[Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43269] |
Thu, 07 May 2009 08:46  |
Originally posted by: sderrienREMOVE.irisa.fr
I want to define a DSL for an existing ecore meta model.
In this model I have an AbstractClass which has a feature named foo, and
a ConcreteClass that inherits from this AbstractClass.
I want to write a Rule to create an initialized instance of
ConcreteClass in which I initialize the feature foo (inherited from
AbstractClass).
I use the following Xtext Rule for this
MyRule1 returns ConcreteClass:
foo+=AnotherRule
However, I get the following error :
Cannot find compatible feature foo in sealed EClass ConcreteClass from
imported package http://mypackageURI.
Is there a way to specify that the feature belongs to the ParentClass
(something like super.foo+=AnotherRule) ? If not is there any alternive
solution ?
Steven Derrien
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43419 is a reply to message #43326] |
Thu, 07 May 2009 15:41   |
Hello Heiko,
Thank you for your help.
Actually my example was not correct, since my DSL involves
cross-references. Here is the actual code snippet :
import "http://www.irisa.fr/cairn/datapath/fsm" as fsm
import "http://www.irisa.fr/cairn/datapath/port" as ports
FSMRule returns fsm::FSM :
ports+=InputPortRule terms+=PredicateTermRule;
InputPortRule returns ports::InControlPort:
name=ID;
PredicateTermRule returns fsm::PredicateTerm :
(negated?=('!'))? flag=[ports::InControlPort];
It is the flag feature that causes the error message :
"Cannot find compatible feature flag in sealed EClass PredicateTerm from
imported package http://www.irisa.fr/cairn/datapath/fsm."
In the ecore file defining the fsm package, the EClass *PredicateTerm*
has a EReference feature named *flag* of type *InControlPort*, with
upperBound set to 1, and containment set to false.
Unless I am missing something obvious, everything seems consistent
to me (I double-checked before writing this mail).
Do you have any hints ?
Thanks in advance,
Steven
Heiko Behrens a écrit :
> Hey Steven,
> the problem here is that Xtext tries to find a proper feature that
> corresponds to "foo+=AnotherRule" in your meta model. Each assignment
> has to match with respect to its name, cardinality and type.
> Just looking at your snippet I would guess that AnotherRules does not
> return the proper type for the given feature foo defined in your
> existing meta model.
> This should work:
> MyRule returns ConcreteClass:
> foo=AnotherRule;
> AnotherRule returns TypeOfFeatureFooInConcreteClass:
> some?="rule that matches return type";
> Also, please be aware that "+=" and "=" expect different configurations
> of your meta model. The former expects a multi value containment feature
> where as the latter expect a single value containment.
> Hope that helps,
> Heiko
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43512 is a reply to message #43419] |
Fri, 08 May 2009 02:37   |
You use namespace URIs this implies that you have installed both
EPackages into the workbench. Did you?
We also need to have a look at the EPackages in order track the problem
down.
Sven
Steven Derrien schrieb:
> Hello Heiko,
> name=ID;
> Thanks in advance,
> Steven
>> Hey Steven,
>> This should work:
>> foo=AnotherRule;
>> configurations of your meta model. The former expects a multi value
>> containment feature where as the latter expect a single value
>> containment.
>> Hope that helps,
>> Heiko
Re: [Xtext] Problem : Cannot find compatible feature foo in sealed EClass [message #43662 is a reply to message #43512] |
Fri, 08 May 2009 05:54   |
Hi Sven,
Yes, I can see them in the EMF package registry view. Anyhow, if
packages are not registered, the Xtext editor shows an error directly on
the corresponding *import* line.
> down.
I'll see If I can send them to you by mail.
Thanks for the support.
Steven
> Sven
>> Hello Heiko,
>> name=ID;
>> from imported package http://www.irisa.fr/cairn/datapath/fsm."
>> Thanks in advance,
>> Steven
>>> Hey Steven,
>>> This should work:
>>> foo=AnotherRule;
>>> containment.
>>> Hope that helps,
>>> Heiko
FUDForum. Page generated in 0.33899 seconds
