Re: EMF in plugin [message #431055 is a reply to message #431052] |
Thu, 25 June 2009 10:49 |
Ed Merks Messages: 33142 Registered: July 2009 |
Samuel,
Comments below.
Samuel wrote:
> After exploring more about what EMF does, I begin to doubt it is what
> I need. I would like to extend the UML2 framework so that it generates
> code for my UML elements.
The UML framework doesn't directly generate code so there's not much to
extend...
> But now it seems to me the EMF framework actually generates code for
> the UML editor, and not for the UML elements itself.
There is a UML.ecore which is used to generated the UML model itself,
its item providers, and the editor...
> Is there a way to define what code I would like to have generated for
> my UML elements itself?
It would be a from scratch effort and there are several template engines
available to help.
> Or should I code this all by myself?
Pretty much you're on your own. I'm not sure what you're trying to
generate, but I assume it must be very different from what EMF generates
or must involve UML element types for which there is to corresponding
Ecore mapping and hence for which EMF generates nothing...
> Samuel
Ed Merks
FUDForum. Page generated in 0.03207 seconds
