Home » Eclipse Projects » Remote Application Platform (RAP) » Installation problem
Installation problem [message #43719] Wed, 29 August 2007 03:32 Go to next message
Originally posted by: thomas.cataldo.aliasource.fr
When I try to install RAP M6 on top of a clean eclipse 3.3 linux gtk, my
eclipse can start up anymore. It always fail with the following
exception :
../eclipse
Exception in thread "Thread-2" java.lang.NullPointerException: You cannot parameterize a null parameter
at org.eclipse.core.commands.Parameterization.<init>(Parameterization.java:76)
at org.eclipse.ui.internal.ShowViewMenu.getCommand(ShowViewMenu .java:300)
at org.eclipse.ui.internal.ShowViewMenu.<init>(ShowViewMenu.java:123)
at org.eclipse.ui.internal.FastViewBar.<init>(FastViewBar.java:209)
at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContent s(WorkbenchWindow.java:1062)
at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefa ultContents(WorkbenchWindowConfigurer.java:624)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWind owContents(WorkbenchWindowAdvisor.java:268)
at org.eclipse.ui.internal.WorkbenchWindow.createContents(Workb enchWindow.java:974)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.ui.internal.Workbench$19.runWithException(Workbe nch.java:1010)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:797)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Any idea ?
Re: Installation problem [message #43902 is a reply to message #43719] Wed, 29 August 2007 05:29 Go to previous message
Originally posted by: b.muskalla.gmx.net
Hi Thomas,
you should carefully read the instructions on the download page. RAP is
distributed as a target platform and there should not be installed on
top of your existing Eclipse installation.
See http://www.eclipse.org/rap/downloads.php for more details.
Greets
Benny
Thomas Cataldo wrote:
> exception :
> ./eclipse
> Any idea ?
Previous Topic:Re: How to show a MessageDialog in a web browser when an event occoured in the backround thread
Next Topic:Custom widget
Current Time: Sat Jul 26 09:07:22 EDT 2025
Powered by FUDForum. Page generated in 0.02778 seconds
