Cannot load lib ssleay.dll [message #43229] |
Sat, 14 March 2009 22:00  |
I want to install JavaHL 1.4.x and JavaHL 1.5.x as well, because I must work with older repos
If i install only JavaHL 1.5.x connector, everything is loaded without problems and i have
used this config all time, but now i have installed JavaHL 1.4.5 and Native JavaHL
implementation 1.4 and here the problem arised.
Here is the error:
http://tinyurl.com/bvt3lb
and here are version of my plugins:
http://tinyurl.com/dbl2m5
I'm using latest Eclipse 3.4.2
If you need some more info pls ask me.
Thank you very much for any advices and suggestions
Re: Cannot load lib ssleay.dll [message #43623 is a reply to message #43411] |
Fri, 20 March 2009 20:27  |
Igor Burilo napsal(a):
> Hello sNop,
> This problem indicates that you have a BerkelyDB version mismatch.
> I can see here following solutions:
> 1. You can run svnadmin upgrade on the Subversion repository
> 2. Try to use SvnKit connector for svn 1.4 (currently it's SvnKit 1.1.7)
> For more info, please try to google as it more relates to SVN than to
> Subversive
Hi Igor,
so i have installed SvnKit 1.1.7 Connector and I have installed JavaHL 1.5.4 connector
too, but when I try to show history from repo which have old format i get the error:
Get log messages for 'http://svn.modxcms.com/svn/tattoo/tattoo/branches/1.0' failed.
Trying to use an unsupported feature
svn: Querying mergeinfo requires version 3 of the FSFS filesystem schema; filesystem
'/usr/local/svn/tattoo/db' uses only version 2
It's somehow possible to handle old and new versions of the subversion repos with subversive ?
And if it's possible how ? What combination of the connectors i should to use ?
Thank for any advices and suggestions
FUDForum. Page generated in 0.09068 seconds
