Home » Archived » M2M (model-to-model transformation) » [ATL] Proper nesting
[ATL] Proper nesting [message #43388] |
Thu, 31 May 2007 09:16  |
Originally posted by: atl_apprentice.yahoo.com
Hi everybody,
I want to create a UML to UML transformation.
When I look at my input XMI file, everything is contained in the UML:Model
element.
<UML:Model xmi.id='eee_1045467100313_135436_1' name='Data'>
<UML:ModelElement.comment>
<UML:Comment xmi.id='_9_5_1_3e4f06c0_1180422049437_213635_233'
name='This is comment'/>
</UML:ModelElement.comment>
</UML:Model>
As a test I wanted to apply the following transformation rule:
module UML2UML; -- Module Template
create OUT : UML refining IN : UML;
rule m2m {
from
m_in : UML!Model
to
m_out : UML!Model (
name <- m_in.name,
comment <- m_in.comment
This rule, however, creates a reference in Model to a Comment outside of
Model:
<UML:Model xmi.id = 'a1' name = 'Data' isSpecification = 'false' isRoot =
'false' isLeaf = 'false' isAbstract = 'false'>
<UML:Comment xmi.idref = 'a2'/>
</UML:Model>
<UML:Comment xmi.id = 'a2' name = 'This is comment' isSpecification =
'false'>
<UML:Comment.annotatedElement>
<UML:Model xmi.idref = 'a1'/>
</UML:Comment.annotatedElement>
</UML:Comment>
How can I adjust my transformation rule in such a way, that not a reference
to comment but the actual comment is placed within Model and nothing is
places outside of Model?
Is it possible to specify a target element's parent so it will be contained
by that parent?
I need to know how to do this, because eventually I want to create a layout
of packages. After creating this layout I need to create Classes which
should be contained in the right package.
Can anyone help me out on this one?
Thanks in advance
Re: [ATL] Proper nesting [message #43417 is a reply to message #43388] |
Thu, 31 May 2007 10:22   |
Containment is specified in the metamodel.
Your cases looks like you have two different UML metamodels, with
ModelElement.comment being a composition in the source metamodel, but
not in the target metamodel.
Could you please check whether ModelElement.comment is a containment in
your target UML metamodel? If it is not, simply changing it will solve
your problem. If it is, then we will have to look for the problem
somewhere else.
Note that I do not mean you are not using the exact same metamodel for
the transformation, but that the source model was created using a
different version of the metamodel (e.g., using a UML tool with a
slightly different metamodel).
Frédéric Jouault
ATL_Apprentice wrote:
> Hi everybody,
> element.
> </UML:Model>
> rule m2m {
> from
> m_in : UML!Model
> to
> m_out : UML!Model (
> name <- m_in.name,
> Model:
> </UML:Model>
> 'false'>
> </UML:Comment>
> by that parent?
> Thanks in advance
Re: [ATL] Proper nesting [message #43957 is a reply to message #43927] |
Sun, 03 June 2007 07:44   |
Hi!
First of all I want to thank you for helping me.
I thought maybe a very simple example would set me on the right track, but I
think I didn't come up with a good example, because I still don't know how
to do what I actually wanted to do.
The purpose of my example was to learn how to position an element in the
target model.
What I actually want to do is the following:
* The whole input model should be copied into the output model (both UML).
That's why I thought refining mode would be a good idea.
* In the input model a package with a specific name has to be matched. If
this match is found, then an additional package with a specific name has to
be created, without deleting the source package (both have to be present in
the target model).
* If classes are found in the source package, then these classes have to be
copied into the newly created package, without deleting the source package.
The names of these classes will be prefixed.
* All get-operations have to be matched in the classes in the matched source
package. These operations have to be copied into the target model into the
classes in the newly created package, but instead of get-operations, they
have to be turned into set-operations.
This transformation seems very simple to me, but I'm having a hard time
getting everything nested in the correct package.
Say I have the following INPUT:
<UML:Model xmi.id="a1" name="Data">
<UML:Namespace.ownedElement>
<UML:Package xmi.id="a2" name="PackA">
<UML:Class xmi.id="a3" name="Class1">
<UML:Classifier.feature>
<UML:Operation xmi.id="a4" name="getProperty"
visibility="public">
<UML:BehavioralFeature.parameter>
<UML:Parameter xmi.id="a5" kind="return" />
</UML:BehavioralFeature.parameter>
</UML:Operation>
</UML:Classifier.feature>
</UML:Class>
</UML:Namespace.ownedElement>
</UML:Package>
</UML:Model>
Then I would want the following OUTPUT:
</UML:Operation>
</UML:Class>
</UML:Package>
<UML:Package xmi.id="a6" name="PackB">
<UML:Class xmi.id="a7" name="XClass1">
<UML:Operation xmi.id="a8" name="setProperty"
<UML:Parameter xmi.id="a9" kind="return" />
</UML:Operation>
</UML:Class>
</UML:Package>
</UML:Model>
I have made some transformation rules:
- One to copy Model;
- One to copy Package and create an additional Package;
- One to copy Classes and create additional Classes;
- One to copy Operations and create additional Operations.
As I said, the transformation is running in refining mode
(good or bad choice?)
