Home » Archived » BIRT » BIRT Integration
BIRT Integration [message #43488] Mon, 06 June 2005 22:54 Go to next message
First of all my congratualtions to BIRT team on BIRT 1.0 release,
Now that I'm using BIRT 1.0, I just want to ask if pointing to BIRT viewer
is the right approach to integrate BIRT reports with my web application
using JSP just like shown belown ? or we still have to wait from BIRT team
regarding the correct procedure regarding BIRT reports integration to a
web application...
//********sample of my jsp code *****
//********reportindex.jsp *****
<html>
<body>
<a href=" http://localhost:8080/birt/run?__report=Report\testrpt.rptde sign">
Test Report</a></body><br>
</body>
</html>
Wins
Re: BIRT Integration [message #45707 is a reply to message #43488] Tue, 14 June 2005 12:31 Go to previous messageGo to next message
Wins,
I think for now the BIRT team is supporting viewing of BIRT reports
through the BIRT viewer application, essentially re-directing from your
web app to the BIRT viewer web app. One of the things that we are
looking at is the usage modes for how people want to include BIRT
content into their applications.
This could mean an RCP application, a web service, a stand-alone java
app. If you could provide some insight into your application and the
way that you would like to include BIRT content, it would be helpful as
we develop more BIRT deployment models.
Scott Rosenbaum
BIRT PMC
> viewer is the right approach to integrate BIRT reports with my web
> application using JSP just like shown belown ? or we still have to wait
> from BIRT team regarding the correct procedure regarding BIRT reports
> integration to a web application...
> //********sample of my jsp code ***** //********reportindex.jsp *****
> <html>
> <body>
> </body>
> </html>
> Wins
Re: BIRT Integration [message #45735 is a reply to message #45707] Tue, 14 June 2005 12:13 Go to previous messageGo to next message
We'd like to be able to run a BIRT report in response to a web service
invocation. Basically a session bean would call a BIRT API and then send the
HTML report stream back to the client.
Re: BIRT Integration [message #46143 is a reply to message #45707] Tue, 14 June 2005 22:27 Go to previous messageGo to next message
Hi Scott,
Our application is a web-based accounting system, this is our first
project using J2EE. We use Jakarta-Struts framework for this application.
This is where we want our reports to be generated. Sample report to be
produced is Statement of Income, in this report user must input a
particular date..We want to generate this report using jsp where the user
can input the date either by choosing from combo box or by typing it as
parameters and then from there generate and display the report based on
the parameters input ....waiting for your help.
Wins
Re: BIRT Integration [message #46787 is a reply to message #46143] Wed, 15 June 2005 20:18 Go to previous messageGo to next message
Hi, Wins,
Your usage scenario sounds very similar to what BIRT viewer intends to
address. BIRT viewer provides a UI for you to enter parameters, and then
calls into report engine to generate the HTML or PDF output. BIRT viewer
is packaged as a standalone web applicaiton. If you want BIRT to be
integrated into your web application, you need to use report engine
directly. Then BIRT viewer is a good sample application for you to learn
how to integrate BIRT engine into your web application. You will probably
be copying a lot of code from BIRT viewer to your web app.
Stanley Wang
BIRT Engine
Re: BIRT Integration [message #46962 is a reply to message #46787] Thu, 16 June 2005 03:08 Go to previous message
Hi Stanley,
Thanks for the support, i'm still trying to dig more about the BIRT viewer
and report engine API and hoping that i'm in the right track in
integrating BIRT to my web-app...
BTW, where can i get more info about the Actuate Birt?
More power!!!
Wins
Previous Topic:Error1:Cannot open connection (jdbc) in Report Design /Preview
Next Topic:Standalone without view
Current Time: Tue Jul 22 02:36:02 EDT 2025
Powered by FUDForum. Page generated in 0.05211 seconds
