Home » Archived » XML Schema Definition (XSD) » SchemaLocation help
SchemaLocation help [message #43456] |
Tue, 04 May 2004 17:23  |
In our XSDImport objects, we are setting the namespace attribute with no
problems. However, our schemaLocation values don't seem to be working. I'm
using the relative file path to the importing schema. What SHOULD I be
using there. Per the spec, it appears that it may be valid to just use the
namespace attribute in BOTH fields??? With the value set to relative file
paths, I get a warning after validation stating that the location could not
be resolved.
thanks,
lp
Re: SchemaLocation help [message #43583 is a reply to message #43553] |
Wed, 05 May 2004 08:40   |
Lance,
I was recommending that the URI of the containing document/Resource should be
absolute not changing the schema location to be absolute; it's better to use
relative schema locations as much as possible. A URI uses "/" not "\"; a file
system path is not a URI.
Lance Phillips wrote:
> Ed,
> I converted the schema location to an absolute path and now I'm getting
> the following:
> XSD: The value
> 'e:\Plugins\current\runtime-workspace\testing\soap_encoding. xsd' of
> attribute 'schemaLocation' must be of type
> 'http://www.w3.org/2001/XMLSchema#anyURI'
> thanks,
> lp
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:40980BE6.7E6DEFD4@ca.ibm.com...
> > Lance,
> > What's the URI of the document containing the reference? It must be
> absolute
> > for relative references to resolve.
> I'm
> the
> file
> not
> > > be resolved.
> > > thanks,
> > > lp
Re: SchemaLocation help [message #43614 is a reply to message #43583] |
Wed, 05 May 2004 09:34   |
Hmmmm.... I seem to have all kinds of issues with references. None of my
cross schema references resolve. I get an error for everything that refers
to something in another schema. The NS is correct in both Schemas. The
error looks like this:
XSD: Attribute group reference
' http://namespace.worldnet.ml.com/EDSI/Party/Datatypes/PartyD atatypes_v5_2#a
rrayAttributes' is unresolved
The PartyDatatypes schema exists and has been read into a resource in the
same resourceSet as the referencing schema. I've stepped through it in
debug and the references all get correctly set to the correct EObject from
the other schema... but when I validate I get the above exception.
Any ideas? My import looks like this (both files exist in the same
directory)....
<xs:import
namespace= http://namespace.worldnet.ml.com/EDSI/Standards/Datatypes/St andard
Datatypes_1_1 schemaLocation="StandardDatatypes_1_1.xsd" />
thanks,
lp
news:4098E0CA.B3309D0A@ca.ibm.com...
> Lance,
be
use
file
> > Ed,
getting
> > the following:
> > XSD: The value
> > thanks,
> > lp
> > > Lance,
> > absolute
h no
working.
> > I'm
be
use
> > the
relative
> > file
could
> > not
> > > > be resolved.
> > > > thanks,
> > > > lp
Re: SchemaLocation help [message #43677 is a reply to message #43614] |
Wed, 05 May 2004 14:30   |
Lance,
What is the URI of the document/Resource containing these?
> directory)....
> <xs:import
> thanks,
> lp
> > Lance,
> be
> use
> file
> > > Ed,
> getting
> > > the following:
> > > XSD: The value
> > > thanks,
> > > lp
> > > > Lance,
> > > absolute
> h no
> working.
> > > I'm
> be
> use
> > > the
> relative
> > > file
> could
> > > not
> > > > > be resolved.
> > > > > thanks,
> > > > > lp
Re: SchemaLocation help [message #43739 is a reply to message #43677] |
Wed, 05 May 2004 16:15  |
The uris for the resources are :
file:/e:/Plugins/current/runtime-workspace/testing/Organizat ion_v5_2.xsd
file:/e:/Plugins/current/runtime-workspace/testing/PartyData types_v5_2.xsd
The targetNamespaces are :
The uri for the importing schema is
http://namespace.worldnet.ml.com/EDSI/Party/Organization_v5_ 2
The uri for the imported schema is
The crazy thing is that arrayAttributes that it can't find (per the message
below) is contained in
file:/e:/Plugins/current/runtime-workspace/testing/soap_enco ding.xsd which
is also imported by Organization.
thanks,
lp
news:409932CD.5995F79C@ca.ibm.com...
> Lance,
my
refers
the
from
> > directory)....
> > <xs:import
> > thanks,
> > lp
> > > Lance,
should
> > be
to
> > use
"\"; a
> > file
> > > > Ed,
> > getting
> > > > the following:
> > > > XSD: The value
> > > > thanks,
> > > > lp
> > > > > Lance,
be
> > > > absolute
wit
> > h no
> > working.
> > > > I'm
SHOULD I
> > be
just
> > use
> > > > the
> > relative
> > > > file
location
> > could
> > > > not
> > > > > > be resolved.
> > > > > > thanks,
> > > > > > lp
Re: SchemaLocation help [message #586655 is a reply to message #43456] |
Tue, 04 May 2004 17:32  |
Lance,
What's the URI of the document containing the reference? It must be absolute
> be resolved.
> thanks,
> lp
Re: SchemaLocation help [message #586677 is a reply to message #43490] |
Wed, 05 May 2004 08:18  |
Ed,
the following:
XSD: The value
thanks,
lp
> Lance,
absolute
I'm
the
file
not
> > be resolved.
> > thanks,
> > lp
Re: SchemaLocation help [message #586687 is a reply to message #43553] |
Lance,
> Ed,
> the following:
> XSD: The value
> thanks,
> lp
> > Lance,
> absolute
> I'm
> the
> file
> not
> > > be resolved.
> > > thanks,
> > > lp
Re: SchemaLocation help [message #586695 is a reply to message #43583] |
directory)....
<xs:import
thanks,
lp
> Lance,
be
use
file
> > Ed,
getting
> > the following:
> > XSD: The value
> > thanks,
> > lp
> > > Lance,
> > absolute
h no
working.
> > I'm
be
use
> > the
relative
> > file
could
> > not
> > > > be resolved.
> > > > thanks,
> > > > lp
Re: SchemaLocation help [message #586727 is a reply to message #43614] |
Lance,
> directory)....
> <xs:import
> thanks,
> lp
> > Lance,
> be
> use
> file
> > > Ed,
> getting
> > > the following:
> > > XSD: The value
> > > thanks,
> > > lp
> > > > Lance,
> > > absolute
> h no
> working.
> > > I'm
> be
> use
> > > the
> relative
> > > file
> could
> > > not
> > > > > be resolved.
> > > > > thanks,
> > > > > lp
Re: SchemaLocation help [message #586754 is a reply to message #43677] |
thanks,
lp
> Lance,
my
refers
the
from
> > directory)....
> > <xs:import
> > thanks,
> > lp
> > > Lance,
should
> > be
to
> > use
"\"; a
> > file
> > > > Ed,
> > getting
> > > > the following:
> > > > XSD: The value
> > > > thanks,
> > > > lp
> > > > > Lance,
be
> > > > absolute
wit
> > h no
> > working.
> > > > I'm
SHOULD I
> > be
just
> > use
> > > > the
> > relative
> > > > file
location
> > could
> > > > not
> > > > > > be resolved.
> > > > > > thanks,
> > > > > > lp
Current Time: Tue Jul 15 03:52:19 EDT 2025
Powered by FUDForum. Page generated in 0.10290 seconds
