Home » Archived » EPF » Publishing Diagrams with Activity Partitions
Publishing Diagrams with Activity Partitions [message #43207] Tue, 09 October 2007 07:10 Go to next message
i'm new at the group. First i want to thank all who contribute to this
fine piece of work.
Here is my question :
When i use diagrams with activity partitions containing the activities the
diagrams will not be generated (error.log is empty). When i put the
partitions over the activity-flow (without containing it actually) the
generation works fine.
Same effect on "custom categories" or "delivery processes".
Does this work as designed or is it a bug ?
Regards Andreas
Re: Publishing Diagrams with Activity Partitions [message #43296 is a reply to message #43207] Tue, 09 October 2007 12:09 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
That was a bug. https://bugs.eclipse.org/bugs/show_bug.cgi?id=203923. It's
scheduled to release for EPF 1.2.0.2
I am not sure what you meant by custom categories. If you could provide
detailed steps, it will be helpful. Better yet, you could open a bug. It
could be related to same one I mentioned above, but you could have
different scenario. And I would like to see whether we covered all the
possible scenarios or not.
Shilpa Toraskar
EPF Committer
Re: Publishing Diagrams with Activity Partitions [message #43528 is a reply to message #43296] Wed, 10 October 2007 04:37 Go to previous messageGo to next message
Thanks for the answer.
The post looks quite familiar. But in my installation (Version: 1.2.0.1
Build Label: 20070912-1538) the effect does not show up in browsing mode
but in the published web-side (browsing mode works fine).
1. I build a Capability pattern (that's what i meant not the "custom
categories" sry)
2. put a tiny flow on it.
3. publish it --> picture shows up
4. put a activity partition on the diagram
5. put the flow in the partition
6. publish it --> diagram does not show up
7. put the flow out of the partition
8. put the partition over the flow without containing it
9. publish it --> diagram shows up
Hope that helps. I can not attach this to the bug-note because at the
moment port 443 is blocked of our firewall. I'm working on it.
Regards Andreas
Re: Publishing Diagrams with Activity Partitions [message #43559 is a reply to message #43528] Wed, 10 October 2007 13:31 Go to previous message
I have added your notes to the bug.
Shilpa Toraskar
EPF Committer
Re: Publishing Diagrams with Activity Partitions [message #584540 is a reply to message #43207] Tue, 09 October 2007 12:09 Go to previous message
That was a bug. https://bugs.eclipse.org/bugs/show_bug.cgi?id=203923 It's
Shilpa Toraskar
EPF Committer
Re: Publishing Diagrams with Activity Partitions [message #584630 is a reply to message #43296] Wed, 10 October 2007 04:37 Go to previous message
categories" sry)
Regards Andreas
Re: Publishing Diagrams with Activity Partitions [message #584647 is a reply to message #43528] Wed, 10 October 2007 13:31 Go to previous message
Shilpa Toraskar
EPF Committer
Previous Topic:Is SPEM 2.0 "Metric" class implemented in EPF 1.2?
Next Topic:OpenUP solution looking for a problem
Current Time: Thu Jul 17 20:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.26451 seconds
