RCP Product export ... [message #435984] |
Sun, 28 August 2005 15:23  |
i've a big troubles with RCP Product Export ...
I've created a application which i want to distribute as standalone RCP, but
the problem is when i create product definition and try to export the
product with the export wizard it export only the icons and other things,
but it doesn't create the jar file for the plugin = application ?!
When i do create new workspace and create the product definition and all the
stuffs from scratch again, then it works but when i change something and try
it to export it again, then it doesn't work any more ...
I'm on Eclipse 3.1, has someone any idea ?
Peter
Re: RCP Product export ... [message #435988 is a reply to message #435984] |
Mon, 29 August 2005 01:15  |
Originally posted by: vsbabu.hotmail.com
There are many things to check here.
1) Open your plugin.xml and then look into "build" tab. You should see t=
he =
jar file there.
See the selection list named "Binary Build" -- add files and folders=
you need to be
included there. At a minimum, you will need to include the folders =
where your
class files are getting built, plugin.xml, icons and any splash scre=
en =
bmps.
2) Now go to "build.properties" tab. This should reflect what you select=
ed =
in step 1
under bin.includes. Also, check what is kept as source.yourjar and =
output.yourjar.
3) Make sure your project is actually getting built. If in doubt, go to =
Project menu
and uncheck "Build Automatically". Now do a "Clean" and then a "Buil=
d". =
Now you can
enable "Build Automatically".
4) Go to your product export configuration, synchronize and export.
I am a newbie to RCP, but these were some of the things I did to get my =
product working :-)
Babu
http://vsbabu.org/
On Mon, 29 Aug 2005 00:53:36 +0530, Peter <peter.daransky@roha.at> wrote=
> I've created a application which i want to distribute as standalone RC=
P, =
> but
> product with the export wizard it export only the icons and other thin=
gs,
> but it doesn't create the jar file for the plugin =3D application ?!
> When i do create new workspace and create the product definition and a=
ll =
> the
> stuffs from scratch again, then it works but when i change something a=
nd =
> try
> Thanks
> Peter
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.02128 seconds
