Home » Eclipse Projects » DTP » NullpointerExceptions on Connect, disappear with eclipse -clean
NullpointerExceptions on Connect, disappear with eclipse -clean [message #43638] Mon, 07 April 2008 06:53 Go to next message
Originally posted by: knb.gfz-potsdam.de
Whe I try to connect to a Sybase ASE database I sometimes get
NullPointerExceptions. Please see Stacktrace below.
This happens when I try to open a .sql file with the DTP sql-file
editor, choosing context menu (right mouse click) / "set connection info".
When I start eclipse from the command line, with the -clean option I
*can* connect to the database, using the method mentioned above.
Why is that so? Any Ideas?
Knut
eclipse.buildId=I20070625-1500
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86_64
Error
Mon Apr 07 10:39:58 GMT 2008
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
org.eclipse.datatools.sqltools.core.profile.ProfileUtil.getD atabase(ProfileUtil.java:494)
org.eclipse.datatools.sqltools.core.profile.ProfileUtil.getD atabaseList(ProfileUtil.java:756)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.AbstractConnectionInfoComposite.initDBNames(AbstractConn ectionInfoComposite.java:136)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.AbstractConnectionInfoComposite.init(AbstractConnectionI nfoComposite.java:264)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.ConnectionInfoComposite2.init(ConnectionInfoComposite2.j ava:249)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.AbstractConnectionInfoComposite.init(AbstractConnectionI nfoComposite.java:224)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor$ToolbarSourceViewer.refreshConnectionStat us(SQLScrapbookEditor.java:108)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.refreshConnectionStatus(SQLScrapbookEdito r.java:262)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.setFocus( SQLEditor.java:1448)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:318)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 127)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:623)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:618)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3398)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:611)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2748)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:286)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:139)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 5)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:316)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:613)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #43671 is a reply to message #43638] Mon, 07 April 2008 10:06 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Knut...
Can you tell us... Which build of DTP are you using? Which build of Eclipse
are you using?
"Knut Behrends" <knb@gfz-potsdam.de> wrote in message
news:ftcudr$9k5$1@build.eclipse.org...
> Knut
> Error
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #43702 is a reply to message #43638] Mon, 07 April 2008 10:12 Go to previous messageGo to next message
Hi Knut...
are you using?
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #43733 is a reply to message #43638] Mon, 07 April 2008 10:12 Go to previous messageGo to next message
Sorry about the duplicate posting. Having issues with my newsgroup reader
this morning.
--Fitz
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #43916 is a reply to message #43733] Wed, 09 April 2008 03:23 Go to previous messageGo to next message
>Eclipse are you using?
Brian-
This information you requested was partly already there in my first
posting, right before the stack trace. The same error also occured with
earlier DTP versions which can be used with the
eclipse.buildId=I20070625-1500.
Knut
Now:
My DTP version is
1.6.0.200802151
Before
1.5.1.200709261 feature-disable success
27.02.2008 13:13:34
I am not sure about this version which I had also installed:
1.5.0.200706221
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #43947 is a reply to message #43916] Wed, 09 April 2008 10:29 Go to previous message
Thanks for the additional information.
We've had a similar report recently also for the SAP MaxDB contribution.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226234
I'm looking into this today and hope to have some answers soon.
--Fitz
news:fthqr9$3q9$1@build.eclipse.org...
> Brian-
> Knut
> Now:
> My DTP version is
> 1.6.0.200802151
> Before
> 27.02.2008 13:13:34
> 1.5.0.200706221
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590786 is a reply to message #43638] Mon, 07 April 2008 10:06 Go to previous message
Hi Knut...
are you using?
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590811 is a reply to message #43638] Mon, 07 April 2008 10:12 Go to previous message
Hi Knut...
are you using?
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590833 is a reply to message #43638] Mon, 07 April 2008 10:12 Go to previous message
this morning.
--Fitz
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590920 is a reply to message #43733] Wed, 09 April 2008 03:23 Go to previous message
Brian-
Knut
Now:
My DTP version is
1.6.0.200802151
Before
27.02.2008 13:13:34
1.5.0.200706221
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590932 is a reply to message #43916] Wed, 09 April 2008 10:29 Go to previous message
--Fitz
> Brian-
> Knut
> Now:
> My DTP version is
> 1.6.0.200802151
> Before
> 27.02.2008 13:13:34
> 1.5.0.200706221
Previous Topic:Getting started with Ecore ODA Driver
Next Topic:[Announcement] Eclipse/OMG Symposium at the OMG Technical Meeting in Ottawa
Current Time: Mon Jul 21 21:30:15 EDT 2025
Powered by FUDForum. Page generated in 0.49036 seconds
