Home » Archived » EPF » Problem: Renaming plugins to take advantage of hierarchical display
Problem: Renaming plugins to take advantage of hierarchical display [message #43649] Wed, 10 October 2007 20:53 Go to next message
I'm trying to rename some of my plugins to have them show in a heirarchy in
the Authoring perspective. E.g. Base_Category => Base.Category
When I rename the plugin, I get a "Problem Occurred" dialog:
"Performing CVS Edit (Time of error: ...)
"Reason:
"Resource '/project/Base_Category/workproducttypes/CVS' does not exist."
If I try renaming the plugin folder directly in CVS, I get a different error
when I open the project.
How do I rename a plugin that's under CVS control?
Re: Problem: Renaming plugins to take advantage of hierarchical display [message #43744 is a reply to message #43649] Thu, 11 October 2007 13:25 Go to previous message
Originally posted by: storaskar.xx.xxx.xxx
You can rename from library view by right clicking on plugin name and then
rename.
From the message you are getting, it looks like rename process tries to
change
references but that file probably doesn't exist. May be it wasn't
checked-in and it's missing ?
"Reason:
Direct rename of CVS folder in CVS won't work since EPF needs to change
the name references in xmi files of the library.
If you can provide more info like .log, which version you are using etc,
we could certainly help you further.
Shilpa Toraskar
Re: Problem: Renaming plugins to take advantage of hierarchical display [message #584744 is a reply to message #43649] Thu, 11 October 2007 13:25 Go to previous message
rename.
change
"Reason:
Shilpa Toraskar
Previous Topic:.project file and Clear Case
Next Topic:Problem with 1.2.0.1
Current Time: Mon Jul 21 21:26:29 EDT 2025
Powered by FUDForum. Page generated in 0.03075 seconds
