.project file and Clear Case [message #43678] |
Thu, 11 October 2007 11:29  |
Originally posted by: Sevon.Vanbebber.baesystems.com
I am in the middle of putting our existing Method Library into Clear Case
under CM and I was wondering if it's a good/bad idea to put the .project
file under CM as well.
Also, are there any ways around having the users responsible for the order
by which they check in and out the library.xmi, projects.xmi files, etc?
Sevon
Re: .project file and Clear Case [message #43721 is a reply to message #43678] |
Thu, 11 October 2007 13:16  |
Originally posted by: storaskar.xx.xxx.xxx
It depends on which version of EPF you are using.
EPF 1.0 - We don't recommnd putting .project in CM.
EPF 1.2 - It doesn't matter.
I am not sure what you meant by order of files checking-in. If you are
checking in the library first time, order doesn't really matter as long as
whole library gets put in CM before someone tries to do checkout.
Shilpa Toraskar
EPF Committer
Re: .project file and Clear Case [message #584724 is a reply to message #43678] |
Shilpa Toraskar
EPF Committer
FUDForum. Page generated in 0.03003 seconds
