Home » Archived » M2M (model-to-model transformation) » Cannot call a CalledRule on a Seqeunce()
Cannot call a CalledRule on a Seqeunce() [message #43448] Thu, 31 May 2007 10:38 Go to next message
Hi all,
I've got a problem with the called rules.
I want to call one of these rules like this :
rule A {
from
a : MMa!A
to
b : MMb!B (
truc <- a.getAllIWant()->collect( e | thisModule.myCalledRule( e,
a ) )
rule myCalledRule( e,a) { ... }
Where the helper getAllIWant() returns a collection.
During execution I've got this error :
message: ERROR: could not find operation including on Module having
supertypes: [OclAny]
But seems to work when we call the rule on a reference like this :
b : MMb!B (
truc <- a.refs->collect( e | thisModule.myCalledRule( e, a ) )
where refs is a reference of A in MMa.
So where i'm wrong ?
What i got to do for calling a called rule on a calculated sequence
Any idea
Re: Cannot call a CalledRule on a Seqeunce() [message #43508 is a reply to message #43448] Thu, 31 May 2007 10:57 Go to previous messageGo to next message
Originally posted by: tristan.faure.c-s.fr
hi
I'm not a specialist but there is some points strange
Why do you have 2 parameters in you called rule when you call it ?
if you use a call rule I think you have to use a rule of this kind :
rule
to b : MMb!B (
do {
b ;
or maybe you want to use a lazy rule and in that case you have to do
lazy rule
Re: Cannot call a CalledRule on a Seqeunce() [message #43539 is a reply to message #43448] Thu, 31 May 2007 10:59 Go to previous messageGo to next message
sorry for the double post . . . :(
hi
rule
to b : MMb!B (
do {
b ;
or maybe you want to use a lazy rule ? and in that case you have to do
lazy rule
from
to
[ATL]Re: Cannot call a CalledRule on a Seqeunce() [message #43569 is a reply to message #43448] Thu, 31 May 2007 11:11 Go to previous message
With the [ATL] ;)
Apologizes to all
I've made a mistake, I've forgot that we've cannot call a called rules
from the declarative part. I have to use lazy rule instead.
Good day
Previous Topic:[ATL] An internal error occurred during: "Launching".
Next Topic:[ATL] problem with programmatically transformation output model
Current Time: Fri Jul 18 22:37:31 EDT 2025
Powered by FUDForum. Page generated in 0.27615 seconds
