Filtering and special characters [message #43256] |
Fri, 28 March 2008 08:40  |
while experimenting with filters I found an unexpected behaviour of the
table filter. I created a table with the name $newtable within a Derby
profile (CREATE TABLE "$newtable" (col integer)). After applying a
"Starts with" filter with the expression "$", the table was not part of
the visible table list. Filtering tables with other names works perfect,
so I'm not sure if the seen behaviour is intended.
Rico
Re: Filtering and special characters [message #43383 is a reply to message #43357] |
Fri, 28 March 2008 10:12  |
Originally posted by: brianf.sybase.com
Thanks for the bug and the patch1 I'll get it delivered next week after we
get through the M6 milestone build.
--Fitz
"Enrico Schenk" <enrico.schenk@ingres.com> wrote in message
news:fsit57$7vp$1@build.eclipse.org...
> Hi Brian,
> I have had a look into this. The ConnectionFilterImpl.NotLikeFilter does
> not escape the search patterns, so the special characters are treated as
> regex. Ok, I'm going to add this as a new bug.
> Rico
> Brian Fitzpatrick wrote:
>> Hey Rico...
>> I'd definitely add this as a bug. It may be that the filters are not
>> aware of special characters, so we could look at adding that.
>> --Fitz
>> news:fsiovh$au5$1@build.eclipse.org...
>>> Hello,
>>> Thanks
>>> Rico
Re: Filtering and special characters [message #590659 is a reply to message #43256] |
Fri, 28 March 2008 09:43  |
Hey Rico...
I'd definitely add this as a bug. It may be that the filters are not aware
--Fitz
> Hello,
> profile (CREATE TABLE "$newtable" (col integer)). After applying a "Starts
> with" filter with the expression "$", the table was not part of the
> visible table list. Filtering tables with other names works perfect, so
> Thanks
> Rico
Re: Filtering and special characters [message #590665 is a reply to message #43323] |
Fri, 28 March 2008 09:51  |
Hi Brian,
Rico
> Hey Rico...
> --Fitz
>> Hello,
>> Thanks
>> Rico
Re: Filtering and special characters [message #590679 is a reply to message #43357] |
--Fitz
> Hi Brian,
> Rico
>> Hey Rico...
>> --Fitz
>>> Hello,
>>> Thanks
>>> Rico
FUDForum. Page generated in 0.28612 seconds
