Home » Archived » EPF » .project file and Clear Case
.project file and Clear Case [message #43678] Thu, 11 October 2007 11:29 Go to next message
Originally posted by: Sevon.Vanbebber.baesystems.com
I am in the middle of putting our existing Method Library into Clear Case
under CM and I was wondering if it's a good/bad idea to put the .project
file under CM as well.
Also, are there any ways around having the users responsible for the order
by which they check in and out the library.xmi, projects.xmi files, etc?
Sevon
Re: .project file and Clear Case [message #43721 is a reply to message #43678] Thu, 11 October 2007 13:16 Go to previous message
Originally posted by: storaskar.xx.xxx.xxx
It depends on which version of EPF you are using.
EPF 1.0 - We don't recommnd putting .project in CM.
EPF 1.2 - It doesn't matter.
I am not sure what you meant by order of files checking-in. If you are
checking in the library first time, order doesn't really matter as long as
whole library gets put in CM before someone tries to do checkout.
Shilpa Toraskar
EPF Committer
Re: .project file and Clear Case [message #584724 is a reply to message #43678] Thu, 11 October 2007 13:16 Go to previous message
Shilpa Toraskar
EPF Committer
Previous Topic:.project file and Clear Case
Next Topic:Problem: Renaming plugins to take advantage of hierarchical display
Current Time: Sat Aug 30 21:29:58 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
