > | ionScanner.java:91)
| > | > > > | > | at
| > | > > > | > | itioner.java:256)
| > | > > > | > | at
| > | > > > | > | ument.java:507)
| > | > > > | > | at
| > | > > > | > | .java:529)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | :162)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | a:831)
| > | > > > | > | at
| > Method)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | .java:25)
| > | > > > | > | !MESSAGE 1000
| > | > > > | > | !STACK 0
| > | > > > | > | at
| > | > > > | > | ntScanner.java:105)
| > | > > > | > | at
| > | > > > | > | ionScanner.java:91)
| > | > > > | > | at
| > | > > > | > | itioner.java:256)
| > | > > > | > | at
| > | > > > | > | ument.java:507)
| > | > > > | > | at
| > | > > > | > | .java:529)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | :162)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | a:831)
| > | > > > | > | at
| > Method)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | .java:25)
| > | > > > | > | !MESSAGE 1000
| > | > > > | > | !STACK 0
| > | > > > | > | at
| > | > > > | > | ntScanner.java:105)
| > | > > > | > | at
| > | > > > | > | ionScanner.java:91)
| > | > > > | > | at
| > | > > > | > | itioner.java:256)
| > | > > > | > | at
| > | > > > | > | ument.java:507)
| > | > > > | > | at
| > | > > > | > | .java:529)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | :162)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | a:831)
| > | > > > | > | at
| > Method)
| > | > > > | > | at
| > | > > > | > | at
| > | > > > | > | .java:25)
| > | > > > | > | > Hi,
| eclipse
| > 2.01
| > | > > and
| > | > > > | the
| > | > > > | > | CDT
eclipse
| > | > package
| > | > > > | > | > > Hi,
| CDT
| > | > (build
| > | > > > | > | 20021002)
| Pro.
write
| > new
| > | > > source
| > | > > > C
| > | > > > | > | when
| > | > > > | > | > at
| > right
| > | > to
| > | > > > left
| > | > > > | > | > instead
| > | > > > | > | > > of left to write.
text
| > from
| > | > > the
| > | > > > | > editor
| > | > > > | > | > and
editor
| > | > behaves
| > | > > > | > normally
| > | > > > | > | > nut
| > source
| > | > > file
| > | > > > | > | editor
| > source
| > | > > file
More
| > ways
| > | > to
| > | > > > | > contact
| > | > > > | > | me
| > | > > > | > | > i
| > | > > > | > | > > See more about me:
Previous Topic:Multiple delets from CVS project
Next Topic:Nightly CDT builds gone?
Current Time: Tue Jul 15 07:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.38147 seconds
