Home » Modeling » M2T (model-to-text transformation) » is it possible to SORT the results of a jet xpath select ?
is it possible to SORT the results of a jet xpath select ? [message #43345] Mon, 17 March 2008 09:05 Go to next message
In my template I iterate over a set of elements
<c:iterate select="$currFile/foo/bar/element" var="element">
It lately turned out that these elements may not be in the oder I need
for processing, I'd need them sorted by the value of an attribute.
I'd be happy if the select statement supported "some sort" ;-) of
sorting syntax.
alternatively, could the template sort the dom first and then start the
iteration?
cheers
Edo
Re: is it possible to SORT the results of a jet xpath select ? [message #43735 is a reply to message #43345] Wed, 26 March 2008 10:23 Go to previous messageGo to next message
Edoardo:
There are no out-of-the box functions to sort. A function sort function may
be in order. Something like:
<c:iterate select="sort( my XPath, a-sort-key-expression)" var="...">
could be useful.
It is certainly possible for you to create something like this yourself, but
it would also be useful to the community at large.
Why not start by creating an enhancement bugzilla, and we can
discuss/develop an appropriate solution that will eventually land back in
JET?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=enhan cement&bug_status=NEW&bug_file_loc=http%3A%2F%2F& ;short_desc=&comment=&commentprivacy=0&keywords= &dependson=&blocked=&maketemplate=Remember%20val ues%20as%20bookmarkable%20template&form_name=enter_bug&a mp;assigned_to=m2t.jet-inbox%40eclipse.org
Paul
"Edoardo Comar" <ecomar@uk.ibm.com> wrote in message
news:frlqau$24a$1@build.eclipse.org...
> It lately turned out that these elements may not be in the oder I need for
> I'd be happy if the select statement supported "some sort" ;-) of sorting
> syntax.
> iteration?
> cheers
> Edo
Re: is it possible to SORT the results of a jet xpath select ? [message #43920 is a reply to message #43735] Thu, 27 March 2008 07:03 Go to previous message
done!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224337
Paul Elder wrote:
> Edoardo:
> could be useful.
> JET?
> Paul
>> syntax.
>> iteration?
>> cheers
>> Edo
Previous Topic:Editor not marking unresolved types?
Next Topic:problem with 0.9.0 I200804162020
Current Time: Thu Jul 17 16:05:11 EDT 2025
Powered by FUDForum. Page generated in 0.28113 seconds
