Home » Archived » XML Schema Definition (XSD) » More namespace help
More namespace help [message #43644] Wed, 05 May 2004 13:10 Go to next message
Ed,
More info on the problem I was having below... I'm not sure if the
schema location issue in the imports is related to this issue or not. I
mentioned in the thread below that all my cross schema references are wrong.
It is not just that they are wrong... but when the schema gets written out,
the references have the wrong namespace!! So, if schema A imports schema B
and schema C... and an Element in A has a type attribute from schema C...
when A gets written out, Element A's type attriubte is B:type and no xmlns
declaration is created for C.
I am completely lost at this point. I'm breakpointing all over the
place and all the references look correct right up until the save. After
the save all the references get reset to placeholder entities from the
incorrect schema. I do get the following in the log as a warning : XSD:
There is no xmlns declaration for namespace
'http://schemas.xmlsoap.org/soap/encoding' as well as XSD: The location
'soap_encoding.xsd' has not been resolved... also as a warning.
Unfortunately I don't have any schemas to send as I'm getting here via a
conversion process from our old proprietary xsd metamodel to your xsd
metamodel. I'm willing to send them off-line if you think they'll help, but
they are very UUID based making it much harder to read!!
HELP!!
thanks,
lp
Re: More namespace help [message #43707 is a reply to message #43644] Wed, 05 May 2004 14:35 Go to previous messageGo to next message
Lance,
I'll definitely need something that reproduces the problem to provide decent
help.
Lance Phillips wrote:
> Ed,
> HELP!!
> thanks,
> lp
Re: More namespace help [message #43767 is a reply to message #43707] Wed, 05 May 2004 17:16 Go to previous message
Ed,
I sent you a producible test off line.
thanks,
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:409933E2.6F67A4BB@ca.ibm.com...
> Lance,
decent
> help.
> > Ed,
wrong.
out,
schema B
C...
xmlns
After
via a
but
> > HELP!!
> > thanks,
> > lp
Re: More namespace help [message #586746 is a reply to message #43644] Wed, 05 May 2004 14:35 Go to previous message
Lance,
help.
> Ed,
> HELP!!
> thanks,
> lp
Re: More namespace help [message #586766 is a reply to message #43707] Wed, 05 May 2004 17:16 Go to previous message
Ed,
thanks,
lp
> Lance,
decent
> help.
> > Ed,
wrong.
out,
schema B
C...
xmlns
After
via a
but
> > HELP!!
> > thanks,
> > lp
Previous Topic:SchemaLocation help
Next Topic:ComplexType error help
Current Time: Sat Jul 26 18:41:47 EDT 2025
Powered by FUDForum. Page generated in 0.28250 seconds
