Problem with SWT_AWT [message #436081] |
Tue, 11 May 2004 09:40 |
Originally posted by: "prenom.,nom".sextant.thomson-csf.com
I embedded two Swing panels in an SWT_AWT Frame, but when I open the parent
shell, there's nothing into it. There's just the shell with its title. I tried
to do the same as the snippet.
Here's a part of my code:
Shell shell = new Shell(new Display(), SWT.DIALOG_TRIM);
Composite prefComposite = new Composite(shell, SWT.EMBEDDED);
Frame embeddedFrame = SWT_AWT.new_Frame(prefComposite);
embeddedFrame.setLayout(new BorderLayout());
.... // operations for the panels
embeddedFrame.add(pnlPrincipal, BorderLayout.CENTER);
embeddedFrame.add(pnlDisplay, BorderLayout.SOUTH);
shell.open();
while(!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
What can be the problem? Did I forget something? Is it a problem of layout? Does
the shell need a layout too?
Thank you in advance
Fabrice
Re: Problem with SWT_AWT [message #436084 is a reply to message #436082] |
Tue, 11 May 2004 11:07 |
Yes I tried to put a JPanel with a BorderLayout, but the result is the same. Did
you have a similar problem?
Henning Rogge a écrit :
> NOM Prenom wrote:
> > Hi,
> Have you tried to put a JPanel into the embedded Frame instead of using
> it directly ?
> Henning Rogge.
FUDForum. Page generated in 0.02766 seconds
