Home » Eclipse Projects » Technology Project and PMC » How do I upgrade from 2.0.2 to 2.1 M4?
How do I upgrade from 2.0.2 to 2.1 M4? [message #43670] Sun, 26 January 2003 16:34 Go to next message
Originally posted by: dinkloh.ipd.uni-karlsruhe.de
Hello!
How can I upgrade from Eclipse 2.0.2 to 2.1 M4? Is it enough just to unzip
the corresponding files into the eclipse directory? I would like to preserve
my settings, but as I understand it, those are in the .metadata subdirectory
under the workspace directory and therefore should not be affected by the
upgrade, is that right?
Thank you for the help,
Martin
Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #43762 is a reply to message #43670] Mon, 27 January 2003 14:16 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
Just unzipping the new archive over your old install might work, but I
wouldn't recommend it. You'd be better off deleting the old install and
unzipping the new one fresh.
If your workspace directory is in your Eclipse install location (the default
behavior, but not recommended), make sure to back it up first!
- Jared
> preserve my settings, but as I understand it, those are in the .metadata
> subdirectory under the workspace directory and therefore should not be
> affected by the upgrade, is that right?
Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #43789 is a reply to message #43762] Mon, 27 January 2003 17:59 Go to previous messageGo to next message
Originally posted by: oshteynbuk.nyc.rr.com
in addition to what Jared said you can also check out swiki
http://eclipsewiki.swiki.net/131
or/and
there is an ant script to update
http://home.nyc.rr.com/olegs/
oleg
"Jared Burns" <jared-eclipse@mn.rr.com> wrote in message
news:b13vc8$hhk$2@rogue.oti.com...
default
> - Jared
unzip
Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #49336 is a reply to message #43762] Tue, 18 March 2003 15:44 Go to previous message
Originally posted by: nospam.metaclass.nl
If you are building plugins, you may have to revise the class path and then
do "Organize Imports" to revise the import statements. (I tried to compile
the readmetool example version 2.0.2 with 2.1 M3, but got lots of errors,
all resulting from org.eclipse... classes being moved to differen packages.
Initally i missed some of the new packages in the class path, so "Organize
Imports" created import statements that import classes from javax.swing...
However after removing the errorneous import statements Eclipse was quite
quite good at finding where the classes had gone )
Henk Verhoeven,
MetaClass.
Jared Burns <jared-eclipse@mn.rr.com> wrote in message
default
> - Jared
unzip
Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #589456 is a reply to message #43670] Mon, 27 January 2003 14:16 Go to previous message
- Jared
Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #589469 is a reply to message #43762] Mon, 27 January 2003 17:59 Go to previous message
or/and
oleg
default
> - Jared
unzip
Re: How do I upgrade from 2.0.2 to 2.1 M4? [message #591692 is a reply to message #43762] Tue, 18 March 2003 15:44 Go to previous message
Henk Verhoeven,
MetaClass.
default
> - Jared
unzip
Previous Topic:Importing project into workspace from external plugin
Next Topic:How to make CVS browser not to show empty directories?
Current Time: Tue Jul 22 13:53:01 EDT 2025
Powered by FUDForum. Page generated in 0.04257 seconds
