Home » Modeling » GMF (Graphical Modeling Framework) » Why I can't select node in my compartment to move
Why I can't select node in my compartment to move [message #43544] |
Sat, 09 September 2006 10:23  |
I encounter a problem when I use gmf. I create a compartment for a node
'A' and add the other kind of node 'B' reference under it. In the
generated diagram editor, I can add the 'B' in the `A`'s compartment but
after that 'B' just stays on the top left conner of the `A`'s
compartment and I can do nothing with it. Does anybody know what the
problem is? Thanks for advancing!
Junyan
Re: Why I can't select node in my compartment to move [message #44801 is a reply to message #44068] |
Mon, 11 September 2006 08:31   |
Originally posted by: lod.staff.civ.org.pl
interestingly enough, I have the same problem; whenever I attempt to
create a compartment - that is, all children of the compartment get
repositioned to the top-left corner of the compartment, become
unselectable, and additionally the compartment figure's label is not
displayed. I'm probably skipping some step, but after triple checking
and comparing with the examples I cannot tell which one.
No errors are logged since the initialization of the diagram editor.
Any help would be appreciated.
Mikolaj
> First please check your .log file.
> Most probably you will find exception (my guess is ClassCastException)
> somewhere in generated code.
> Michael
> "Junyan Ma" <alexmajy@gmail.com> wrote in message
> news:eduipg$fgf$1@utils.eclipse.org...
>> after that 'B' just stays on the top left conner of the `A`'s compartment
>> and I can do nothing with it. Does anybody know what the problem is?
>> Regards,
>> Junyan
Re: Why I can't select node in my compartment to move [message #44903 is a reply to message #44801] |
Mon, 11 September 2006 10:39   |
Mikolaj Koziarkiewicz wrote:
> Hello,
> Mikolaj
>> Regards,
>> Michael
>>> Hi,
>>> Regards,
>>> Junyan
Hi Mikolaj,
We just keep watching the flash and ignore the 'tip' in the tutorial 2.
Just set the 'List Layout' false :)
Tip : In the generator model, you will find a property on the
compartment that will allow you to show children as 'floating' nodes and
not stacked in a list. The property is 'List Layout' and should be set
to 'false' in this case.
Re: Why I can't select node in my compartment to move [message #44954 is a reply to message #44903] |
Mon, 11 September 2006 11:16  |
>> Hello,
>> Regards,
>> Mikolaj
>>> Hi,
>>> ClassCastException) somewhere in generated code.
>>> Regards,
>>> Michael
>>>> Hi,
>>>> but
>>>> Regards,
>>>> Junyan
> Hi Mikolaj,
Hello Junyan,
talk about obfuscated ;)... Thanks, this solves it! Also, the problems
associated with the label's display was simply the result of a lack of a
Label Mapping.
Mikolaj
Current Time: Mon Sep 01 02:35:35 EDT 2025
Powered by FUDForum. Page generated in 0.15820 seconds
