Home » Modeling » TMF (Xtext) » [Xtext] Workflow Errorwhen importing existing ecore meta-model
[Xtext] Workflow Errorwhen importing existing ecore meta-model [message #43205] Thu, 07 May 2009 06:04 Go to next message
Originally posted by: sderrienREMOVE.irisa.fr
I am trying to define a DSL in which I import another ecore metamodel
using the approach suggested in the documentation. I use the following
directive.
import "http://www.irisa.fr/cairn/datapath" as datapath
I first get an error in the editor telling me that the package is not
known, since it is not in the EMF registry. After registering the ecore
file, the error disapears, and I can then use my model classes as Rules
in the DSL spec.
The actual problem arise when I want to run the mwe workflow, I get the
following exception :
313 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering
platform uri 'C:\workspace'
1735 [main] ERROR ternal.core.ast.util.VisitorCreator -
java.lang.IllegalStateException: [XtextLinkingDiagnostic: null:5 Cannot
resolve reference to '"http://www.irisa.fr/cairn/datapath"']
java.lang.RuntimeException: java.lang.IllegalStateException:
[XtextLinkingDiagnostic: null:5 Cannot resolve reference to
Did I miss something, or is it a bug ?
I am using version 0.7 from March.
Thank you in advance,
Steven Derrien
Re: [Xtext] Workflow Errorwhen importing existing ecore meta-model [message #43241 is a reply to message #43205] Thu, 07 May 2009 07:45 Go to previous message
Well, I should have searched this newsgroup a little bit more
carrefully, since this problem was already mentioned in a previous threads.
For the record, on has just to add the follwing line to the mwe workflow
file.
Add this to your GenerateYOURDsl.mwe file:
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<registerGeneratedEPackage
value="your.model.package.name.YourModelPackage"/>
</bean>
Steven
news.eclipse.org a écrit :
> Hello,
> directive.
> in the DSL spec.
> Steven Derrien
Previous Topic:Language Libraries
Next Topic:Outline tree selection elements are all of the same type
Current Time: Thu Jul 17 19:45:43 EDT 2025
Powered by FUDForum. Page generated in 0.05803 seconds