Here are the rules:
rule model {
from
m_in : UML!Model
to
m_out : UML!Model (
name <- m_in.name,
ownedElement <- m_in.ownedElement
rule pack {
from
p_in : UML!Package(
p_in.name='PackA'
to
p_out : UML!Package(
name<-p_in.name,
ownedElement<-p_in.ownedElement
p_add : UML!Package(
name<-'PackB'
--how do I tell that PackB must be in Model?
rule class {
from
c_in : UML!Class
-- Still need to make sure to select only Classes from PackA
to
c_out : UML!Class(
name<-c_in.name,
feature<-c_in.feature
c_add : UML!Class(
name<-'X'+c_in.name
--how do I tell that this class should come in PackB?
rule op {
from
o_in : UML!Operation
-- Still need to make sure only to select get-ops from classes of
PackA
to
o_out : UML!Operation(
name<-o_in.name,
parameter<-o_in.parameter
o_add : UML!Operation(
name<-'set' + o_in.name --not yet correct
--Also, here I need to make sure the operation goes to the proper
target class.
The source package seems properly copied,
but the additional elements are created outside of the Model element.
I don't know how to get those nested in the proper position.
I can't solve this by changing stuff in the metamodel, because the metamodel
is correct.
How do I assign the new elements to the correct "parent" element?
"Fr
Re: [ATL] Proper nesting [message #43989 is a reply to message #43957] |
Sun, 03 June 2007 08:59   |
Firstly, I believe the choice of refining mode is good, because you
really do not want to write copying rules for everything that you do not
modify.
An alternative would be to generate a copying transformation (e.g.,
using KM32ATLCopier:
http://www.eclipse.org/m2m/atl/atlTransformations/#KM32ATLCo pier)
that you could then modify, or, even better, superimpose with your own
rules (for an example, see
http://wiki.eclipse.org/index.php/ATL_Superimposition).
Secondly, regarding nesting:
You need to initialize the containment associations beween Model and
Package, Package and Class, and Class and Operation.
Depending on the UML metamodel you use:
- this can be easy if the association can be initialized in both
directions: then you simply initialize the "parent" (see your UML
metamodel to know its actual name) reference when you create the
additional Packages, Classes, and Operations.
- this can be a bit more painful if the association is unidirectional
(i.e., if the metamodel was *not* designed with transformation in mind):
you then need to add the newly created elements to the collection you
use to initialize the "children" (e.g., "ownedElement", or "feature" in
your case) reference. For instance, in rule model:
ownedElement <- m_in.ownedElement->union(
m_in.ownedElement->select(e |
e.oclIsKindOf(UML!Package)
)->select(e |
-- you may want to define the guard
-- in an attribute helper, so as to
-- reuse it instead of cloning it
e.name = 'PackA'
)->collect(e |
thisModule.resolveTemp(e, 'p_add')
Note that you will probably also need a rule to copy parameters.
Frédéric Jouault
P.S.: Thanks for thanking me for helping you ;-). It is always
gratifying to know that 1) the solution one suggests work, 2) the person
it was suggested to is grateful :-D.
> Hi!
> target model.
> the target model).
> </UML:Operation>
> </UML:Class>
> </UML:Package>
> </UML:Model>
> </UML:Operation>
> </UML:Class>
> </UML:Package>
> </UML:Operation>
> </UML:Class>
> </UML:Package>
> </UML:Model>
> Here are the rules:
> rule model {
> from
> m_in : UML!Model
> to
> m_out : UML!Model (
> name <- m_in.name,
> rule pack {
> from
> p_in : UML!Package(
> p_in.name='PackA'
> to
> name<-p_in.name,
> name<-'PackB'
> rule class {
> from
> c_in : UML!Class
> to
> c_out : UML!Class(
> name<-c_in.name,
> c_add : UML!Class(
> name<-'X'+c_in.name
> rule op {
> from
> PackA
> to
> name<-o_in.name,
> target class.
> is correct.
> "Frédéric Jouault" <frederic.jouault@univ-nantes.fr> schreef in bericht
> news:f3rplv$9hv$2@build.eclipse.org...
>>> I'm using the UML 1.4 metamodel from the OMG website
>>> (http://www.omg.org/docs/ad/01-02-15.xml)
>>> You were right.
>>> In this metamodel the Association with xmi.id a295 and name
>>> "A_comment_annotatedElement" was not a composition.
>>> I changed it to a composition and it indeed solved the problem.
>>> The comment is now contained by the model.
>>> Doesn't this change in the metamodel have any undesirable side effects?
>> Well, if it was meant to be a composition not really.
>> If it was not, it will prevent you from associating a given comment to
>> more than one ModelElement.
>> Regards,
>> Frédéric Jouault
Re: [ATL] Proper nesting [message #44049 is a reply to message #44020] |
Sun, 03 June 2007 13:11  |
> You're good..
> The association is bidirectional indeed.
>>> rule pack {
>>> from
>>> p_in : UML!Package(
>>> p_in.name='PackA'
>>> to
>>> name<-p_in.name,
>>> name<-'PackB'
> In the part that creates PackB, I just added the following line:
> namespace<-p_in.namespace
> that was all.. and now PackB is properly nested..
> Thanks!!
> P.S. I'm using the metamodel provided by the OMG
Ok. I am glad it now works for you.
Frédéric Jouault
Current Time: Sat Aug 30 23:51:00 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
