Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with Label.setText() and StackLayout
Problem with Label.setText() and StackLayout [message #43575] Tue, 28 August 2007 09:56 Go to next message
Hi!
I have a strange problem with Label and StackLayout:
I'm using StackLayout and a Composite with a Label. But i can only use
Label.setText() if its Composite is the first topControl of the
StackLayout. If i set it later as topControl, the Label is not repainted
(but getText() returns the correct value).
I created a small demo-Composite, where you can see the problem:
There are two equal Composites on a StackLayout, each with a Label, but
only on the first one you can add Text to the Label. If you exchange the
Label with a Text, it works fine:
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.StackLayout;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
public class StackLayoutTestComposite extends Composite{
private StackLayout stackLayout = new StackLayout();
private Composite composite1, composite2;
public StackLayoutTestComposite(Composite parent, int style) {
super(parent, style);
setLayout(new GridLayout(1, false));
Button switchButton = new Button(this, SWT.NONE);
switchButton.setText("switch Composite");
final Composite composite = new Composite(this, SWT.NONE);
GridDataFactory.fillDefaults().grab(true, false).applyTo(composite);
composite.setLayout(stackLayout);
composite1 = createComposite(composite, "1");
composite2 = createComposite(composite, "2");
stackLayout.topControl = composite1;
composite.layout();
switchButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
if (stackLayout.topControl == composite1) {
stackLayout.topControl = composite2;
} else {
composite.layout();
private Composite createComposite(Composite parent, String startValue) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(1, false));
final Label label = new Label(composite, SWT.NONE);
label.setText(startValue);
GridDataFactory.fillDefaults().grab(true, false).applyTo(label);
Button button = new Button(composite, SWT.BORDER);
button.setText("add text to Label");
button.addSelectionListener(new SelectionAdapter(){
label.setText(label.getText()+"x");
return composite;
Re: Problem with Label.setText() and StackLayout [message #44316 is a reply to message #43575] Sat, 01 September 2007 17:42 Go to previous message
Hi Magnus,
seems very strange. You could please file a bug against RWT so we can
track that?
Benny
Magnus Konze wrote:
> Hi!
> composite.layout();
> } else {
> composite.layout();
> startValue) {
> return composite;
Previous Topic:ServletContext is null
Next Topic:Re: How to show a MessageDialog in a web browser when an event occoured in the backround thread
Current Time: Mon Jul 21 20:57:24 EDT 2025
Powered by FUDForum. Page generated in 0.03505 seconds
