[ANN] Eclipse Checkstyle v3.1 is available for download [message #43591] |
Thu, 29 May 2003 16:05  |
Originally posted by: daschneider.atlas-sw.com
Version 3.1 of the Eclipse Checkstyle plug-in is now available for download.
Checkstyle is a development tool written by Oliver Burn to help you ensure
that your Java code adheres to a set of coding standards. Checkstyle does
this by inspecting your Java source code and pointing out items that deviate
from a defined set of coding rules. The full Checkstyle distribution is
included with the plug-in. In addition to using the Eclipse Checkstyle
plug-in you can also use Checkstyle from the command line or as part of an
Ant build.
With the Checkstyle Eclipse plug-in your code is constantly inspected for
problems. Within the Eclipse workbench you are notified of problems via the
task window and source code markers just as you would see with compiler
errors or warnings. The current release of the Eclipse plug-in runs the
tree-walker checks from Checkstyle. These checks only check individual Java
source files. A future release of the plug-in may include Checkstyle checks
that span across multiple files.
To get the plug-in go to the project's SourceForge home page at:
http://eclipse-cs.sourceforge.net. If you are interested in receiving future
notifications please join the plug-in's 'Announce' mailing list on the
SourceForge site.
Enjoy,
Dave
FUDForum. Page generated in 0.25659 seconds
