Re: More namespace help [message #43707 is a reply to message #43644] |
Wed, 05 May 2004 18:35 |
Lance,
I'll definitely need something that reproduces the problem to provide decent
help.
Lance Phillips wrote:
> Ed,
> More info on the problem I was having below... I'm not sure if the
> schema location issue in the imports is related to this issue or not. I
> mentioned in the thread below that all my cross schema references are wrong.
> It is not just that they are wrong... but when the schema gets written out,
> the references have the wrong namespace!! So, if schema A imports schema B
> and schema C... and an Element in A has a type attribute from schema C...
> when A gets written out, Element A's type attriubte is B:type and no xmlns
> declaration is created for C.
> I am completely lost at this point. I'm breakpointing all over the
> place and all the references look correct right up until the save. After
> the save all the references get reset to placeholder entities from the
> incorrect schema. I do get the following in the log as a warning : XSD:
> There is no xmlns declaration for namespace
> 'http://schemas.xmlsoap.org/soap/encoding' as well as XSD: The location
> 'soap_encoding.xsd' has not been resolved... also as a warning.
> Unfortunately I don't have any schemas to send as I'm getting here via a
> conversion process from our old proprietary xsd metamodel to your xsd
> metamodel. I'm willing to send them off-line if you think they'll help, but
> they are very UUID based making it much harder to read!!
> HELP!!
> thanks,
> lp
Re: More namespace help [message #43767 is a reply to message #43707] |
Wed, 05 May 2004 21:16 |
Lance Phillips Messages: 210 Registered: July 2009 |
Ed,
I sent you a producible test off line.
thanks,
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:409933E2.6F67A4BB@ca.ibm.com...
> Lance,
decent
> help.
> > Ed,
wrong.
out,
schema B
C...
xmlns
After
via a
but
> > HELP!!
> > thanks,
> > lp
Re: More namespace help [message #586746 is a reply to message #43644] |
Ed Merks Messages: 33142 Registered: July 2009 |
Lance,
help.
> Ed,
> HELP!!
> thanks,
> lp
Ed Merks
Re: More namespace help [message #586766 is a reply to message #43707] |
Ed,
thanks,
lp
> Lance,
decent
> help.
> > Ed,
wrong.
out,
schema B
C...
xmlns
After
via a
but
> > HELP!!
> > thanks,
> > lp
FUDForum. Page generated in 0.03599 seconds
