NullpointerExceptions on Connect, disappear with eclipse -clean [message #43638] |
Mon, 07 April 2008 06:53  |
Originally posted by: knb.gfz-potsdam.de
Whe I try to connect to a Sybase ASE database I sometimes get
NullPointerExceptions. Please see Stacktrace below.
This happens when I try to open a .sql file with the DTP sql-file
editor, choosing context menu (right mouse click) / "set connection info".
When I start eclipse from the command line, with the -clean option I
*can* connect to the database, using the method mentioned above.
Why is that so? Any Ideas?
Knut
eclipse.buildId=I20070625-1500
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86_64
Error
Mon Apr 07 10:39:58 GMT 2008
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
org.eclipse.datatools.sqltools.core.profile.ProfileUtil.getD atabase(ProfileUtil.java:494)
org.eclipse.datatools.sqltools.core.profile.ProfileUtil.getD atabaseList(ProfileUtil.java:756)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.AbstractConnectionInfoComposite.initDBNames(AbstractConn ectionInfoComposite.java:136)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.AbstractConnectionInfoComposite.init(AbstractConnectionI nfoComposite.java:264)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.ConnectionInfoComposite2.init(ConnectionInfoComposite2.j ava:249)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.connect ion.AbstractConnectionInfoComposite.init(AbstractConnectionI nfoComposite.java:224)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor$ToolbarSourceViewer.refreshConnectionStat us(SQLScrapbookEditor.java:108)
org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.refreshConnectionStatus(SQLScrapbookEdito r.java:262)
org.eclipse.datatools.sqltools.sqleditor.SQLEditor.setFocus( SQLEditor.java:1448)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:318)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 127)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:623)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:618)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3398)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:611)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2748)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:286)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:139)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 5)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:316)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:613)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #43947 is a reply to message #43916] |
Wed, 09 April 2008 10:29  |
Originally posted by: brianf.sybase.com
Thanks for the additional information.
We've had a similar report recently also for the SAP MaxDB contribution.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226234
I'm looking into this today and hope to have some answers soon.
--Fitz
"Knut Behrends" <knb@gfz-potsdam.de> wrote in message
news:fthqr9$3q9$1@build.eclipse.org...
> >Can you tell us... Which build of DTP are you using? Which build of
>>Eclipse are you using?
> Brian-
> This information you requested was partly already there in my first
> posting, right before the stack trace. The same error also occured with
> earlier DTP versions which can be used with the
> eclipse.buildId=I20070625-1500.
> Knut
> Now:
> My DTP version is
> 1.6.0.200802151
> Before
> 1.5.1.200709261 feature-disable success
> 27.02.2008 13:13:34
> I am not sure about this version which I had also installed:
> 1.5.0.200706221
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590786 is a reply to message #43638] |
Mon, 07 April 2008 10:06  |
Hi Knut...
Can you tell us... Which build of DTP are you using? Which build of Eclipse
are you using?
news:ftcudr$9k5$1@build.eclipse.org...
> Knut
> Error
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590811 is a reply to message #43638] |
Mon, 07 April 2008 10:12  |
Hi Knut...
are you using?
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590833 is a reply to message #43638] |
Sorry about the duplicate posting. Having issues with my newsgroup reader
this morning.
--Fitz
> Knut
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590920 is a reply to message #43733] |
Wed, 09 April 2008 03:23  |
Brian-
Knut
Now:
My DTP version is
1.6.0.200802151
Before
27.02.2008 13:13:34
1.5.0.200706221
Re: NullpointerExceptions on Connect, disappear with eclipse -clean [message #590932 is a reply to message #43916] |
--Fitz
> Brian-
> Knut
> Now:
> My DTP version is
> 1.6.0.200802151
> Before
> 27.02.2008 13:13:34
> 1.5.0.200706221
FUDForum. Page generated in 0.45899 seconds
