Home » Language IDEs » Java Development Tools (JDT) » HELP: Eclipse with JSR14
HELP: Eclipse with JSR14 [message #43368] Thu, 29 May 2003 14:40 Go to next message
Originally posted by: budimlic.myrealbox.com
Hi everyone!
I am relatively new to this forum, and I have an urgent question:
Is there a (relatively) painless way to integrate JSR14 (the new prototype
from Sun for the 1.5 that uses generics, enums e.t.c.) into Eclipse?
I am fully aware that the full functionality (hovering, hierarchy browsing,
probably even syntax checking) would require a lot of
work to get it to work properly.
I am ONLY looking for simple functionality: compiling the project and
debugging it.
Thanks a lot,
Zoran.
Re: HELP: Eclipse with JSR14 [message #44263 is a reply to message #43368] Fri, 30 May 2003 08:00 Go to previous messageGo to next message
> debugging it.
You could switch off the automatic building in Eclipse and use an ANT
build script. You'd probably need to override some ANT defaults to
point it to the right compiler. Or you could setup a simple external
tool launcher for the new javac(.bat) script - works okay for me.
Debugging shouldn't be a problem, if you remember to put the new classes
into the library path. The generated bytecode is backward compatible
AFAIK. However, because Sun decided, to implement autoboxing of ints
using a new static method Integer.valueOf(int) instead of simply calling
"new Integer(...)", the generated code doesn't work with a normal JDK
1.4.x anymore. There's a good reason for the new method, but as long as
it's not implemented the way the description suggests, it's an annoyance.
bye
Stefan Matthias Aust
www.3plus4software.de // Inter Deum Et Diabolum Semper Musica Est
Re: HELP: Eclipse with JSR14 [message #45919 is a reply to message #44263] Sat, 31 May 2003 14:54 Go to previous messageGo to next message
now i am curious.
Whats the good reason for this new method?
and one thing else (i didn't test it yet and the download page is under maintenence now at java.sun)
what happens with this:
Integer a = null;
int b = a;
what do i get?
johan
Re: Eclipse with JSR14 [message #45949 is a reply to message #43368] Sat, 31 May 2003 14:55 Go to previous messageGo to next message
it is in the project plan of the next release
So it will be there in one of the milestone/integration builds
But i think this will not make it for a while.
johan
"Zoran Budimlic" <budimlic@myrealbox.com> wrote in message news:bb5k7g$dsk$1@rogue.oti.com...
> Hi everyone!
> debugging it.
> Thanks a lot,
> Zoran.
Re: HELP: Eclipse with JSR14 [message #46093 is a reply to message #45919] Sun, 01 June 2003 03:32 Go to previous messageGo to next message
> now i am curious.
> maintenence now at java.sun) what happens with this:
> Integer a = null;
> int b = a;
> what do i get?
> johan
Well, AFAIK there were some debates whether a NPE should be thrown or the
value for b should be 0. But I don't know what's the final decision. There
was an interview with Joshua Bloch (don't remember the URL though) where he
talked a bit about all this new stuff in Tiger.
Stelian Iancu
Linux registered user 287835
Be different. Think.
Re: HELP: Eclipse with JSR14 [message #46151 is a reply to message #46093] Sun, 01 June 2003 08:19 Go to previous messageGo to next message
> > Integer a = null;
> > int b = a;
> > what do i get?
> > johan
ahh they should throw a nullpointer
because
Integer a = null;
int b = a;
a = b;
suddenly gives me a Integer(0) in a??
so that state/value is changing with pure assignments?
not logical.
johan
Re: Eclipse with JSR14 [message #47096 is a reply to message #45949] Tue, 03 June 2003 04:44 Go to previous message
Indeed, JDT/Core is busy investigating support for Java-like languages, new
code formatter, new syntax error messages, new index infrastructure and
JavaModel cleanup... generics and other 1.5 features are queued behind
these.
"Johan Compagner" <jcompagner@j-com.nl> wrote in message
news:bbatrq$q1l$1@rogue.oti.com...
> johan
> > Hi everyone!
prototype
browsing,
> > debugging it.
> > Thanks a lot,
> > Zoran.
Previous Topic:Ant and External Tool Builders
Next Topic:Name of a PackageFragmentRoot
Current Time: Thu Jul 17 21:33:48 EDT 2025
Powered by FUDForum. Page generated in 0.04604 seconds
