KDE, Eclipse, and font sizes [message #43538] |
Sat, 25 January 2003 10:38  |
Originally posted by: leegraba.visi.com
I have installed Eclipse (version 2.0.2) on my Mandrake 9.0 Linux system.
When I am using KDE and fire up eclipse, the fonts used in the menus and
views are all very small, probably about 6 point. If I use GNOME instead,
I can start the GNOME font config app and change the default application
font to something reasonable, and this is reflected in eclipse when I
start it up. Unfortunately, when I go back to KDE, it still uses the
small font sizes. I had seen in an SWT FAQ that default GtK fonts can be
changed by putting the text below in a .gtkrc or .gtkrc_2.0 file:
style "eclipse" {
font_name = "Sans 12"
bg[NORMAL] = "#d6d3ce"
bg[ACTIVE] = "#c7c2bc"
bg[INSENSITIVE] = "#828282"
bg[PRELIGHT] = "#3a6ea5"
fg[NORMAL] = "#000000"
fg[ACTIVE] = "#000000"
fg[INSENSITIVE] = "#d4d0c8"
fg[PRELIGHT] = "#ffffff"
class "GtkWidget" style "eclipse"
However, this doesn't seem to work either.
Any suggestions?
Re: KDE, Eclipse, and font sizes [message #43700 is a reply to message #43538] |
Sun, 26 January 2003 21:32  |
> style "eclipse" {
> Any suggestions?
It turns out that I was trying the above config stuff in .gtkrc, rather than
..gtkrc-2.0. Putting it in the latter works.
Lee Graba
leegraba@visi.com
Re: KDE, Eclipse, and font sizes [message #589446 is a reply to message #43538] |
> style "eclipse" {
> Any suggestions?
Lee Graba
leegraba@visi.com
FUDForum. Page generated in 0.04514 seconds
