Home » Language IDEs » C / C++ IDE (CDT) » Unable to build
Unable to build [message #43349] Sun, 29 September 2002 10:18 Go to next message
--------------115A41FE05C04C052F6871D0
Content-Type: text/plain; charset=us-ascii
Hello:
I have followed the instructions given in CDT User FAQ to create a Hello
World Project. I am getting an error when I issue build command. The
error text is as follows:
make -f makefile
!CBuilder.build_error!
(CreateProcess: make -f makefile error=2)
I installed MinGW at C:\MinGW and changed the makefile accordingly.
Also, I have added the C:\MinGW\bin directory to the PATH environment
variable. Is CDT running make command that ships with MinGW? If so, I
dont see the make.exe in C:\MinGW\bin directory? Could that be the
problem?
The makefile is as follows:
objects = hello.o
hello : $(objects)
gcc -o hello $(objects) -L C:/MinGW/lib/gcc-lib/mingw32/3.2/
-lstdc++
$(objects) : hello.cpp
gcc -c hello.cpp
all :
${MAKE} hello
..PHONY : clean
clean :
-del hello.exe $(objects)
Thanks in advance.
Anil
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Hello:
<br>I have followed the instructions given in CDT User FAQ to create a
Hello World Project. I am getting an error when I issue build command.
The error text is as follows:
<p><tt>make -f makefile</tt>
<br><tt>!CBuilder.build_error!</tt>
<br><tt>(CreateProcess: make -f makefile error=2)</tt><tt></tt>
<p>I installed MinGW at C:\MinGW and changed the makefile accordingly.
Also, I have added the C:\MinGW\bin directory to the PATH environment variable.
Is CDT running <tt>make</tt> command that ships with MinGW? If so, I dont
see the make.exe in C:\MinGW\bin directory? Could that be the problem?
<p>The makefile is as follows:
<p><tt>objects = hello.o</tt><tt></tt>
<p><tt>hello : $(objects)</tt>
<br><tt>&nbsp;&nbsp;&nbsp; gcc -o hello $(objects) -L C:/MinGW/lib/gcc-lib/mingw32/3.2/
-lstdc++</tt><tt></tt>
<p><tt>$(objects) : hello.cpp</tt>
<br><tt>&nbsp;&nbsp;&nbsp; gcc -c hello.cpp</tt><tt></tt>
<p><tt>all :</tt>
<br><tt>&nbsp;&nbsp;&nbsp; ${MAKE} hello</tt><tt></tt>
<p><tt>.PHONY : clean</tt>
<br><tt>clean :</tt>
<br><tt>&nbsp;&nbsp;&nbsp; -del hello.exe $(objects)</tt>
<p>Thanks in advance.
<br>Anil</html>
--------------115A41FE05C04C052F6871D0--
Re: Unable to build [message #43453 is a reply to message #43349] Mon, 30 September 2002 03:57 Go to previous messageGo to next message
CDT will launch that make.exe which could find in the PATH. So if you
insert C:\MinGW\bin in PATH and there is no make.exe CDT will post such a
diagnostic
make -f makefile
You should get make.exe and then everything launch properly.
Hope it helps,
Igor S. Zamyatin
Interstron Ltd.
email: isz@interstron.ru
tel: +7 (095) 269-4713
cell: +7 (902) 659-5838
www: http://www.interstron.ru
> Hello:
> make -f makefile
> problem?
> objects = hello.o
> hello : $(objects)
> -lstdc++
> gcc -c hello.cpp
> all :
> ${MAKE} hello
> ..PHONY : clean
> clean :
> Thanks in advance.
> Anil
> <html>
> Hello:
variable.
> <br><tt>    gcc -o hello $(objects) -L C:/MinGW/lib/gcc-lib/mingw32/3.2/
> <br><tt>    gcc -c hello.cpp</tt><tt></tt>
> <p><tt>all :</tt>
> <br><tt>    ${MAKE} hello</tt><tt></tt>
> <br><tt>    -del hello.exe $(objects)</tt>
> <br>Anil</html>
Re: Unable to build [message #43669 is a reply to message #43453] Wed, 02 October 2002 10:12 Go to previous messageGo to next message
I've tried with this one found in MinGW:
mingw32-make.exe
but then I got this error:
makefile:4: *** missing separator. Stop.
Do I need something different? I'm really newby in C/C++ and I'm
just setting up the tools to start learning.
> diagnostic
> make -f makefile
> Anil Ambati wrote:
>> Hello:
>> command. The error text is as follows:
>> make -f makefile
>> environment variable. Is CDT running make command that ships with
>> MinGW? If so, I dont see the make.exe in C:\MinGW\bin directory?
>> objects = hello.o
>> hello : $(objects)
>> gcc -o hello $(objects) -L C:/MinGW/lib/gcc-lib/mingw32/3.2/ -lstdc++
>> gcc -c hello.cpp
>> all :
>> ${MAKE} hello
>> .PHONY : clean
>> clean :
>> Thanks in advance.
>> Anil
Stanimir
Re: Unable to build [message #43732 is a reply to message #43669] Wed, 02 October 2002 17:23 Go to previous message
Make sure the indented lines in your makefile are indented with a tab character,
rather than spaces.
Brian
> mingw32-make.exe
> Do I need something different? I'm really newby in C/C++ and I'm just
>> you insert C:\MinGW\bin in PATH and there is no make.exe CDT will post
>> such a diagnostic
>> make -f makefile
>> Anil Ambati wrote:
>>> Hello:
>>> make -f makefile
>>> problem?
>>> objects = hello.o
>>> hello : $(objects)
>>> -lstdc++
>>> gcc -c hello.cpp
>>> all :
>>> ${MAKE} hello
>>> .PHONY : clean
>>> clean :
>>> Thanks in advance.
>>> Anil
Previous Topic:Inflexible project structure problem
Next Topic:Debugging in C
Current Time: Tue Jul 15 12:16:14 EDT 2025
Powered by FUDForum. Page generated in 0.06671 seconds
