Home » Modeling » EMF » EMap<Object, EObject>
EMap<Object, EObject> [message #430846] Fri, 12 June 2009 07:13 Go to next message
I need an efeature with a "type" Map<Object, EObject>. Unfortunately
defining a EMap<Object, EObject> datatype requires custom implementation of
(de)serializing the "value" EObject. And I do not want implement such
serialization as the object already is an EObject.
In principle I can make my EObject be able to identify itself with the
"key", but still I need a specific "unique" colletion (as feature value
holder).
That collection should ensure there is only one EObject with the same "key",
similar to set, but adding new EObject should replace the same "key" object.
Maybe somebody had similar issue?
Re: EMap<Object, EObject> [message #430847 is a reply to message #430846] Fri, 12 June 2009 08:53 Go to previous message
--------------020406020003000501040002
Content-Type: text/plain; charset=windows-1257; format=flowed
Martynas,
Comments below.
Martynas Lelevicius wrote:
> implementation of (de)serializing the "value" EObject. And I do not
> want implement such serialization as the object already is an EObject.
How about using an EMap?
http://wiki.eclipse.org/index.php/EMF/FAQ#How_do_I_create_a_ Map_in_EMF.3F
The serialization of EJavaObject isn't human readable so that's going to
be kind of yucky too...
> value holder).
> "key", similar to set, but adding new EObject should replace the same
> "key" object.
Content-Type: text/html; charset=windows-1257
<html>
<head>
<meta content="text/html;charset=windows-1257"
http-equiv="Content-Type">
</head>
Martynas,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:h0td8q$ga9$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
I need an efeature with a "type" Map&lt;Object, EObject&gt;.
Unfortunately defining a EMap&lt;Object, EObject&gt; datatype requires
custom implementation of (de)serializing the "value" EObject. And I do
not want implement such serialization as the object already is an
EObject.
<br>
</blockquote>
Previous Topic:[TENEO] Problem with GMF BasicDecorationNodeImpl
Next Topic:Customizing XML format of root element
Current Time: Wed Jul 02 10:42:14 EDT 2025
Powered by FUDForum. Page generated in 0.16926 seconds
