SWT asyncExec() problem [message #436190] |
Wed, 12 May 2004 12:51 |
Originally posted by: whoops.ukrtop.com
I have two-thread application. One thread receive network data, parse it
and call GUI to redraw canvas. GUI updates are called throw
Display.asyncExec() function on every package receive form network. The
problem is that asyncExec() is not executed on first package, when
multiple packages are received.
It works good with syncExec(), it works even when I run it in debug more
step-by-step, it works if put Thread.sleep(10) after first package is
received, but not work with asyncExec()..
Here is code:
//this run in separate thread and do receive network packages
NetworkListener.java:
public void run()
while (true) {
System.out.println ("receive iteration");
protocol.recvPackage();
//this receive/parse packages and do asyncExec for GUI updates
NetworkProtocol.java:
public void recvPackage()
System.out.println ("before parser start");
gameListener.getDisplay().asyncExec(new Runnable()
public void run()
System.out.println ("parse package");
parsePackage (package_type, package_bufs, package_len);
//parse package function do calls for GUI redraw
System.out.println ("after parser start");
The console output is:
receive iteration
before parser start
after parser start
receive iteration
before parser start
parse package
after parser start
As you see there is no 'parse package' message after first 'receive
iteration'. Any suggestions how to fix it?
FUDForum. Page generated in 0.02903 seconds
