Home » Eclipse Projects » DTP » Filtering and special characters
Filtering and special characters [message #43256] Fri, 28 March 2008 08:40 Go to next message
while experimenting with filters I found an unexpected behaviour of the
table filter. I created a table with the name $newtable within a Derby
profile (CREATE TABLE "$newtable" (col integer)). After applying a
"Starts with" filter with the expression "$", the table was not part of
the visible table list. Filtering tables with other names works perfect,
so I'm not sure if the seen behaviour is intended.
Rico
Re: Filtering and special characters [message #43323 is a reply to message #43256] Fri, 28 March 2008 09:43 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hey Rico...
I'd definitely add this as a bug. It may be that the filters are not aware
of special characters, so we could look at adding that.
--Fitz
"Enrico Schenk" <enrico.schenk@ingres.com> wrote in message
news:fsiovh$au5$1@build.eclipse.org...
> Hello,
> profile (CREATE TABLE "$newtable" (col integer)). After applying a "Starts
> with" filter with the expression "$", the table was not part of the
> visible table list. Filtering tables with other names works perfect, so
> Thanks
> Rico
Re: Filtering and special characters [message #43357 is a reply to message #43323] Fri, 28 March 2008 09:51 Go to previous messageGo to next message
Hi Brian,
I have had a look into this. The ConnectionFilterImpl.NotLikeFilter does
not escape the search patterns, so the special characters are treated as
regex. Ok, I'm going to add this as a new bug.
Rico
Brian Fitzpatrick wrote:
> Hey Rico...
> --Fitz
>> Hello,
>> Thanks
>> Rico
Re: Filtering and special characters [message #43383 is a reply to message #43357] Fri, 28 March 2008 10:12 Go to previous message
Thanks for the bug and the patch1 I'll get it delivered next week after we
get through the M6 milestone build.
--Fitz
news:fsit57$7vp$1@build.eclipse.org...
> Hi Brian,
> Rico
>> Hey Rico...
>> aware of special characters, so we could look at adding that.
>> --Fitz
>>> Hello,
>>> Thanks
>>> Rico
Re: Filtering and special characters [message #590659 is a reply to message #43256] Fri, 28 March 2008 09:43 Go to previous message
Hey Rico...
--Fitz
> Hello,
> Thanks
> Rico
Re: Filtering and special characters [message #590665 is a reply to message #43323] Fri, 28 March 2008 09:51 Go to previous message
Hi Brian,
Rico
> Hey Rico...
> --Fitz
>> Hello,
>> Thanks
>> Rico
Re: Filtering and special characters [message #590679 is a reply to message #43357] Fri, 28 March 2008 10:12 Go to previous message
--Fitz
> Hi Brian,
> Rico
>> Hey Rico...
>> --Fitz
>>> Hello,
>>> Thanks
>>> Rico
Previous Topic:Type hierarchy of JDBCUniqueConstraint
Next Topic:Re: DTP: Why SQL statements die saying "no database selected"
Current Time: Thu Jul 17 22:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.18106 seconds
